Results 251 to 292 of 292
Thread: Lumin T2
October 11, 2019, 11:42 AM #251
- May 2019
- CA
- 48
October 11, 2019, 12:01 PM #252
- Sep 2019
- U.S.
- 42
Re: Lumin T2
Does the auralic lightning ds app have the filters built in or is it the hardware?
October 11, 2019, 12:24 PM #253
- May 2019
- CA
- 48
Re: Lumin T2
Borresen 02, Virtus RI-101, Ansuz A2 loom
October 11, 2019, 01:31 PM #254
Re: Lumin T2
Right. When the possibility of filter choice has been brought up, none of our decision makers think that suits our philosophy of SQ and avoidance of options that are really hard to explain.
Peter Lie
LUMIN Firmware Lead
October 11, 2019, 05:24 PM #255
- Sep 2019
- U.S.
- 42
Re: Lumin T2
Nut in yhe case of auralic lightning, there are only four choices. People listen and make a choice. So nothing to understand, it's really just what sounds better. Most people and reviewers seem to like the options and simply make a choice.
October 11, 2019, 05:32 PM #256
- May 2013
- 3,242
Re: Lumin T2
The "choices" you refer to in Lightning DS are nothing more than the options in the ESS Sabre chipsets they were using. Some manufacturers choose to enable them and some don't. The differences between them are minor to my ears.
October 13, 2019, 08:58 PM #257
- Sep 2019
- U.S.
- 42
Re: Lumin T2
What sound qualty affect does upsampling have? Does it roll off the highs? Make a system sound less bright or less harsh?
October 15, 2019, 12:01 PM #258
- Sep 2019
- U.S.
- 42
Re: Lumin T2
Newbie here. If I want to listen to all the songs in a Tidal playlist in the Apple Lumin app, what is the best way to do that? Is there one button I can press just to play them all in a row? The only thing I have seen so far is that I have to add them to the Lumin play list one by one. One click to play the entire play list would be great. Thanks.
October 15, 2019, 12:04 PM #259
- Jan 2014
- 152
Re: Lumin T2
If you get to the point where you can see the playlist cover (i.e. the image that represents the playlist - usually one level above the songs) then you can press and hold the image and add that whole thing to the LUMIN Playlist that way.
Same with albums, etc.[Associated with LUMIN]
October 15, 2019, 12:58 PM #260
- Sep 2019
- U.S.
- 42
Re: Lumin T2
Thanks!
October 23, 2019, 10:59 AM #261
- Oct 2019
- NYC
- 2
Re: Lumin T2
Is it OK to use both the balanced and single ended outputs of a T2, not at the same time? I am using the balanced outputs to my preamp at the moment. Is it OK to connect a headphone amp to the single ended outputs too. I won’t be using both at the same time. I will only listen to either speakers or headphones. Thanks.
October 23, 2019, 10:13 PM #262
Re: Lumin T2
Welcome to the forum.
October 23, 2019, 10:27 PM #263
Re: Lumin T2
OK for Lumin T2, although we generally recommend not connecting both types of analog outputs at the same time.
Peter Lie
LUMIN Firmware Lead
October 24, 2019, 09:04 AM #264
- Oct 2019
- NYC
- 2
Re: Lumin T2
Thanks for the response peter. Is that because of sound quality degradation? Will the T2 see both loads if only one of the devices connected is powered on at one time?
October 24, 2019, 10:41 AM #265
Re: Lumin T2
SQ degradation from simultaneous connection of XLR and RCA outputs mostly affect models with Lundahl output transformers. For T2 / D2 / D1, SQ degradation should be minimal if not negligible when only one is active. Please do not worry about it.
Peter Lie
LUMIN Firmware Lead
November 9, 2019, 03:10 PM #266
- Apr 2018
- Las Vegas
- 77
Re: Lumin T2
Peter,
What are the changes made in this latest firmware upgrade?Jonathan
_______________________
Age is a mental construct.
