Results 51 to 100 of 181
January 3, 2019, 12:35 PM #51
- Feb 2016
- west Michigan
- 713
Re: Cables? What Brand/Model do you use?
My System
Acoustic Revive RTP-4
Innuos Pulsar
Lampizator BALTIC4
Cary SLP-05
Pass XA30.5 or
Line Magnetic 845ia
Reference 3A Reflector's
Pr SVS SB3000 Subs
Core Audio Design Rack
January 3, 2019, 12:52 PM #52
- Nov 2013
- Minnesota
- 1,369
January 3, 2019, 01:03 PM #53
- Feb 2016
- west Michigan
- 713
Yes, I noted both IC's and SC's in the post and in our test the results for either were the same.
Your results may vary.
If you have a more detailed or lively speaker that you wish to somewhat tame then these may work for you.My System
Innuos Pulsar
Lampizator BALTIC4
Cary SLP-05
Pass XA30.5 or
Line Magnetic 845ia
Pr SVS SB3000 Subs
January 3, 2019, 05:39 PM #54
I think this has turned out to be, and is proving to be, a very fruitful discussion.
Thank you everyone and please keep it going if you want to add anything.Last edited by joeinid; January 3, 2019 at 06:16 PM.
January 3, 2019, 05:49 PM #55DPT4ME - Dynamics, Presence & Tone for Musical Engagement; MBP (3) - stripped down for music only; Shunyata Omega & Sigma USBs; ISO REGEN w/short Curious USB links; Berkeley Alpha USB; Aqua La Scala II Optologic DAC; Schiit Yggdrasil - fully updated; Ayre Codex dac - updated; Pass Labs INT-60 integrated amp; Wyred 4 Sound STP-SE-2 preamp, Quicksilver Mono 120 amps w/Tung-Sol KT150s; Quicksilver Mid Mono amps w/Gold Lion KT77s; Fyne Audio 703s; Symposium Svelte Plus & Ultra Platforms; REL S-812 subwoofers; Duelund DCA12GA speaker cables; AV Room Service EVPs, Stein Music Harmonizers, Duelund DCA16GA & 20GA ICs; Shunyata Denali 6000S/V2; Tripp Lite PCs; Wyred 4 Sound power cords; AudioDharma cable cooker; dedicated custom room; various GIK & ASC room treatments; etc.
www.getbettersound.com
January 3, 2019, 06:01 PM #56
Duelund: Individual + and - runs or do u braid them?
"We all know real when we hear it"
January 3, 2019, 06:02 PM #57
- WyWires Platinum ICs
- Cardas Clear Beyond phono
- AQ Vodka Ethernet everywhere
- Inakustik LS Reference 4004 AIR for speakers
- Shunyata Alpha HC, Digital, NR, WyWires Platinum power
January 3, 2019, 06:10 PM #58
January 3, 2019, 10:26 PM #59
- May 2016
- 574
I've always been a believer in a cable loom or system. Especially in keeping the interconnects and speaker cables from the same manufacturer and possible the same line and or cable type( eg. all cooper etc) Maybe its the OCD in me but, all the best sounding systems I've ever heard always used this approach; regardless of the brand of speaker cable/interconnect.
To that end, I've used Audioquest cooper based in the past with great success (speaker+interconnect) Always felt that the DBS system gave such a low noise floor and smooth clean sound.
But, when I wanted more resolution the only option in AQ was to move up to their Silver cables Fire Interconnects and Redwood Speaker cables.
Even if I purchased them one at time ; the total end cost was more than wanted to spend.
MIT EVO One replaced them and surpassed expectations I had about "network" cables. Simply put, as a whole system MIT interconnects and speaker cables simply surpassed the AQ I had (Earth and Oak).
And at less of a cost than AQ silver cables.
I can't imagine what the higher end MIT Oracle cables are like.
For power, I've always used and trusted Shunyata Research and felt no need to try or compare anything else. Started with Venom and moved up to the Alpha line on all components with their Zi-Tron technology.
