Page 2 of 3 FirstFirst 123 LastLast
Results 51 to 100 of 101
  1. #51
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    Re: New MSB S500 and M500 Amplifiers
    Quote Originally Posted by audio.bill View Post
    An update on the M500 amps driving Magico M6 speakers, including pricing from Stereophile in Munich.
    Positive mini review by JVS and impressive looks and specs. Pricing to match the Select and Reference DACs. M500 MSRP = $118,500; S500 MSRP = $58,500.
    Ken
  2. #52
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    After running all day, these amps ran barely above room temperature. Just an FYI.
    To me, they have no identifiable sound characteristic, not warm, not sweet, no dry, not.....other than dynamic as all hell with their over 1,000,000 microfarad capacitors and the blackest backgrounds you can imagine. It is kind of spooky. The music just appears from no where. Dead freaking quiet. The sound of the DAC comes through brilliantly. You simply, just hear the music.
  3. #53
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    Thanks Mike,
    How would characterize the overall sound you’re hearing from the S2/M500/M6 system? Could you compare/contrast it to the S2/M204/M3 system you listened to at Axpona this year?
    Ken
  4. #54
    What classes up to what output do they run in?
  5. #55
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Quote Originally Posted by Alpinist View Post
    Thanks Mike,
    Ken
    The 204’s were very warm - in sound and output of heat. These new amazing amps are purely natural. Neutral isn’t the right word. They’re NATURAL. Dynamic as hell and the music just appears from no where. Blackest backgrounds I’ve ever heard.
  6. #56
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    Quote Originally Posted by Kingsrule View Post
    Hi King,
    The M500’s and M204’s (Discontinued) input stage is Class A and its output stage is Class A/B. I’ve asked MSB many times how many watts the M500’s and M204’s run in Class A and they do not measure it. The M500’s power consumption at idle is 150 watts per mono amp, while the M204’s power consumption at idle in the high bias mode is 280 watts per mono amp. So I believe the M204’s may run nearly twice as many watts in Class A as the M500’s. The M500’s are zero negative feedback judging by their Total Harmonic Distortion measurements.
    Best,
    Ken
  7. #57
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Asked and told by the designers “that’s not an official spec.” There is no actual way to measure it, only estimate based on calculations. It has a class A input stage. I would GUESS (this is just me), that is 5-20 watts at most. The amps run VERY cool.
  8. #58
    Not much elaboration so far on the impedance-matching and gain-setting alternatives. Would the s500 actually be viable for high-eff speakers?
    Parker
  9. #59
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Quote Originally Posted by pdub View Post
    Parker
    Yes. Absolutely. I posted a pic of the different settings.
  10. #60
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    M500/S500 Adjustable Settings:
    Gain:
    Low Gain (75 ohm input) = 14.8 dB
    Medium Gain (75 ohm input) = 20.8 dB
    High Gain (75 ohm input) = 26.8 dB
    Input Impedance:
    75 ohm
    300 ohm
    1,200 ohm
    Ken
  11. #61
    I know flea-watt fans differ, but one of the pitfalls of owning high-eff speakers, which are niche, is feeling like one is limited to low wattage amps, also niche. Having amps that can also play with any other speakers that happen to wander into the house can help defray the costs of swapping around gear.
    Parker
  12. #62
    Cool running is a red flag for me...I have never heard a SS amp that runs cool sound good....like Soulution 511
  13. #63
    Thanks Ken. I've seen the specs. I just wonder if Vince can comment yet on any particular brands or types of speakers they've happily driven given these possible permutations.
  14. #64
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    Hi King,
    I don’t think they exactly run cool. They put out 150 watts of heat at idle per amp. However, the heat sinks have a very large surface area, so I would suspect they do not feel very warm, which matches with what Mike is reporting.
    I look forward to hearing them in person.
    Ken
  15. #65
    Good point
  16. #66
    Junior Member
    Join Date
    Jan 2014
    Hong Kong
    Posts
    3
    There isn’t enough space for the M500 amps in my current setup - it’s likely others are on the same boat. A new M300 series of amps would be nice products for MSB to add ! :-)
  17. #67
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Quote Originally Posted by jhsu View Post
    Their footprint isn’t really super large. Substantial, but not ridiculously so.
  18. #68
    Senior Member
    Join Date
    Mar 2017
    North Carolina
    Posts
    811
    Mike, are these plugged directly into the wall or into somebody's (?) conditioner?
  19. #69
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Quote Originally Posted by GSOphile View Post
    Wall
  20. #70
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    MSB S500 in the house!
  21. #71
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    Holy crap! Congrats!!! I didn’t know you were getting the S500. Now I’ll have to stop down at your store. In the meantime, I want a full report once they’re broken in.
    Thanks,
    Ken
  22. #72
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    I’ve been listening to this amp all day. The amp sounds exactly like the Select II DAC from MSB. Musical, full with delightful black backgrounds (one of the best SN ratios I’ve seen at 134db) and so natural with no hint of coloration. The amp has incredible transients. It’s dynamic with outstanding bass control. The amp never runs out of gas, never compresses and never changes it’s sonic character, no matter how hard I push it.
    Have a listen...
    https://youtu.be/UVbQ3f0QNjQ
  23. #73
    Senior Member
    Join Date
    Sep 2017
    Seattle
    Posts
    1,964
    So MSB DAC into the MSB amp, add a Phono and your done?
    Speakers: Wilson Alexias
  24. #74
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Quote Originally Posted by UltraFast69 View Post
    Yes indeed!
  25. #75
    Senior Member
    Join Date
    Jul 2013
    Florida
    Posts
    3,848
    Mike - You have quite a selection of amps in the store. Can’t wait to hear the new MSB amp.
