Page 2 of 2 FirstFirst 12
Results 51 to 59 of 59
  1. #51
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,086
    Re: Q: Can anyone speak to the differences between LampizatOr GG and MSB Premier?
    Quote Originally Posted by Alrainbow View Post
    Lets all agree to move on it does no one good on either side and not Right to mike on his place. I submit a bow out lol.
    Mill be posting a marked up plan for data.
    Agreed. Both are excellent.
    I bet there’s more than a few other brands that wished they had such passionate owners!
  2. #52
    Senior Member
    Join Date
    Jan 2014
    USA , NYC
    Posts
    498
    We all have had experiences good and bad on server stuff
    almost home ok.
  3. #53
    Senior Member
    Join Date
    Jan 2014
    USA , NYC
    Posts
    498
    Reg the network plan you shared
    what is a ps audio premier ?
    same for power filter
    did you setup on the output of your router feeding the network SW its own network ip addresses to ensure all traffic is just through the switch and only dhcp is used from the router ?
    Then I can give advice and add on devices , I'm cheap so no need for exp stuff by me lol.
    TUBEZATOR
    preamp ML26
    amps ML No.33
    Infinity IRS-V speakers with Xover redone by Arie Nudell.
  4. #54
    Join Date
    May 2015
    Fort Wayne, IN
    Posts
    37
    The PS Audio Premier is a power re-generating amplifier (i.e. turns AC to DC, then rebuilds the AC waveform). Power filter is a passive power filtering device, also by PS Audio, but not sure the name off hand.
    I have not done anything with the router or switch. Router plugs into cisco switch, then all other cables feed into switch.
    Thanks.
    Room: 22' W x 26.5' L x 10' H. Constructed with double drywall with acoustic glue between sheets. Drywall isolated from studs and joists using IsoMax Isolation Clips.
    Room Treatments: Mix of GIK Acoustics Bass Traps, 244 panels with scatter plates and 242 panels with scatter plates
    Digital Files Handling: NAS -> Roonserver on CAPSv3 - i7 quad-core powered by Uptone Linear PS.
    Power Conditioning: Equi=Tech 2RQ Balanced Isolation Transformer, PS Audio Premier.
    Front End: MSB Reference DAC (Femto 77, Preamp Module, Renderv2)
    Linestage: Thomas Mayer 10Y Silver
    Amplifier: Thomas Mayer 45 drives 45 mono blocks
    Speakers: Avantgarde Duo Mezzo XD
    Video: Oppo BD-103 BR Player, JVC RS67U projector, 133" diagonal Da-Lite Cinema Contour Fixed Frame screen.
  5. #55
    Senior Member
    Join Date
    Jan 2014
    USA , NYC
    Posts
    498
    Ok ty for answers I like ps audio power products they work well. I use a P10 to power all of my front end
    dsc / all computer and network and preamp
    only not used for amps
    for me no amp does well on there stuff and most iso cond as they limit power unless it's ten k watts or above. But that's for another topic
    lps is good for all computers / nas / routers and sws
    I'll be posting comments later and I'm not being an absolute person
    here.
    TUBEZATOR
    preamp ML26
    amps ML No.33
  6. #56
    Senior Member
    Join Date
    Jan 2014
    USA , NYC
    Posts
    498
    Can you add Ona cheap lps to the network SW
    and at the router make the one port have its own network address
    meaning as below
    now maybe 192.168.1.1 is the gateway
    make new one on just that port
    192.168.0.1. In doing so all audio traffic goes through your SW alone
    a more simple way is to add a router after tour main one
    it gets the lps and it should make its own network like I said above. But never use a router as a SW too there is too many other cammands being done all the Time. Where a SW just does traffic
    this is what I do.
    Just use its wan input from your current routers lan port
    get all routers and sws to be gig band speed
    meaning 10/100/1000.
    Also all data cables leaving your audio network switch to be cat 7 shielded
    mill explain why in next post.
    Also mike if to worst to move this topic to its own if you wish. I'm happy to stay here
    TUBEZATOR
    preamp ML26
    amps ML No.33
  7. #57
    Senior Member
    Join Date
    Jan 2014
    USA , NYC
    Posts
    498
    Cat 7 is rfi Shielded inside for each pair Separately and in addition it's then shielded
    now unless we use a shield rj45 it's useless and even worse of used on both sides
    but if we use a tiny wire on the computer side only one side to it's ground or case
    this makes the shield even more effective in giving the desktop ground plain to own the data transmission.
    Cat 7 alone yields a audible improvement
    now don't buy data Cables on eBay or amazon they are most likely fake
    by form known sources like BHPHOTO OR
    usa bAsed makers
    im not a paranoid Person but I have seen all fake no real for the most part on bay and amaz.
    So be aware
    TUBEZATOR
    preamp ML26
    amps ML No.33
  8. #58
    Senior Member
    Join Date
    Jan 2014
    USA , NYC
    Posts
    498
    TUBEZATOR
    preamp ML26
    amps ML No.33
  9. #59
    Senior Member
    Join Date
    Jan 2014
    Los Angeles
    Posts
    1,775
    as for a server, highly recommend an Innuos to partner with the Ref. Then you don't need any of the doodads, filters, etc. Its pretty much plug n play. Not to mention it sounds fantastic.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
