Results 1 to 29 of 29
February 18, 2019, 11:46 AM #1
Please recommend a USB cable that won’t break the bank ...
What are you using and have you made comparisons of different brands?
I hate to admit that cables do matter, but I’d like to keep it reasonable.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
February 18, 2019, 12:14 PM #2
- Apr 2015
- 54
Re: Please recommend a USB cable that won’t break the bank ...
Have a look here: https://www.audiosciencereview.com/f...sb-cable.6599/
At least there is a measurable difference
February 18, 2019, 12:19 PM #3
+1 ... as a place to start and under the assumption that the manufacturer provided usb cable from T+A is perhaps not an "audiophile cable" but nonetheless is a quality cable, i am currently using the one provided with the dac 8 dsd. i am quite happy with the SQ of my digital front end and in no hurry to "upgrade" the usb cable. i have done no A/B comparisons.
viking acoustics berlin r mk2 | almarro a318b + air tight atc-5 (phono) | clearaudio concept + virtuoso v2 MM | t+a dac8 dsd + diy transport + roon rock
February 18, 2019, 12:28 PM #4
- Feb 2019
- Metro Detroit
- 10
Or, something a little different
Phasure Lush^2 USB Cable
(damn can't post links yet )Analog: modded Yamaha PX-2, Denon DL-103r, MFA Magus preamp, Mogami/Vampire/DIY cables
Digital: Firewire ext. HDD, modded Mac Mini server, Intona/Regen/Curious USB chain, (3x)ultralow noise LPSUs
2-channel: Benchmark DAC2 HGC, Crown XLS2500, Acoustat Spectra 3300, (2x)Velodyne 12" servo subs
Other: OPPO BDP-103, DIY and Nordost Blue Heaven cables, all speakers and gear floated on DIY rollerblocks
February 18, 2019, 12:30 PM #5
Lots of people may consider things reasonable and others consider them not reasonable. I have 4 systems with USB cables (and a few spare cheaper ones). If $350 is reasonable, the Curious USB is good for the money.
February 18, 2019, 12:58 PM #6
NORMAN
February 18, 2019, 01:03 PM #7
I have the Curious USB, Audioquest Carbon, Wireworld Starlight 3.0, Belkin Gold Hi-Speed, whats in my system working is the Belkin. I could not hear any difference using the others.
February 18, 2019, 01:12 PM #8
- Nov 2013
- Minnesota
- 1,369
Wire World Platinum and never look back! It will set you back about $600. Joe, usb cables are system dependent as are all cables. You may or may not hear a difference. It probably has to do with the usb implementation and power supply on your DAC.
We did a shoot out of cables in my system last year. We used a WW Platinum and Lightspeed both $600 cables, a WW Starlight Red 7 and a cheap Pangea cable. They sounded dramatically different. the WWP sounded the best with the Red coming in second. The LS next but it was way too bright sounding. However, it had the most detail and resolution. The Pangea sounded too bright, weak and thin without any depth.
The WWP was detailed, smooth, neutral and natural sounding. The WW Red however, sounded veiled in comparison and was warmer and darker.
Interestingly, when we used my Regen, it greatly closed the gap between the WWP and Red. The Red lost its veil and had more detail but still had just a hint of warmth and darkness. The LS still sounded bright but less so and there was no help for the Pangea although the sound did improve some.
Another interesting fact is that the guy that owns the WWP and LS prefers the LS in his system with a Hugo Chord and T+A DAC8. The LS does not sound bright in his system. Go figure.
My advice, rent different USB cables from the www.cableco.com and see what you like. You can take home up to 5 cables with a deposit.
LarryMy Gear- Mains System-Pass X250 amp, BAT VK-51se preamp, Luxman DA-06 DAC, Magnepan 1.6's, Thorens TD-145 TT, Dual Martin Logan Subs, Vintage Luxman T-110 Tuner, Cables-WW Platinum 7 USB, Cardas Parsec XLR, AQ Columbia DBS 72v XLR, Belden 8402 XLR.
February 18, 2019, 02:27 PM #9
- Feb 2016
- west Michigan
- 713
Tried several, in my rig Dana cable was smooth yet detailed without glare.
