Results 1 to 17 of 17
  1. #1
    Senior Member
    Join Date
    Feb 2019
    Southeast Iowa
    Posts
    992
    How long does it take to adequately warm up the tubes (power and preamp) of a tube amp designed for home audio?
    I've always owned tube powered guitar amps. Usually but not always NOS 6L6 power amp tubes and usually but not always NOS 12AX7 preamp tubes. I found it takes about 20 minutes to warm up and "stabilize." I've also found the tone of a tube powered guitar amp to be slightly inconsistent for those first 20 minutes or so. I've never owned a tube powered home audio amp. Do they require approximately the same warm up time? More, less, none at all?
  2. #2
    Senior Member
    Join Date
    Nov 2015
    Kansas
    Posts
    5,951
    Re: How long does it take to adequately warm up the tubes (power and preamp) of a tube amp designed for home audio?
    I have noticed that my tube gear sounds considerably better after about 20-30 minutes!
    ― Neil deGrasse Tyson
  3. #3
    Senior Member
    Join Date
    Feb 2016
    west Michigan
    Posts
    713
    It depends a lot on which tube you're talking about.
    Tubes like Randy's 6C33's are very slow to ramp up and stabilize.
    However as stated 20-30 minutes is generally more than satisfactory.
    The other components in the piece of equipment may require more time to reach their potential though.
    My System
    Acoustic Revive RTP-4
    Innuos Pulsar
    Lampizator BALTIC4
    Cary SLP-05
    Pass XA30.5 or
    Line Magnetic 845ia
    Reference 3A Reflector's
    Pr SVS SB3000 Subs
    Core Audio Design Rack
  4. #4
    When the somore's are ready so are the tubes. I'm kidding, I wouldn't know.
  5. #5
    Senior Member
    Join Date
    Nov 2013
    St. Louis, MO, USA
    Posts
    3,067
    My CJ gear took 30 to 45 minutes to open up.
    SVS PC13 Ultra
    Sony XBR-75X940D & BDP
  6. #6
    Senior Member
    Join Date
    Apr 2017
    Wesley Chapel, FL
    Posts
    962
    Any of my ARC amps 30 min. +-
    Synology 1019D+ - SGC Sonictransporter I9 w Roon/HQ Player- UltraRendu- PBD Stream IF to Playback Designs MPS5 via fiber optic - ARC 40th Anniversary Pre - ARC 610 T's - Martin Logan CLX's - 4 Martin Logan Depth i Subs - Shunyata Hydra, DIY PCOCC interconnects, speaker cables and power cords with Furutech terminations. Blue Jeans CAT 6's. Acoustically treated room with one permanent chair.
  7. #7
    Senior Member
    Join Date
    Dec 2015
    Posts
    346
    Jadis DA 50:
    5 minutes - good
    30 minutes - better
    60 minutes - perfect
    hifi:
    power: Audioplan Powerstar, Audioplan Finefilter, Audioplan Powerplant, Powercord
    tube amp: Jadis DA 50 Signature RC, Line Magnetic 508ia
    speaker: Living Voice Avatar 2
    turntable: Pro-Ject Xtension 10 + Ortofon Quintet Black MC
    phono stage: Remton 383 MKII
    cables: Audioplan Musicable bic 7a, Profigold, Wilbrand
    home-cinema: Sony blu-ray, Yamaha rx v2700, Heco Metas 700 (4x), Heco center
  8. #8
    Senior Member
    Join Date
    Nov 2013
    SE Pa
    Posts
    2,036
    the variable for 'tube warm up' has a direct correlation to ones own personal perceived belief's as well.
    FWIW, when I was running tube amps (KT120's) for the initial 20 hours or so of the new tubes they were re-biased a couple of times, after which tube bias stabilized to where they remained as such for hundreds of hours. It was at that point that I felt comfortable with 30-45 min warm ups ...........
    Cheers ! …. Dave
  9. #9
    Senior Member
    Join Date
    Jan 2014
    Bluffton SC
    Posts
    767
    My all tube amplification system gets smoother after about 15 minutes. If pushed to describe it, I would say the mods become fuller.
