Results 51 to 64 of 64
Thread: problems posting images
April 30, 2019, 07:45 PM #51
Re: problems posting images
Thank you Mike and techs for all the hard work!
April 30, 2019, 08:47 PM #52
Test:
~ Bob ~
"And it Stoned me to my Soul" • Van Morrison
Click ♪ Audiophile Audition
April 30, 2019, 08:55 PM #53
Test 2:
~ Bob ~
April 30, 2019, 09:07 PM #54
~ Bob ~
April 30, 2019, 09:09 PM #55
Sorry for practicing; it's working much better than before.
May 1, 2019, 07:23 AM #56viking acoustics berlin r mk2 | almarro a318b + air tight atc-5 (phono) | clearaudio concept + virtuoso v2 MM | t+a dac8 dsd + diy transport + roon rock
May 1, 2019, 07:58 PM #57
My last test:
~ Bob ~
May 1, 2019, 08:02 PM #58
Test (music tune...video):
But for this one I had to slightly changed the URL address, make it longer in that exact same format as below ....
https://www.youtube.com/watch?v=IFIx0K2vpT4
If I only copy and paste the URL video and insert it in the small strip of film Function above, it won't work, because that URL address is like this:
https://youtu.be/IFIx0K2vpT4
* I need to add www and remove the dot of tu.be and add .com and add watch?v=
That's quite a lot of modification in order to make the Video Function works. I don't know any other better methods; anyone?
** For a picture with an URL address, in order to work I need to uncheck the small square below the address, @ left.
*** For a file in my computer, attachement, it works now, but it also adds the small attachment guide as well, below the main photo/image file. With gif it seems to only display a very small one, but you can click on it to open it larger on your display.
Conclusion: It is an improvement from previously.
Thx to Mike and his site's designer/construction worker.~ Bob ~
May 2, 2019, 09:27 AM #592chl : Vincent Sp331MkII, W4S STP-SE Stage 2, Kef 201/2, KEF 140, Vapor Breeze, Lumin, Bryston CD, BHA-1, Quicksilver Headamp, HD650, HD800s, HD820's, Dan Clark 1.1, Focal Stellia, OPPO 203, 105. ( Boxed up: Pass Xa-30.5, VPI Classic, Dynavector DV-20XL, Manley Chinook, Cadenza Bronze)
May 2, 2019, 09:59 AM #60
On a related note...how do you get images to post without attached thumbnails?? I can do it using Tapatalk on my iphone and ipad, but not from my Mac computers.
Rance
May 2, 2019, 10:02 AM #61
Flemming
Lumin X1
Rotel Michi S5
Focus Audio FS788
LS cable : Yter
Nordost QB8
Rack : Finite Elemente Pagode
May 2, 2019, 10:03 AM #62
Now i just have to figure out how to rotate the photo , but thank you Mike and team.
Flemming
Lumin X1
Rotel Michi S5
Focus Audio FS788
LS cable : Yter
Nordost QB8
May 2, 2019, 10:05 AM #63
May 2, 2019, 03:36 PM #64
I had the exact same issue. The trick I used is to edit the photo in my computer by rotating it 90° and then I just took out a slight tiny line from it and save. I don't know the edit function of your personal device but you should have a photo editing function on any PC, MAC, laptop, tablet, smartphone, ...
* When I just rotated it 90° and saved, it did not work, but after rotating it and editing the photo very slightly by removing just a small portion (only 1% or so), then clicking on Save, it worked. I could posted it in its proper orientation.
Post #53, second image ... prior to cutting it slightly (just rotating it didn't work for me, even after I clicked on Save) ...
• https://www.audioshark.org/showthrea...l=1#post270574
Then full edit on post #55 ...
• https://www.audioshark.org/showthrea...l=1#post270578
I only cut the picture @ the bottom by less than 1%.
1. Rotate the image 90°
2. Cut a small portion
3. Click "Save"
4. Now your image attachment should display in its correct orientation when transferring this new edited image.~ Bob ~
Clarisys Arrives at Puur...
