Page 2 of 2 FirstFirst 12
Results 51 to 64 of 64
  1. #51
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Re: problems posting images
    Thank you Mike and techs for all the hard work!
  2. #52
    Senior Member
    Join Date
    Apr 2013
    Vancouver Island, British Columbia, Canada
    Posts
    9,413
    Test:
    ~ Bob ~
    "And it Stoned me to my Soul" Van Morrison
    ClickAudiophile Audition
  3. #53
    Senior Member
    Join Date
    Apr 2013
    Posts
    9,413
    Test 2:
    ~ Bob ~
  4. #54
    Senior Member
    Join Date
    Apr 2013
    Posts
    9,413
    ~ Bob ~
  5. #55
    Senior Member
    Join Date
    Apr 2013
    Posts
    9,413
    Sorry for practicing; it's working much better than before.
  6. #56
    Senior Member
    Join Date
    Jan 2018
    saṃsāra
    Posts
    1,049
    All fixed!
    thanks mike!!
    viking acoustics berlin r mk2 | almarro a318b + air tight atc-5 (phono) | clearaudio concept + virtuoso v2 MM | t+a dac8 dsd + diy transport + roon rock
  7. #57
    Senior Member
    Join Date
    Apr 2013
    Posts
    9,413
    My last test:
    ~ Bob ~
  8. #58
    Senior Member
    Join Date
    Apr 2013
    Posts
    9,413
    Test (music tune...video):
    But for this one I had to slightly changed the URL address, make it longer in that exact same format as below ....
    https://www.youtube.com/watch?v=IFIx0K2vpT4
    If I only copy and paste the URL video and insert it in the small strip of film Function above, it won't work, because that URL address is like this:
    https://youtu.be/IFIx0K2vpT4
    * I need to add www and remove the dot of tu.be and add .com and add watch?v=
    That's quite a lot of modification in order to make the Video Function works. I don't know any other better methods; anyone?
    ** For a picture with an URL address, in order to work I need to uncheck the small square below the address, @ left.
    *** For a file in my computer, attachement, it works now, but it also adds the small attachment guide as well, below the main photo/image file. With gif it seems to only display a very small one, but you can click on it to open it larger on your display.
    Conclusion: It is an improvement from previously.
    Thx to Mike and his site's designer/construction worker.
    ~ Bob ~
  9. #59
    Senior Member
    Join Date
    Mar 2014
    Ormond Beach, Plantation Bay CC
    Posts
    5,185
    I rarely use a browser for Audioshark, but I just tried myself and couldn't upload an image. I will try to get this fixed ASAP.
  10. #60
    Senior Member
    Join Date
    Jan 2014
    Kentucky, USA
    Posts
    624
    On a related note...how do you get images to post without attached thumbnails?? I can do it using Tapatalk on my iphone and ipad, but not from my Mac computers.
    Rance
  11. #61
    Senior Member
    Join Date
    Aug 2016
    Denmark
    Posts
    639
    Flemming
    Lumin X1
    Rotel Michi S5
    Focus Audio FS788
    LS cable : Yter
    Nordost QB8
    Rack : Finite Elemente Pagode
  12. #62
    Senior Member
    Join Date
    Aug 2016
    Denmark
    Posts
    639
    Now i just have to figure out how to rotate the photo , but thank you Mike and team.
    Flemming
    Lumin X1
    Rotel Michi S5
    Focus Audio FS788
    LS cable : Yter
    Nordost QB8
  13. #63
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Quote Originally Posted by FDPDK View Post
    You’re welcome!
  14. #64
    Senior Member
    Join Date
    Apr 2013
    Posts
    9,413
    I had the exact same issue. The trick I used is to edit the photo in my computer by rotating it 90° and then I just took out a slight tiny line from it and save. I don't know the edit function of your personal device but you should have a photo editing function on any PC, MAC, laptop, tablet, smartphone, ...
    * When I just rotated it 90° and saved, it did not work, but after rotating it and editing the photo very slightly by removing just a small portion (only 1% or so), then clicking on Save, it worked. I could posted it in its proper orientation.
    Post #53, second image ... prior to cutting it slightly (just rotating it didn't work for me, even after I clicked on Save) ...
    https://www.audioshark.org/showthrea...l=1#post270574
    Then full edit on post #55 ...
    https://www.audioshark.org/showthrea...l=1#post270578
    I only cut the picture @ the bottom by less than 1%.
    1. Rotate the image 90°
    2. Cut a small portion
    3. Click "Save"
    4. Now your image attachment should display in its correct orientation when transferring this new edited image.
    ~ Bob ~
Posting Permissions
  • You may not post replies
  • You may not edit your posts
