March 31, 2019, 06:44 PM #51
Re: Q: Can anyone speak to the differences between LampizatOr GG and MSB Premier?
March 31, 2019, 06:45 PM #52
We all have had experiences good and bad on server stuff
almost home ok.
April 1, 2019, 04:56 AM #53
Reg the network plan you shared
what is a ps audio premier ?
same for power filter
did you setup on the output of your router feeding the network SW its own network ip addresses to ensure all traffic is just through the switch and only dhcp is used from the router ?
Then I can give advice and add on devices , I'm cheap so no need for exp stuff by me lol.TUBEZATOR
preamp ML26
amps ML No.33
Infinity IRS-V speakers with Xover redone by Arie Nudell.
April 1, 2019, 06:23 AM #54
The PS Audio Premier is a power re-generating amplifier (i.e. turns AC to DC, then rebuilds the AC waveform). Power filter is a passive power filtering device, also by PS Audio, but not sure the name off hand.
I have not done anything with the router or switch. Router plugs into cisco switch, then all other cables feed into switch.
Thanks.Room: 22' W x 26.5' L x 10' H. Constructed with double drywall with acoustic glue between sheets. Drywall isolated from studs and joists using IsoMax Isolation Clips.
Room Treatments: Mix of GIK Acoustics Bass Traps, 244 panels with scatter plates and 242 panels with scatter plates
Digital Files Handling: NAS -> Roonserver on CAPSv3 - i7 quad-core powered by Uptone Linear PS.
Power Conditioning: Equi=Tech 2RQ Balanced Isolation Transformer, PS Audio Premier.
Front End: MSB Reference DAC (Femto 77, Preamp Module, Renderv2)
Linestage: Thomas Mayer 10Y Silver
Amplifier: Thomas Mayer 45 drives 45 mono blocks
Speakers: Avantgarde Duo Mezzo XD
Video: Oppo BD-103 BR Player, JVC RS67U projector, 133" diagonal Da-Lite Cinema Contour Fixed Frame screen.
April 1, 2019, 06:33 AM #55
Ok ty for answers I like ps audio power products they work well. I use a P10 to power all of my front end
dsc / all computer and network and preamp
only not used for amps
for me no amp does well on there stuff and most iso cond as they limit power unless it's ten k watts or above. But that's for another topic
lps is good for all computers / nas / routers and sws
I'll be posting comments later and I'm not being an absolute person
here.TUBEZATOR
preamp ML26
amps ML No.33
April 1, 2019, 08:24 AM #56
Can you add Ona cheap lps to the network SW
and at the router make the one port have its own network address
meaning as below
now maybe 192.168.1.1 is the gateway
make new one on just that port
192.168.0.1. In doing so all audio traffic goes through your SW alone
a more simple way is to add a router after tour main one
it gets the lps and it should make its own network like I said above. But never use a router as a SW too there is too many other cammands being done all the Time. Where a SW just does traffic
this is what I do.
Just use its wan input from your current routers lan port
get all routers and sws to be gig band speed
meaning 10/100/1000.
Also all data cables leaving your audio network switch to be cat 7 shielded
mill explain why in next post.
Also mike if to worst to move this topic to its own if you wish. I'm happy to stay hereTUBEZATOR
preamp ML26
amps ML No.33
April 1, 2019, 08:36 AM #57
Cat 7 is rfi Shielded inside for each pair Separately and in addition it's then shielded
now unless we use a shield rj45 it's useless and even worse of used on both sides
but if we use a tiny wire on the computer side only one side to it's ground or case
this makes the shield even more effective in giving the desktop ground plain to own the data transmission.
Cat 7 alone yields a audible improvement
now don't buy data Cables on eBay or amazon they are most likely fake
by form known sources like BHPHOTO OR
usa bAsed makers
im not a paranoid Person but I have seen all fake no real for the most part on bay and amaz.
So be awareTUBEZATOR
preamp ML26
amps ML No.33
April 1, 2019, 08:56 AM #58
Cheap and real
https://www.bhphotovideo.com/c/produ...sstp_bare.htmlTUBEZATOR
preamp ML26
amps ML No.33
April 1, 2019, 05:29 PM #59
- Jan 2014
- Los Angeles
- 1,775
as for a server, highly recommend an Innuos to partner with the Ref. Then you don't need any of the doodads, filters, etc. Its pretty much plug n play. Not to mention it sounds fantastic.
Altaira or Gemini CGS on...