Curious cable was a bit more organic sounding (think Harbeth).My System
Acoustic Revive RTP-4
Innuos Pulsar
Lampizator BALTIC4
Cary SLP-05
Pass XA30.5 or
Line Magnetic 845ia
Reference 3A Reflector's
Pr SVS SB3000 Subs
Core Audio Design Rack
February 18, 2019, 02:33 PM #10
https://www.ghentaudio.com/part/dc-gac4.html. Their Gothem quad cable is very nice. I like options on length and how you want each end terminated.
NickNick
Main system :TAD CR1 speakers, Viola Labs Symphony amp,Pass XP-20 preamp., MSB Discrete DAC with twin power supplies and V2 Renderer module, Gigafoil V4 inline ethernet filter with uptone LPS-1 power supply with Ghent audio Gotham 2.1mm to 2.5mm cable and AG diamond ethernet cable, Sonicorbitor Roon Audiophile 6 TB network server-player , MG Audio Design Planus III jumpers & speaker cables, Zitron Cobra power cords, Shunyata Hydra AV, and acoustic zen absolute copper IC,. Room treatment ASC tower traps, Vicoustic absorber premium cinema wall and ceiling panels, and MSR acoustic trifusser side wall panel
February 18, 2019, 02:53 PM #11
I have a Curious and it works for me. Although USB is currently only used for Netflix streaming. Next USB cable might be an AQ Diamond - despite the $$$ - due to very positive experiences with their Ethernet cables.
In my system I prefer Ethernet for its sonic advantages.
February 18, 2019, 03:35 PM #12
- Nov 2013
- St. Louis, MO, USA
- 3,068
I have limited experience with USB but if I were looking and not wanting to spend a fortune it would be Analysis-Plus. Wire World would be on my list as well. Some reviews of WW say the sound is very good, detailed but seems to make the sound stage smaller. Whatever, that means, just could be lack of distortions. WW is typically more expensive than A+ in similar levels.
I went with Clarus due to being able to try first but really have a fondness for A+'s ability to improvement sound while keeping a very natural presentation.Aurender ACS10 w/Audioquest Diamond USB, Esoteric N05xd
SVS PC13 Ultra
Sony XBR-75X940D & BDP
February 18, 2019, 03:38 PM #13
Final touch Audio -Callisto is the best I ever heard. Cost is circa $800. Phasure lush is very good and not too expensive.
edit...300 was a typo.NORMAN
February 18, 2019, 06:34 PM #14
February 18, 2019, 06:58 PM #15
I use two Audio Quest Coffee cables (I need two because I run the USB through a W4S Recovery). I do have a set of lower range Wireworld that I am current not using if you want something better than what manufactures provide that will not break the bank.
― Neil deGrasse Tyson
February 18, 2019, 07:56 PM #16
- Nov 2013
- Minnesota
- 1,369
February 18, 2019, 08:10 PM #17
NORMAN
February 18, 2019, 09:34 PM #18
Sorry guys, been too busy to respond. I need to see what’s been said.
February 18, 2019, 10:33 PM #19
Joe. When I was helping MarkJones at the show. The president from Tenor audio came in the room and he wasn’t happy about the sound of digital and he pulled out the AQ Diamond USB. We connected it and bam I could hear the difference instantly.
Ofcoz later that day I purchased it and it’s been in my system for last 2 years. .
February 18, 2019, 10:44 PM #20
I agree with Paul, the AQ Diamond is superb, so is the Shunyata Sigma NR and Curious USB.
February 18, 2019, 10:59 PM #21
- May 2013
- 3,242
Joe
Here's another option and Pete may have one at the shop broken in since he cabled three rooms at the show last week.
https://www.triodewirelabs.com/produ...ete-usb-cable/Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
February 18, 2019, 11:55 PM #22
February 24, 2019, 01:02 PM #23
https://www.finaltouchaudio.com/
rhey make usb Cables and interconnects too. The usb is great and comes in power and non power.TUBEZATOR
preamp ML26
amps ML No.33
Infinity IRS-V speakers with Xover redone by Arie Nudell.
