Results 51 to 67 of 67
May 26, 2019, 10:04 AM #51
Re: Holger Stein visits Suncoast Audio
May 26, 2019, 10:30 AM #52
So here are my questions to you Mike: With your stereo system turned off or on mute, can you hear any sound(s) coming from the active devices? Are there any disturbances to the air that you can hear in your room with no sound playing but the active devices are on?
May 26, 2019, 10:31 AM #53
May 26, 2019, 11:01 AM #54
May 26, 2019, 11:03 AM #55
May 26, 2019, 01:19 PM #56
If you are manipulating the air pressure in the room which affects the sound waves coming from your speakers, how can it not affect tone? If you can change the height and position of a singer in your room, how can that not affect tone? The bottom line is your room boundaries are still there and they are still having the largest impact on your sound second only to the speakers themselves. What these active devices are doing can't be benign otherwise you wouldn't hear any effects from them.
May 26, 2019, 01:24 PM #57
I'm sort of with MEP but a little divergent on this. I don't know that I believe the tone will change by using this device. But I fully agree when the stereo is off the device is still working. That means any conversation, TV, or anything else going on in the room is going to be acted upon by the device and alter the way it is heard. If it's giving the illusion of the music playing in a different room, it seems to me everything else would be recreated as in a different room.
May 26, 2019, 01:40 PM #58
I've had mine for 7-8 years. Four Harmonizers, stands, plus black stones plus blue diamonds.
Over the past dozen years or so, I evaluate any component purchase solely as to how high - if at all - musical engagement is enhanced.
The Steins were an unqualified success in that area.DPT4ME - Dynamics, Presence & Tone for Musical Engagement; MBP (3) - stripped down for music only; Shunyata Omega & Sigma USBs; ISO REGEN w/short Curious USB links; Berkeley Alpha USB; Aqua La Scala II Optologic DAC; Schiit Yggdrasil - fully updated; Ayre Codex dac - updated; Pass Labs INT-60 integrated amp; Wyred 4 Sound STP-SE-2 preamp, Quicksilver Mono 120 amps w/Tung-Sol KT150s; Quicksilver Mid Mono amps w/Gold Lion KT77s; Fyne Audio 703s; Symposium Svelte Plus & Ultra Platforms; REL S-812 subwoofers; Duelund DCA12GA speaker cables; AV Room Service EVPs, Stein Music Harmonizers, Duelund DCA16GA & 20GA ICs; Shunyata Denali 6000S/V2; Tripp Lite PCs; Wyred 4 Sound power cords; AudioDharma cable cooker; dedicated custom room; various GIK & ASC room treatments; etc.
www.getbettersound.com
May 26, 2019, 04:37 PM #59
I am guessing (since I have never heard these), but from what I understand from several reviews, including Mike's, these do not change or affect the tonality of the music but make the air and atmosphere in the room easier for sound waves to to travel trough. Therefore they open up the music by allowing it to travel through the room unhindered, or so it seems from what many people are saying.
I am very interested in trying them, however I do have one question from those who own the Steins. I am a tad concerned that with my listening room in a loft with both side walls open (half walls opening to approximately 30' high ceilings below) and how this might affect the Harmonizers. Any thoughts about if these open walls will neutralize the Steins, rendering them ineffective?McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
― Neil deGrasse Tyson
May 26, 2019, 04:53 PM #60
For me, placement has been the key in several rooms, (maybe 10’ away in front, outside and a bit back from the mains, maybe 5’ in the rear - spread a bit wide as my seat is about 4' from the rear wall. You do have a level control. In mine, since they are relatively close, IIRC, the front level control is somewhere above 10:30 or so, and the rear is a bit below 10.
I wouldn't think you'd have a problem, but Mike may have a much better answer to your specific question.
May 29, 2019, 08:27 PM #61
- Oct 2014
- Oregon
- 233
A question for Jim. Is there a psychological component to it? In other words, do you feel more relaxed with it on? Not a byproduct of the acoustics, but a additional advantage. What is the effect of turning up the control on the units? Thanks
May 30, 2019, 03:18 AM #62
I do have a question: how does a typical Stein Music setup look like, which components do you you need and why?
May 30, 2019, 07:42 AM #63
May 30, 2019, 08:54 AM #64
2 x https://steinmusicstore.de/en/portfolio-item/h2/
Placed front left and right
7 x http://v2.stereotimes.com/post/stein-music-blue-sun
Placed one middle between speakers at front of room. Two just past the tweeter on each side. Two just in front of the listening position on each side. One at back of room. One on ceiling just in front of the listener.
7 x https://steinmusic.de/portfolio-item/diamonds/
PLACED ON TOP of the Blue Sun Signature’s (listed above).
Of course you can go with less, I’m just trying to relay what I did in my rooms. The only thing I added was two more H2’s at the back of the room in the big room only.
You stick up with some tacky putty. Ideally black.My Systems: http://www.audioshark.org/showthread...481#post158481
May 30, 2019, 12:54 PM #65
Hmm, I never thought of it as psychological, but as I think of it now, I think it does have some of that aspect.
For me it is a more relaxing, yet more involving musical experience. The reproduced sound is smoother in a good way - maybe not as super clinical (with recordings that lean that way).
If I were to name one thing that I especially value, it's the sense of Presence, especially on recordings that were closely mic'd. It can be quite literally as if the performers are in the room.
Re the level control, I don't remember much about it since it was so long ago that I settled on an acceptable level. IIRC, if turned up too high, things got bloated in their effect - not better, in other words.DPT4ME - Dynamics, Presence & Tone for Musical Engagement; MBP (3) - stripped down for music only; Shunyata Omega & Sigma USBs; ISO REGEN w/short Curious USB links; Berkeley Alpha USB; Aqua La Scala II Optologic DAC; Schiit Yggdrasil - fully updated; Ayre Codex dac - updated; Pass Labs INT-60 integrated amp; Wyred 4 Sound STP-SE-2 preamp, Quicksilver Mono 120 amps w/Tung-Sol KT150s; Quicksilver Mid Mono amps w/Gold Lion KT77s; Fyne Audio 703s; Symposium Svelte Plus & Ultra Platforms; REL S-812 subwoofers; Duelund DCA12GA speaker cables; AV Room Service EVPs, Stein Music Harmonizers, Duelund DCA16GA & 20GA ICs; Shunyata Denali 6000S/V2; Tripp Lite PCs; Wyred 4 Sound power cords; AudioDharma cable cooker; dedicated custom room; various GIK & ASC room treatments; etc.
June 3, 2019, 03:09 PM #66
- Oct 2014
- Oregon
- 233
Thank you for the detailed response. I am working on something similar. When I reached it's to much level the music was in my face. That should give the chicken bones guys something to laugh about. I just ran across this ad for a used set for anyone interested.
https://www.audiogon.com/listings/li...-stands-tweaks
June 3, 2019, 03:21 PM #67
I'm suffering issues with getting 1 boulder amp to talk to another boulder amp. I will agreed sound is pretty good.
Boulder 866 app