System: Theta Casablanca V preamp/processor/DAC; Wadia 8 transport; Wadia 2000 DAC; Theta Compli SACD transport; Lumin T2 streamer/DAC; Roon Nucleus+; Luxul AGS-1024 switch; SOTA Sapphire turntable w/Premier FT3 arm & Hana SL cartridge; PS Audio Stellar phono preamp; SweetVinyl SC-2 noise/click remover; Oppo 203 4K player; Magnum Dynalab FT-101A tuner; McIntosh MC611 mono amplifiers (3); Revel Ultima Studio/ Voice/Embrace speakers (L/C/R and sides); Arendal 1723 speakers (surrounds); SVS SB-16 (2) and 3000 Micro (2) subwoofers; Stax SR-L300 headphones; TeddyPardo 19/3 linear power supply; Richard Gray's Substation; Shunyata 6000/S, 2000/T (2), Venom PS10, Hydra (2), and Defender (2) power conditioners; Wireworld Silver Eclipse 8 speaker cables; Audioquest, Cardas, Kimber Kable, MIT, and Wireworld interconnects; Cullen, and Shunyata power cords.
JVC RS 3100 projector; MadVR Envy Extreme II video processor.
November 10, 2019, 06:15 AM #267
Re: Lumin T2
AirPlay improvement
Peter Lie
LUMIN Firmware Lead
December 6, 2019, 02:59 PM #268
- Apr 2017
- Norway
- 58
Re: Lumin T2
Hello
Anyone Moved up from D1 to T2, i am wondering to doe that after several years whit D1 and super happy about this but now i think its time to go further . What can i expect ? . Uses Kennet Lau powersuply on the D1 that make a big differens.
December 6, 2019, 06:32 PM #269
- Apr 2018
- Las Vegas
- 77
Re: Lumin T2
The T2 is my first streamer/DAC, and so I can’t offer any comparative observations. That said, I can say that streaming has now eclipsed both vinyl and CD/SACD as my preferred music source. Why? For me, it is the lifelike clarity, combined with fabulously articulated deep bass, evidenced in most every recording. I want to highlight the quality of the T2’s digital to analog conversion. I have the ability to decode the audio stream using two other high end DACS — one being Wadia’s best and the other the Theta Casablanca
Jonathan
December 6, 2019, 07:15 PM #270
Re: Lumin T2
The T2 is the sweet spot in the line and offers a big performance over a D1. More layering. Much more solid of a foundation. Better separation. A big jump.
December 7, 2019, 08:42 PM #271
- Nov 2019
- USA
- 4
Re: Lumin T2
Anyway to disable the track counter / history from the display when using the Lumin app?
December 10, 2019, 03:28 PM #272
- Nov 2019
- USA
- 4
Re: Lumin T2
Is there a way to disable the track/track history counter from the display when using the Lumin App?
December 12, 2019, 05:49 PM #273
- Apr 2017
- Norway
- 58
Re: Lumin T2
Thanks for reply, i have now tested the T1 for two days, and i tok me just 2 songs before i orders one for my self. so yes it was a difference :-)
December 12, 2019, 05:55 PM #274My Systems: http://www.audioshark.org/showthread...481#post158481
December 12, 2019, 07:15 PM #275
- Jul 2017
- Israel
- 56
Re: Lumin T2
Did anyone compared and can measure or describe the differences between the T2 (with or without a Sbooster upgrade) ?
I have the T2 for six months and like Mike mentioned is superb in SQ and seems to be the sweet spot of the Lumin line...
December 13, 2019, 11:46 PM #276
December 22, 2019, 12:29 AM #277
- Nov 2019
- USA
- 4
Re: Lumin T2
Any chance of adding the Tidal "Top Tracks" feature to the Lumin app?
December 22, 2019, 12:42 AM #278
- May 2013
- 3,242
Re: Lumin T2
They can only add features that are included in the Services API they are provided. That will never include all the features found in the Desktop app.
December 22, 2019, 12:50 AM #279
- Nov 2019
- USA
- 4
Re: Lumin T2
Bummer... Roon can't do it either... At least not correctly. I only know of one app that can... USB Audio Pro.