This combo MIT Speaker Cables/Interconnects+Shunyata Power cables has been a winner for me in terms of synergy and gotten me off the cable merry go round in this hobby.
Although I'm sure there are many fine alternatives; I'm happy with these products in my system.
January 3, 2019, 11:01 PM #60
- Apr 2015
- 634
That's what I have with my interconnects and speaker cables, all ZenWave Audio (silver/gold alloy).
And at less of a cost than AQ silver cables.Simaudio Moon Neo 260 DT CD Transport / MIT SL-Matrix Plus AES/EBU digital cable / Schiit Yggdrasil Analog 2 DAC / Octave HP 700 preamp / Octave RE 320 stereo amp with Super Black Box / Reference 3A Reflector monitors on Sound Anchors Signature Stands / dual JL Audio Fathom 112 v2 subwoofers on ASC SubTraps / ZenWave Audio D4 and SMSG cables / Acoustic treatment: tube traps, Tri-panels, window plugs, ceiling diffusers (all ASC), large absorbing panels (Acoustics First), diverse carpets chosen for acoustic properties: wool, polypropylene basket-weave
January 4, 2019, 03:56 AM #61
I am an enthusiastic Shunyata cable (power and IC) fan. I started with the entry Venom power cable years ago on my amps at that time, and haven't looked back. Each cable I added made an obvious improvement to the sound. Granted, it is possible another vendor might also have the same effect, but at this time I have zero reason to try another vendor.
Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
January 4, 2019, 07:20 AM #62
Big fan of Tinned Copper here.
Started with Belden 8402 as ICs + Duelund DCA 16 GA for speaker cable.
Then discovered the magic of Western Electric ...
WE 18 awg based power cable
WE 12 awg speaker cable
WE speaker cable connected bare wire.2 Channel Stereo :
January 4, 2019, 10:08 AM #63
The Duelund wire (and "audio-grade" tinned-copper wire in general) is quite detailed and yields a rich / intense tone -- very engaging.
Duelund makes this wire in both 12awg and 16awg. Relative to the 12awg, the 16awg is a little less weighty and a bit more nimble. So, depending upon your system and sound preferences one might fit better than the other.
January 4, 2019, 03:27 PM #64
January 4, 2019, 03:50 PM #65
I replaced my set of 3 meter bi-wire 16 GA speaker cables with a single - not bi-wired - set of 12 GA & preferred the 12 GA overall. I think this depends on the system, the set-up, and not least by any means - personal taste.
Also, the best results with any Duelund speaker cables that I've heard have typically been with higher efficiency speakers.
My Tannoys are 96dB/1W/1M 8 ohms.DPT4ME - Dynamics, Presence & Tone for Musical Engagement; MBP (3) - stripped down for music only; Shunyata Omega & Sigma USBs; ISO REGEN w/short Curious USB links; Berkeley Alpha USB; Aqua La Scala II Optologic DAC; Schiit Yggdrasil - fully updated; Ayre Codex dac - updated; Pass Labs INT-60 integrated amp; Wyred 4 Sound STP-SE-2 preamp, Quicksilver Mono 120 amps w/Tung-Sol KT150s; Quicksilver Mid Mono amps w/Gold Lion KT77s; Fyne Audio 703s; Symposium Svelte Plus & Ultra Platforms; REL S-812 subwoofers; Duelund DCA12GA speaker cables; AV Room Service EVPs, Stein Music Harmonizers, Duelund DCA16GA & 20GA ICs; Shunyata Denali 6000S/V2; Tripp Lite PCs; Wyred 4 Sound power cords; AudioDharma cable cooker; dedicated custom room; various GIK & ASC room treatments; etc.
January 4, 2019, 09:37 PM #66
- Nov 2014
- 2,104
You can buy the Duelund 12g for about $20 per meter. I use the 16g which costs $10/meter. Price wise, they are very inexpensive.
Someone loaned me some very expensive cables (a few thousand a pair) and I saw no reason to move away from the Duelund. I should add that I am cable skeptical guy so ymmv.
