Results 1 to 30 of 30
April 9, 2019, 02:22 PM #1
SOtM SNH 10g Ethernet Switch Review
https://audiobacon.net/2019/04/05/so...ch-review/amp/
April 9, 2019, 03:38 PM #2
Re: SOtM SNH 10g Ethernet Switch Review
April 9, 2019, 04:04 PM #3
thanks for posting - good information in addition to the product review. the comment in the intro that really set up the rest of the article for me was:
"I’ve written quite a bit about why it isn’t just 0’s and 1’s... It boils down to noise (RFI/EMI) modulating how the DAC interpolates the bits – and how it affects the analog output section... Many don’t realize that a digital signal is still an analog signal – and it’s not perfect".
i took that to mean a digital signal transmitted over a copper (or some other metal) cable also carries with it all the accumulated upstream electrical noise. hence, the performance and SQ characteristics of the SOtM sNH-10G are attributable to how well it handles this electrical noise as it passes along the hybrid digital/analog signal.
which gets me to thinking... if the goal is to deliver a pure digital signal to the DAC - free of electrical noise - then optical isolation is perhaps a more effective alternative? otherwise, we are simly left choosing among devices that have differing quantities and flavors of noise... can't help but think SOtM included 2 SFP ports on the switch for a reason.viking acoustics berlin r mk2 | almarro a318b + air tight atc-5 (phono) | clearaudio concept + virtuoso v2 MM | t+a dac8 dsd + diy transport + roon rock
April 9, 2019, 04:27 PM #4
More than just about noise with audiophile switches, it’s also about jitter.
April 9, 2019, 04:47 PM #5
phewwww.... just when I thought the gigafoil / Aqvox discussion had been exhausted... Now it seems time to have a discussion about this one (and soon the UpTone version). At least it's good to see more and more players jumping into this important area... No doubt clocks (jitter) and switches (noise floor) make a huge difference in streaming quality. Haters can say whatever they want, but I beg you to listen first before forming an opinion.
Ken, I'm getting a MSB Ref... I wasn't quite following what you were saying above. Are you saying that there could be a clock in the switch and then another clock in the MSB? I wonder what happens in the case there are two clocks...?Jeremy
Speakers: Magico S3 MkII
Power Amp: VAC 200iQ (stereo)
Source/DAC/Preamplifier: MSB Reference DAC (Femto 77 / Dual Powerbase)
Power: Shunyata Triton V3 / Shunyata Typhon QR / AQ NRG 20 Outlet / Dedicated 20 amp circuit
Power Cables: AQ Dragons to components / AQ Hurricane to Typhon QR
Speaker Cables: MIT Heritage MI 2C3D - Level 1
Interconnects: MIT Heritage MI 2C3D - Level 1 (XLR)
Ethernet: AQ Vodka > Aqvox SE > AQ Diamond > MSB Reference DAC
Racks: Critical Mass Sotto Voce with Black Platinum shelves
April 9, 2019, 08:01 PM #6
April 9, 2019, 10:36 PM #7
Based on what I have learned from their US distributor, You can use an external Master Clock to ‘clock’ the SOtM switch. In my case, that would be a Cybershaft Limited which can Clock multiple devices.
I am still on the fence about the cost of this device. With the clock connector, and upgraded wiring (whatever that means), it lists for $1,900.Main Equipment: Kharma Elegance dB11-S, JL Audio F113v2, Block Audio Line & Mono SE Amplification, Bricasti M21 DAC, Antipodes Kala K-50 Server, ClearAudio Performance SE, Satisfy Arm & Maestro Wood MM Cartridge
Power: 3 x 20 Amp Lines, Shunyata Everest 8000, Sigma XC v2, Shunyata Sigma v2 NR, Block Audio Power Cords, Defender, ADDPowr Wizard
Grounding: Shunyata Altaira CGS - Alpha CGS cables
Network : Supra Cat 8+, Twin (Nenon Modified) Buffalo GS2016 Switches powered with Keces P3 LPSU,
Cables: Wireworld Platinum Starlight 8 USB, Wireworld Platinum Eclipse 8 SCs, 1M & 6M Tubulus Concentus ICs,
Other: Isoacoustics GAIA I footers on the Kharmas, GIK/Vicoustics/Stillpoint Apertures, Stillpoint Ultra SS, Furutech GTX - Gold outlets, Adona Rack
April 10, 2019, 08:58 AM #8
thanks vey much for the clarification.
i have been relying on the, perhaps mistaken, understanding that given a digital audio stream of sufficient quality, DACs with their own internal clock are capable of operating without reference to or use of the timing information from the source clock (asynchronously), thereby, eliminating any jitter from upstream clocks. [an airport express running airPlay2 is capable of delivering a signal of sufficient quality to allow my DAC to switch over to its internal clock, so the threshold input signal would seem pretty low.]
i have also been under the, again perhaps mistaken, assumption that for a DAC with a network renderer the audio file is transmitted directly from the server to the onboard DAC renderer which then creates the digital music stream using the DAC's internal clock ...never using any upstream clock at all for the purpose of generating a digital audio signal.
my next project is to reconfigure my network so it would be very helpful to learn where i have gone off the rails here. any input would be greatly appreciated!!viking acoustics berlin r mk2 | almarro a318b + air tight atc-5 (phono) | clearaudio concept + virtuoso v2 MM | t+a dac8 dsd + diy transport + roon rock
April 10, 2019, 10:42 PM #9
Peter Lie
LUMIN Firmware Lead
April 11, 2019, 07:25 AM #10
I got one myself. It does make a small, positive difference. I suspect it will be system dependent.
