Results 1 to 2 of 2
April 12, 2019, 11:22 PM #1
- Oct 2014
- Oregon
- 234
Question about biasing a Reference 110 amplifier
I am a new owner of a used Reference 110. I am about to bias the output tubes. I understand the procedure but unsure about the bias pots. There are two circuit board pots at the other end of the board where the tubes are mounted. Are those the correct pots to adjust? Because the are quite a distance from the tubes I want to make sure they are not adjustments for something else. Thanks
April 13, 2019, 05:44 PM #2
- Oct 2014
- Oregon
- 234
Re: Question about biasing a Reference 110 amplifier
Got it.
i hear differences between streamers, the power supplies and the chassis material is audiable. A good streamer is a wise thing to invest in and they are absolutely not all the same.
Streamer selection
