Results 51 to 61 of 61
March 28, 2021, 09:04 PM #51
Re: Conrad Johnson ART27A Stereo Triode Tube Amp
More in updated post 47. Pictures on the way.
Wilson Yvette speakers, [B]Conrad-Johnson [ART88 [B]pre, TEA1bc phono, and ART 27A Amplifier, Marantz digital player, Wireworld Gold and Platinum ICs, USB and power cables, Rega Planar 10 turntable/ Apheta cartridge, Wireworld Platimum Eclipse 8 speaker cables, AQ Hurricane and Tornado power cables, Shunyata Denali 6000S/V2, Sigma NR PC and DELTA USB cords, Symposium and Stillpoint vibration control, JL Audio Fathom 113 subwoofer, dCS Bartok Streamer/DAC
March 28, 2021, 09:34 PM #52
March 28, 2021, 10:43 PM #53
April 16, 2021, 08:57 PM #54
As we know, Conrad-Johnson amplifiers take a bit longer to break in due to all the proprietary caps. Well the ART27 just continues to improve. Coming from an ART150S, surprisingly, the lower power has been absolutely no issue at all. For everyday listening streaming from the dCS Bartok at 2 volts, the GAT volume setting of 28 is loud enough to annoy my wife's TV two rooms away. In a 20x30x12 room. Somehow we are driving more bass to the Yvettes than the 150 did with similar music. For phono out of the C-J TEA1bc, the GAT needs about five more clicks, easily done. That said, the sound is magnificent. Rich and detailed. Noticeably more dynamic, better transients. Don't know how you convince folks that 36WPC is this much better than 150 but it's immediately obvious to any savy listener. I guess that's it. Will it be enough in my room, for my speakers. with my music? An easy decision in my case.
Oh yes... I owe this post some pictures as soon as I figure out how to post them.Wilson Yvette speakers, [B]Conrad-Johnson [ART88 [B]pre, TEA1bc phono, and ART 27A Amplifier, Marantz digital player, Wireworld Gold and Platinum ICs, USB and power cables, Rega Planar 10 turntable/ Apheta cartridge, Wireworld Platimum Eclipse 8 speaker cables, AQ Hurricane and Tornado power cables, Shunyata Denali 6000S/V2, Sigma NR PC and DELTA USB cords, Symposium and Stillpoint vibration control, JL Audio Fathom 113 subwoofer, dCS Bartok Streamer/DAC
July 31, 2021, 10:05 AM #55
- Jul 2017
- zone7
- 27
HI, i recently acquired ART27A amp and now looking for a preamp to set a system, ET7S2 vs GAT S2, i have not heard either.
is there any major sonic deference between two, when price is taken in consideration.
I know both are single ended as is ART7A amp.
I had issues connecting amp to AR ref6 preamp due to balanced outputs.
Thank you for your input.
Sami
July 31, 2021, 10:33 AM #56
Hey Sami,
I have a GAT I and it's terrific. So would recommend GAT. But, didn't you say Jeff was using the ET7s2 in his system to demo the ART27A for you? That surprised me a bit but he may not have had a GAT on hand to use but it still says a lot for the ET7. You now know him so call and ask about the sound differences. He'll be absolutely truthful with you. The GAT may have some additional capabilities like extra inputs that the ET7 doesn't. And then it comes down to a budget decision. Good luck and have fun.
Best,
BobWilson Yvette speakers, [B]Conrad-Johnson [ART88 [B]pre, TEA1bc phono, and ART 27A Amplifier, Marantz digital player, Wireworld Gold and Platinum ICs, USB and power cables, Rega Planar 10 turntable/ Apheta cartridge, Wireworld Platimum Eclipse 8 speaker cables, AQ Hurricane and Tornado power cables, Shunyata Denali 6000S/V2, Sigma NR PC and DELTA USB cords, Symposium and Stillpoint vibration control, JL Audio Fathom 113 subwoofer, dCS Bartok Streamer/DAC
July 31, 2021, 10:49 AM #57
- Jul 2017
- zone7
- 27
Thank you, Bob,
I would call him ,decision is really about cost and sonic improvement as price is 13k VS 26.5K.
I am gravitating to idea of purchasing ET7A as i have listened to it with Aurrender N1 and it sounded almost Vinyl.No regrets here.ET7A is new model compared to GAT. it has single 6922 vs duo for Gat( double capacitors, resistors and other parts);some how,I thought you might have compared the two.
Thanks,
Sami
July 31, 2021, 11:27 AM #58
Hey Sami,
I suspect if you get the ET7A you will never look back. My GAT I is an early model so consideration to send it in for an upgrade has been on my mind for years. Some say that after the upgrade, they actually liked the sound of the I better than the II. I think we are splitting hairs now as they say. As a retired guy, for twice the price, the decision would be easy.
Enjoy,
July 31, 2021, 02:00 PM #59
If you're shopping for preamp, I would get a First Sound Presence Deluxe III-Si 4.0 rather than a ET7-S2. The First Sound is a better preamp, and for considerably less than $12K for an ET7-S2. As someone who has owned three C-J preamps over the last 12 years, yes, they're great, but the First Sound is completely on another level altogether. I used a CT-5 for 10 years and while's a very good sounding preamp, my First Sound pre makes it sound thin and 2-dimensional by comparison.
August 2, 2021, 01:25 PM #60
- Jul 2017
- zone7
- 27
August 2, 2021, 02:36 PM #61
The new nucleus one is introduced. For just 499 dollar you have a roon server. Does anyone already have experience with it?
Nucleus one
