Results 1 to 12 of 12
Thread: Phono Stage With XLR Output
March 9, 2019, 04:45 PM #1
Are there any distance limitations when connecting a phono stage to a line stage with XLR outputs on the phono stage?
I’m looking to rearrange my setup moving my turntable from in between my speakers. I’m also in the market for a phono stage. The distance between the two will be about 15 to 20 feet.
Is this distance acceptable without any loss or should I keep it short?Paul
Tape Deck Otari 5050B II2
Music Server: Aurender N100H
March 9, 2019, 05:18 PM #2
Re: Phono Stage With XLR Output
Balanced cables are designed for long runs- a hundred feet or more is common in the pro audio world where they have long been the standard.
Tom
Ultimate Audio
SoundLab Dealer
Country System:
SoundLab Ultimate-1PX Electrostatic Speakers
Pass Labs XP-32 pre, Pass Labs XA60.8 Amps
Pass Lab XP-27 phono stage
SME 20/2 table with SME V arm, Stillpoints LPI
Minus-K BM-8 passive vibration control under tt
Dynavector XV-1s, Koeitsu Rosewood Signature cartridges, Klaudio RCM
Roon Nucleus+ powered by Keces P-8 LPS
Lumin X-1 Network Music Player
3 dedicated AC lines
Shunyata Omega PC to Everest for all source devices
Typhon for each amp powered by 2 dedicated circuits
Various Shunyata Alpha & Sigma PC's throughout.
Stillpoints under everything.
City System:
Ayre KX-R Twenty Preamp
Pass Labs X-260.8 Monoblocks
Esoteric K-03 SACD Player
Roon Nucleus+powered by UpTone Audio JS-2 LPS
Sound Lab Ultimate-545PX Speakers
Shunyata Hydra 8, Typhon QR
Stillpoints under everything. Multiple room acoustic panels.
March 9, 2019, 06:16 PM #3
Paul
March 10, 2019, 11:53 AM #4
- May 2017
- Cleveland, Ohio, USA
- 530
Yes, from a powered balanced output stage, a balanced interconnect cable can run several hundred feet. And in on location pro audio this often happens.
But it's not just about the cable it's about the interconnect system.
Balanced output stage >> balanced interconnect cable >> balanced input stage.
May 21, 2019, 05:05 PM #5
May 21, 2019, 05:15 PM #6
Paul
May 21, 2019, 10:53 PM #7
Avanti Audio
May 21, 2019, 11:03 PM #8
- May 2013
- 3,242
Before Ralph re-opened this thread Paul had already purchased a Gold Note PH-10 which has both SE and Balanced outputs.
May 21, 2019, 11:05 PM #9Avanti Audio
May 21, 2019, 11:52 PM #10
With 2 V output or more from your stage to your pre no prob. From your TT to your stage you will get less performance l- low voltage.
Gesendet von iPad mit Tapatalk
May 22, 2019, 08:08 AM #11
- May 2017
- 530
The Audio Engineering Society 'AES48' standard is about how the cable shield is connected at both chassis ends. It's better known as the 'Pin 1 Problem'. It's true that some audiophile products still do it incorrectly, allowing increased noise end interference. The first 'Pin 1 Problem' engineering paper was published in 1994. It took over a decade for some pro audio equipment to get it correct and even now some audiophile equipment is still not on-board.
But it's far from the only circuit design problem.
Well designed line level interconnect systems should be good for up to 300 feet (100 meters).
May 22, 2019, 12:44 PM #12
The pin 1 problem was solved long before the mid 1990s- Ampex had that right in the mid 1950s. But
Here are the most common mistakes I see in high end:
1) the output of the circuit references ground from either pin 2 or pin 3. This causes the construction of the cable to be become critical for best sound- just like single-ended.
2) the output impedance is high- where the circuit should be able to drive 1,000 to 2,000 ohms I've seen some that can't drive anything less than 30Kohms! This has the same effect as in 1), and longer cables can be problematic.
I'm suffering issues with getting 1 boulder amp to talk to another boulder amp. I will agreed sound is pretty good.
Boulder 866 app