On the digital side, my system consists of:
SOtM switch > SOtM sMS-200Ultra > Intona USB Isolator > SOtM TX USB reclocker
All powered by a bunch of UpTone Audio LPS-1.2 PSUs. I need to try a 10MHz clock on the SOtM reclocker and switch (both have the 10MHZ inputs).Adam
Speakers: Magico M3
April 11, 2019, 08:51 AM #11
April 11, 2019, 09:38 AM #12
Speakers: Wilson Alexias
April 13, 2019, 12:04 PM #13
April 14, 2019, 05:18 AM #14
- Oct 2015
- 2
[QUOTE = kzhtoo; 268620] Questo è molto interessante per me. My Discrete ha un output di sincronizzazione di parole. Qualcuno può confermare questa configurazione con lo switch SOtM funzionerebbe? [/ QUOTE]
It us non possibile .
The word sync output is either a 44.1kHz or a 48kHz clock. The SOtM devices requires a 10MHz clock.
Ciaomsb, burmester, acapella
April 14, 2019, 09:29 AM #15
May 17, 2019, 07:34 PM #16
- Sep 2018
- 48
My friend on my audio discord has this switch and really loves it. That with SOTM 200 ultra has made his front end super resolving.
May 18, 2019, 02:27 AM #17
It is interesting, classic placebo effect at its finest seen here.
The master clock input works on 10mhz, not typical audio frequencies from the MSBs clock.
In any case, even if it is the inappropriate frequency, it does absolutely nothing, the sclk ex in the Sotm will still work and the unit functions as if there is no masterclock.
May 18, 2019, 08:12 AM #18
Not necessarily. I spoke with Alex and while the clocking is not synchronized they did hear a clear improvement when they went back and forth. They believe it may be due to improved grounding. Nevertheless, another clocking solution is needed. Alex will be getting in some 10 MHz clocks to try. The usual suspect is the Cybershaft. Stay tuned.
May 18, 2019, 01:37 PM #19
May 18, 2019, 11:39 PM #20
Do you mean Alex from Uptone?
Yes, not to confuse things, i did have the analysis that a bnc cable connected to the MBS does noting in the sense for master clocking (keeping to topic), but the ground of whatever digital cable will have effects by way of improved grounding.
Just leaving the digital cable connected to the switch and ot connected on the other end also has effect on the total grounding of the system.
I feel this is not the way to approach this, as they are many other grounding solutions out there as opposed to letting customers spend on expensive clock cables and hearing an improvement due to improved grounding via whatever digital cable that is connected.
ment
Experiments could lead to this connection even to a preamp and possibly provide greater synergy in grounding architecture of the whole system that may provide a better improvement over the connection that they did.
May 19, 2019, 12:35 AM #21
May 19, 2019, 12:54 AM #22
Any update on the Uptone switch?
May 19, 2019, 01:26 AM #23
May 19, 2019, 01:33 AM #24
It was much of a shame that the Msb Femto 33 's clock frequencies are not compatible to be used with a lot of other universal clocking requirements (so is DCS clocking system) which does not use 10Mhz.
The problem and issue arises when streaming different sampling rates, if 10Mhz is not used, specific clock frequencies for different base sampling rates will cause the dac or streamer not being able to output any sound.
For streaming, the clocking for equipment such as a switch at the source has proven to be the most obvious and important changes that will render any downstream equipment vastly improved or different based on selection of various clocking eco-system, that includes clocking cables which possibly might prove to have one of the biggest impact of all cabling within a system.
May 19, 2019, 10:24 AM #25
- May 2019
- US
- 217
May 19, 2019, 10:35 AM #26
May 20, 2019, 10:46 AM #27
May 20, 2019, 07:28 PM #28
Also there might be a new clock on the way..
May 20, 2019, 08:46 PM #29"No summit worth climbing is easily attained."
May 24, 2019, 02:29 AM #30
This is a great discussion guys, I'm just catching up on the entire thread, but lots of good discussion here. I just spoke to Kamal at SOtM-USA today and discussed clock solutions for both the Switch and the SMS-200UltraNeo. The UltraNeo actually has 4 clock inputs on it. The Neo itself uses only two of the four, so this leaves two clock inputs free for connecting another device, such as...a switch. So, if you get a Neo, you can have either the (new) SOtM Ethernet switch use of one of the remaining two clock inputs on the Neo. Additionally, if you don't have the funds to pony up for the $800 SoTM Ethernet switch, you can also get their modded D-Link switch; modded with an input port to connect to one of the clock inputs on the Neo, so that you don't have to buy an extra clock for a the D-link Ethernet switch. Pretty cool!