December 23, 2019, 04:17 PM #280
- Nov 2019
- USA
- 44
Re: Lumin T2
The apps “mconnect Player” and “mconnect Player HD” (for iOS), and BluOS apps for Bluesound devices, all use a TIDAL API that supports Top Tracks for artists. Hopefully Lumin gets that updated API soon. The mconnect apps also have MY Mix playlists after a recent update, so that’s in the API too. Qobuz integration in mconnect is very good as well.
@Litlgi74 if you have an iOS device, maybe give mconnect Player a try (it works with Lumin via UPnP/DLNA). The paid version is what I’ve been using (I don’t know if the free version has these updates). I think they have Android versions too but I have not used them.
February 13, 2020, 12:05 PM #281
- Feb 2020
- Nieuwegein
- 11
Re: Lumin T2
I run a hegel h390 amp with a nuc core with Roon. The hegel is not roon endpoint ready. I can buy a lumin t2 with a discount. Will the lumin t2 will be an upgrade to the internal one in the h390??? Any thoughts?
February 13, 2020, 12:31 PM #282
- Feb 2020
- Nieuwegein
- 11
Re: Lumin T2
I run a hegel h390 amplifier with a nuc Roon core. The hegel is not roon ready yet so I am looking around for an streamer/dac. Will the lumin t2 will a big upgrade to the internal dac/ streamer? Does anyone did a comparison or compared the lumin t2 to the hegel hd30?
February 19, 2020, 01:23 PM #283
- Jan 2020
- Netherlands
- 21
Re: Lumin T2
I have the same issue with my Mcintosh MA8900. I have a Lumin T2 in order to audition it at home. It is the best way to find out.
Mcintosh MA8900 || Sonus Faber Olympica Nova III || Taga Harmony Platinum 18-16C || X-odos Stream Pro || AudioQuest Niagara 1200 || Thunder Silent Angel N8
February 19, 2020, 02:07 PM #284
Re: Lumin T2
Flemming
Lumin X1
Rotel Michi S5
Focus Audio FS788
LS cable : Yter
Nordost QB8
Rack : Finite Elemente Pagode
February 19, 2020, 03:20 PM #285
- Feb 2020
- Nieuwegein
- 11
April 4, 2020, 05:00 PM #286
- Jan 2018
- 5
Re: Lumin T2
My T2 sounds great but I have an unusual problem. The display will illuminate at various times with no action by me. The song indicator does not progress (good). The T2 display eventually turns off on its own.
Not a big issue but is there a fix ?
Thanks
April 4, 2020, 06:20 PM #287
- Feb 2020
- New england
- 2
April 4, 2020, 07:03 PM #288
- Apr 2018
- Las Vegas
- 77
Re: Lumin T2
May I suggest that you power down your T2, then disconnect the T2 from your wall plug or power conditioner, disconnect the Ethernet connection, power down your Ethernet switch, then disconnect your switch from your wall plug or power conditioner and finally disconnect the router connection, power down and disconnect your router from your modem. Wait 5 - 10 minutes. Then power up and connect your components in the opposite order. Hopefully, that should do the trick.
Jonathan
April 4, 2020, 08:31 PM #289Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
April 5, 2020, 05:37 PM #290
- Jan 2018
- 5
April 5, 2020, 05:38 PM #291
- Jan 2018
- 5
May 20, 2020, 10:55 PM #292
Re: Lumin T2
We just received this e-mail from a happy customer:
I just have to let you guys know - I have used my LUMIN D1 for 5 years and was happy. Four months ago I sold my D1 and upgraded to the LUMIN T2. I noticed an improvement in all aspects of my system (Krell 300i pushing Maggie 1.7i speakers) - sound stage, depth, bass, vocals, cymbals, etc. I was very happy. No one told me there was a ‘break in period’!! This system sounds better than I ever imagined four months in!
Thank you for an ‘Over the Moon’ quality product!! I just had to let you know!
A very happy customer for life!Peter Lie
LUMIN Firmware Lead
Looks like a great room and install!
