Results 1 to 18 of 18
March 21, 2019, 12:40 AM #1
- Mar 2019
- 4
Accuphase A-70 enough to drive Magnepan 20.7 or 30.7?
hi,
Wonder if anyone has experience with Magnepan driven by Accuphase A-70 class-A amp?
More specifically, wondering if A-70 has enough power to drive large panels such as the 20.7 or 30.7. By the way, I saw in an online 30.7 User's Manual that it apparently has the same sensitivity rating as that of 20.7, which is rated 4 Ohms load and 86dB/500Hz /2.83v sensitivity.
March 21, 2019, 09:25 AM #2
Re: Accuphase A-70 enough to drive Magnepan 20.7 or 30.7?
Hi Charles and welcome to AudioShark! While the inherent quality of a pure Class A amp like the Accuphase A-70 would be apparent at moderate volume levels with the large Magnepans, such speakers really thrive on high power and current and in my experience only really 'come to life' when driven with amps rated at a couple of hundred watts and above. Even when not being driven towards the amplifier's limits matching high powered amps with the large Maggies seems to energize and control the panels much more successfully than lower powered amps and as a result they sound more effortless and relaxed in their presentation. Hope this helps!
March 21, 2019, 10:26 AM #3
The A-70 is a beefy amp but, with Maggies, it would not have enough power for me. I've never tried that combo tho.
Jock
March 22, 2019, 09:29 AM #4
That's such a sweet amp..would probably sound amazing on 20.7s, but, I'd bet that on those occasions where ya want to play hard (loud) you'd be wanting more power.
Magnepan 20.7 - CJ ART 300s - CJ GATV2 - Meitner MA-1 V2 -Dedicated JRMC + Synology NAS
March 25, 2019, 08:57 PM #5
- Nov 2013
- Minnesota
- 1,369
March 27, 2019, 03:20 AM #6
When I had my 20.7's I tried as many amps on them as I could but even the Sanders stereo/mono amps struggled at times for me .... ymmv.
March 28, 2019, 02:50 AM #7
- Aug 2013
- 334
The A-70 is a high current amplifier and it won't have any problems driving the Magnepans; only things you need to consider are your listening distance from the speakers and your desired SPL at the listening position; based on these two factors calculate if the A-70 has enough power to give you the SPL you want.
March 28, 2019, 11:07 PM #8
- Nov 2013
- Minnesota
- 1,369
March 29, 2019, 03:00 AM #9
- Aug 2013
- 334
60W is the rated class A power, the actual power available is 130W@8Ohm and 230W@4Ohm; just like the Pass XA60.8 for example is not a 60W amplifier but a 120W one.
http://www.accuphase.com/cat/a-70_e.pdf
I don't know how loud the OP likes to listen but the A-70 will give him 100dB peaks at a 3m listening distance without problems with the 86dB sensitive Magnepans.
http://myhometheater.homestead.com/splcalculator.html
March 29, 2019, 03:49 AM #10
March 29, 2019, 04:00 AM #11
March 29, 2019, 05:44 AM #12
- Aug 2013
- 334
The name has nothing to do with the class A power available, the A-60 had 300W idle consumption.
http://www.accuphase.com/cat/a-60_e.pdf
March 29, 2019, 11:29 AM #13
Numbers aside . . . . .
I love the balls of the accuphase BUT in my opinion, it would not power the Maggies to a level acceptable. Maggies are an easy load BUT need power.Jock
March 29, 2019, 02:35 PM #14
Its 70 watt class A with a an A70 designation , go figure .... regardless the numbers you quoted are way off, extreme irony you picked that to discredit findings ..
Anyway 83db is what 3.6R Maggie ( Maggie usually claim 86) actually measured, best to hook them up and listen from experience 300/300 is what they usually need ...
Regards
March 29, 2019, 03:02 PM #15
Jim
March 29, 2019, 03:58 PM #16
The A65 was just a better amp , surely you not suggesting a 500/500 watt Accuphase equivalent is less than an A65 ...
BTW , Im familiar and have used Accuphase amps since the 70’s ...
Regards ..
March 29, 2019, 04:01 PM #17
Jim
February 23, 2020, 07:07 AM #18
- Oct 2015
- FRANCE
- 353
So , what do you have choose as amplifier ?
Marantz SA7S1/GRIMM AUDIO CC1/MARK LEVINSON 360S+TECHNICS SL1210 MKII/ORTOFON X1-MC/VPI CLASSIC 3 in rosewood/Audio-Technica ART-9/ESOTERIC E03+TAG MC LAREN T32R+JEFF ROWLAND CORUS+JEFF ROWLAND MODEL 625+Magnepan 3.7i+Cables line: all Furutech lineflux+power cord DIY
Suggestion: run Roon core on a computer in your house. Laptop is fine. Try roon on the aurender (free demo) and compare. If you prefer roon (it’s the best UI, but sonically inferior IMO), then...
Aurender and Roon