    _______________
    Phono Pre: Pass XP-27
    Speakers: MBL 101E MKII
    Rack: Artesania Exoteryc
  26. #76
    Have a listen...
    Superb Mike, congrats!
  27. #77
    Sounds like it. Very nice.
  28. #78
    Senior Member
    Join Date
    Jul 2014
    Tampa FL
    Posts
    301
    Mike,
    What settings for gain and input impedance did you select with an MSB DAC input and why?
    Cincy
    Wadax Reference DAC and Server
    CH Precision L10 PreAmp
    CH Precision M10 Amplifier
    Rockport Orion speakers
    Nordost ODIN 2 speaker cables and interconnects
    StromTank 2500 Power Supply
    Shunyata Sigma QR power cords
    Shunyata Everest power conditioner
    Vicoustics Room Treatments
  29. #79
    Senior Member
    Join Date
    Aug 2014
    east of Seattle
    Posts
    821
    very nice Mike!
    that is one amp i can't wait to hear. i'm sure it's a perfect match with the Select II.
    i look forward to when you have enough time with it to contrast it with some other amps you have.
  30. #80
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Quote Originally Posted by Cincy2 View Post
    Mike,
    Cincy
    You have to use the 75ohm setting. I have the gain at high. Haven't played much with the gain. I find myself listening in the 70's on the VC and 80 is very loud in the 20 x 25 room that's open. It's absolutely perfect for the MSB DAC's. The amp sounds like the Select II DAC. Period. That's the review of this amp in a nutshell.
  31. #81
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Quote Originally Posted by Mike Lavigne View Post
    very nice Mike!
    Thanks Mike. With the MSB DAC's, it's the best match hands down compared to anything we've tried. Like I said above, the amp completely sounds like the Select II.
  32. #82
    Junior Member
    Join Date
    Sep 2019
    Hong Kong
    Posts
    21
    I listened to M500 directly connected with Select DAC in 2 systems.
    For both of them I liked the middle gain more.
    The volume of the Select was in the 70+.
  33. #83
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Welcome!
  34. #84
    I wonder what is the sonic difference between the stereoamp and the monoblocks. One costing one-half of the other, but with practically the same power specs on paper. wondering has anyone compared the two side by side?
    Regards
  35. #85
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Quote Originally Posted by Alectiong View Post
    Regards
    The monos gave a great sense of ease and seemed ready to pounce dynamically at a moments notice. Soundstage was also bigger with the monos. I tried to detect whether the stereo might have a different tonal presentation, but really couldn’t detect any.
  36. #86
    Thanks. That sounds familiar to when I upgraded my Vitus SS103 to the monoblocks SM103. Even though in hindsight it wasn’t really necessary for my room size and speakers.
  37. #87
    To all friends using the MSB 500, how long did it take you to run them in?
    I just took delivery of my Select and the M500, and burning them in. The Select drives the M500 directly.
    At this time after 1 day of playing, they sound a bit soft, or should I say lacking in weight in the mid band.
    My previous amplification was the Vitus MPS and MPL.
    Regards
  38. #88
    Senior Member
    Join Date
    Jul 2014
    Tampa FL
    Posts
    301
    Regards
    I am operating the same set up you have. I ran my M500's for three days 24 hrs / day at low volume and found that they settled in nicely. I have not experienced the sonic issue you describe.
    Cincy
  39. #89
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    Regards
    Congrats on the Select DAC and M500 monoblocks! What speakers do you have for this wonderful system?
    Ken
  40. #90
    Cincy
    Thanks for sharing your experience. I replaced my M500's footers with those huge Stillpoint SS5 footers. Will go back to the stock footers next week if the issue persists, and see if the Stillpoints caused it.
    Regards
  41. #91
    Ken
    Ken, thanks for compliments. I use Rockport Cyngus.
    Regards
  42. #92
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    Regards
    Excellent speakers! That’s a world class system you have put together.
    Enjoy,
    Ken
  43. #93
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    Regards
    MSB just came out with brand new amp footers that are supposed to be superior to the stock footers. I would suggest ordering these if you don’t already have them.
    Ken
    The Viton Tri-Foot and S202 gallery update - MSB Technology
  44. #94
    Ken
    That news hadn't come out yet a few months ago. That's why I ordered the Stillpoints. Stillpoints had worked well with my Vitus Amp. but maybe not this time with MSB amps. Will see. Will try the MSB amp footers when they become available. My Select DAC and transport did come with the new footers.
    Regards,
  45. #95
    Regards
    What u are describing about the sound of your M500's is exactly what I have heard with those Stillpoint footers...therein lies your problem...
    "We all know real when we hear it"
  46. #96
    After 3 days of continuous burn in, the sound has settled in significantly and blossomed. The mid band still sounds a bit soft/recessed to my ears. The Stillpoint remains a conjecture till I have more hours on the burn in. The isolation devices are often a hit and miss thing, giving you some sonics benefits but can take away others.
    Regards
  47. #97
    Here is photo of my MSB set up. The amps are on the Stilpoints. I have a ceramic tile floor which has proven to be not so good for all my previous mono amps.
  48. #98
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    Beautiful system and a very efficient use of space. Just one question, why not place one amp on either side of the DAC and Transport?
    Best,
    Ken
  49. #99
    Best,
    Ken
    Thanks for compliment Ken. I am constrained by the length of my power cords and the position of the wall outlets needed to do it. Didn't want to have an electrician in to reposition the outlets, or get a power distributor for my sources components. Hence, this layout is the best I can manage for now.
    Regards
  50. #100
    Nice clean setup.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