March 2, 2019, 01:59 PM #24
AQ Diamond...
Triangle Magellan Concerto 2 < AQ Everest < Vitus Audio SS-010 Mk2 < AQ Dragon HC < AQ WEL Signature XLR < Chord Qutest w UpTone JS-2 & AQ Dragon Source < SOtM tX-USBultra w 75Ohm Master Clock Input, Paul Hynes SR5-12 Turbo XL & AQ Dragon Source < AQ Diamond USB < Aurender N-100H w AQ Dragon Source < Gryphon PowerZone w AQ NRG-Wild < Solid Tech Hybrid < Ansuz Darkz D-TC, Darkz D2, Stillpoints Ultra SS, Omicron Harmonic Stabilizer & Gold SE < Furutech FT-SWS < Synergistic Research Blue Quantum Fuse
March 2, 2019, 02:01 PM #25
I had that cable too it's a good one
TUBEZATOR
preamp ML26
amps ML No.33
March 3, 2019, 09:11 AM #26
Curious REGEN link from a WW platinum.
Marty
MSB Premier
PS Audio Powerplant 15
March 3, 2019, 04:34 PM #27
Joe, I have used a WireWorld Platinum Starlight and it was a step up from what I was using. Now I am interested in the newest Shunyata Alpha USB as their ALPHA Clock 75 was significantly better than the WireWorld Gold Starlight it replaced. I think Shunyata has found something.
Main Equipment: Kharma Elegance dB11-S, JL Audio F113v2, Block Audio Line & Mono SE Amplification, Bricasti M21 DAC, Antipodes Kala K-50 Server, ClearAudio Performance SE, Satisfy Arm & Maestro Wood MM Cartridge
Power: 3 x 20 Amp Lines, Shunyata Everest 8000, Sigma XC v2, Shunyata Sigma v2 NR, Block Audio Power Cords, Defender, ADDPowr Wizard
Grounding: Shunyata Altaira CGS - Alpha CGS cables
Network : Supra Cat 8+, Twin (Nenon Modified) Buffalo GS2016 Switches powered with Keces P3 LPSU,
Cables: Wireworld Platinum Starlight 8 USB, Wireworld Platinum Eclipse 8 SCs, 1M & 6M Tubulus Concentus ICs,
Other: Isoacoustics GAIA I footers on the Kharmas, GIK/Vicoustics/Stillpoint Apertures, Stillpoint Ultra SS, Furutech GTX - Gold outlets, Adona Rack
March 4, 2019, 08:56 PM #28
Shunyata Alpha USB at $1K I believe. SIGMA USB one level above at a higher price of course. Anyone who's tried the new Shunyata USBs is saying great things...
Legacy Audio Valor+Wavelet v2, Esoteric S-02 Amps HDPlex 300W, RevAudio Labs DC Umbilical, Esoteric Grandioso P1, P1PSU & dual D1 DACs, Cybershaft Prem Ltd OP21A 10 MHz Clock, Esoteric C-02X, Shunyata Everest 8000 & Altaira SG-NR hubs, Sigma SGC/CGC ground cables, VTX-Ag ground tails, AfterBurner8 duplexes, CSP Inc Q4B, S2B IEC plates, Shunyata Omega CLOCK-50 cables, Tubulus Concentus HDMI, Elrod Master Series Diamond SE & Masters Series Gold Power cords and Statement Gold XLRs, Diamond XLRs & Master Series Diamond XLRs, Shunyata OMEGA QR-s power cable, Anaconda Z-tron XLR, Elrod Statement Gold speaker cables, Adona Zero GX3, GX2, GX racks, Composite Audio CF-2010, Townshend Audio Podiums, HRS DPX Damping Plates, Stillpoints Ultra SS w/Ultra Bases, pArtScience 64-well, 2D QRD 3-inch SpaceArray Diffusors
Travel/Rip: Apple MacBook Pro 16” 2023 M2 Max, 12-core CPU, 38-core GPU, 32 GB RAM, 1 TB SSD for Audirvana+ v3, iTunes, REW Audio Analyzer, dbPowerAmp, DVD Audio Extractor
March 4, 2019, 09:21 PM #29