    Main Equipment: Kharma Elegance dB11-S, JL Audio F113v2, Block Audio Line & Mono SE Amplification, Bricasti M21 DAC, Antipodes Kala K-50 Server, ClearAudio Performance SE, Satisfy Arm & Maestro Wood MM Cartridge
    Power: 3 x 20 Amp Lines, Shunyata Everest 8000, Sigma XC v2, Shunyata Sigma v2 NR, Block Audio Power Cords, Defender, ADDPowr Wizard
    Grounding: Shunyata Altaira CGS - Alpha CGS cables
    Network : Supra Cat 8+, Twin (Nenon Modified) Buffalo GS2016 Switches powered with Keces P3 LPSU,
    Cables: Wireworld Platinum Starlight 8 USB, Wireworld Platinum Eclipse 8 SCs, 1M & 6M Tubulus Concentus ICs,
    Other: Isoacoustics GAIA I footers on the Kharmas, GIK/Vicoustics/Stillpoint Apertures, Stillpoint Ultra SS, Furutech GTX - Gold outlets, Adona Rack
  10. #10
    Senior Member
    Join Date
    May 2013
    Posts
    3,242
    Thirty minutes works for me even with the hybrid BHK gear.
  11. #11
    Senior Member
    Join Date
    Apr 2015
    North Central Florida
    Posts
    3,483
    My pair of McIntosh MC2301 tube power amplifiers hit their stride at about 30 minutes. I generally turn the sound system on about a half hour or so before I begin listening.
    Dan
    STUDIO - McIntosh C1000C/P, MC2301 (2), MR88, Aurender N10, Esoteric K-01X, Shunyata Sigma spdif digital coax,
    Sonos Connect, Stillpoints Ultra SS & Ultra Mini, PurePower 2000, Furutech Flux 50, Michell Gyro SE, Michell HR Power Supply, SME 309, Ortofon Cadenza Black, Sonus faber Amati Anniversario
    LIVING ROOM - McIntosh C2300, MC75 (2), MR85, Magnum Dynalab 205 Signal Sleuth, Sonos Connect, Simaudio MOON Neo 260D-T, Schiit Audio Yggdrasil, Aurender N100H, Shunyata Sigma USB cable,
    Sony DAT 60ES, Nakamichi BX-300, Micro Seiki DD40 w/m505A tonearm, Ortofon Cadenza Blue, PS Audio P10, Furutech Flux 50, Stillpoints Ultra Mini, PMC EB1i, JL Audio f113
  12. #12
    Senior Member
    Join Date
    Nov 2013
    St. Louis, MO, USA
    Posts
    3,067
    I used to turn mine on ahead of time as well but it still seemed like it took a bit of music playing to get them at the right point. Definitely seemed to reduce the overall time from cold though.
    Quote Originally Posted by jdandy View Post
    SVS PC13 Ultra
  13. #13
    I really don't notice any major changes during warm up of the CJ gear... a slight change during the first half hour or so, but, it's sweet from the start!
    Magnepan 20.7 - CJ ART 300s - CJ GATV2 - Meitner MA-1 V2 -Dedicated JRMC + Synology NAS
  14. #14
    Senior Member
    Join Date
    Nov 2013
    St. Louis, MO, USA
    Posts
    3,067
    My CJ never sounded bad, after about 30 minutes or so you should hear like the sound stage sort of open more and a more relaxed sound. Maybe at the end of a CD/album play the first track again, if you trust your memory I think you will hear what I mean. It's almost like a flower closed to the cold and opening up in the warm sun
    Quote Originally Posted by Rayooo View Post
    SVS PC13 Ultra
  15. #15
    About 9 to 10 minutes for my HH Scott 299C - 15 minutes for my Scott 296.
  16. #16
    Senior Member
    Join Date
    Oct 2014
    Tampa, FL
    Posts
    126
    I turn on the ref 6 about 45 minutes before I begin listening. also gives me a chance to finish the second jack and coke...
    Aurender > Weiss > Audio Research > SoundField
    Oppo > Lexicon > Hegel > SoundField
  17. #17
    Senior Member
    Join Date
    Apr 2013
    Staten Island, New York
    Posts
    703
    Quote Originally Posted by tube-vds View Post
    Jadis DA 50:
    5 minutes - good
    30 minutes - better
    Just to add to this:
    90 minutes to 2 hours - Outstanding!
    Paul
    Tape Deck Otari 5050B II2
    Music Server: Aurender N100H
    SSP: Marantz AV8801 Cables: Wireworld Electra 7 (P) Wireworld Silver Eclipse 7, Shunyata Delta NR (I) Wireworld Silver Eclipse 7 (S)
    Wireworld Platinum Starlight 7 (USB)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