January 5, 2019, 09:21 AM #67
I’m using a combination of Shunyata (Sigma for Amp & Pre, Alpha for Digital and Phono Pre, and Delta for TT motor and controller) for PCs and Anaconda for SC. XLR ICs are Kimber Select (1116 and 1126).
Probably time to upgrade the speaker cables._______________
Phono Pre: Pass XP-27
Speakers: MBL 101E MKII
Rack: Artesania Exoteryc
January 5, 2019, 09:41 PM #68
- Aug 2013
- Burb of Chi-town
- 588
I use a combo of Ansuz C2 and D-TC. D-TC from the wall to the Mainz D-TC. C2 for the U300 and speaker cables. D-TC digital and almost forgot an Ansuz X ethernet from the switch to the Naim UnitiServe. If I were to upgrade any cable it would be the the C2 for the U300 to the D2. Very significant upgrade.
George
Aavik U300 - Borresen 03 with optional Supreme D-TC feet - Naim unitiserve 2tb - Ansuz DTC digital cable with power box - Ansuz Mainz8 D-TC with 1 Ansuz Supreme D-TC and 1 Ceramic V2 power cords - Ansuz Ceramic V2 speaker cables - Ansus X Ethernet - pARTicular Novus full suspension rack.
January 5, 2019, 10:06 PM #69
I started out years back with Van dun Hul cables, most notably The Clearwater [what a great name for a loudspeaker cable] and their most famous interconnects the D-102’s.
I then jumped into the Audioquest product range. I can’t remember the product names.
I then fell in love with Nordost and I worked my way through their extensive range with my first purchase being Blue Heaven interconnects and loudspeaker cables and Vishnu power cords. These were later upgraded to Red Dawn and again to Heimdall and again to Valhalla before reaching the top of the tree with the Odin.
And that brings us to where we are today. Ansuz Cables. The Ansuz cables have pretty much replaced all the Nordost ones. Ansuz P and Ansuz C where upgrades to Heimdall and Valhalla and Ansuz D and Ansuz C2 killed Odin.
In addition Van dun Hul, Audioquest and Nordost – over the years I have also tried lots of other cables including Belden, QED, Chord, Ecosse, Wireworld, Audience, MIT, Cardas, Kubala-Sonsa Research and Crystal.
I kept arriving at three conclusions. First, cables make a difference. Second, you have to audition cables in your own system changing a single cable at a time to appreciate this difference. Third, cable synergy is my preference. I prefer to keep the manufacturer choice consistent throughout the system. A common design approach and consistency of materials reduces variables and is much easier to work with.
There’s no denying that you can spend pretty much unlimited funds on cables. I don’t dare to add up what I’ve spent on cables over the years. My pursuit has not been a question of how much money is spent on cables – rather a question of how to extract every cent of performance I can and thus get full value from existing HiFi equipment I own.Borresen Acoustics Loudspeakers, Borresen Model 01 Compact monitor loudspeakers with Ansuz Darkz T2s Supreme resonance control, Audio Video Manufaktur GmbH (AVM) Inspiration amplifier & streamer, Innuos Zen MKII music server, Ansuz Acoustics cables & accessories. Please visit my system thread hosted on Audioshark for more details. Disclosure: The author is materially connected to Ansuz, Aavik & Borresen Acoustics via friendship with an owner.
January 5, 2019, 10:18 PM #70
- Aug 2013
- Burb of Chi-town
- 588
Ralph I also started with Nordost Frey and thought they were great. When I got my first Ansuz C I thought I was was really disappointed. But I was only listening for tonality changes. Then I heard what I would describe as more 'soul' in the instruments but more importantly in the vocals. Sure it cost more more but for me was worth hearing what is more lifelike soulful music.
George
January 5, 2019, 10:35 PM #71
I hear you George.
Cable evaluations need to consider the big picture. We often try - perhaps too hard - to pick out small differences and use these small differences to arrive at what we hope is a rational decision. Sometimes, we are better off to simply sit back, relax and ask ourselves which musical performance resonates and emotionally connects with us - because that is the recipe for long term satisfaction.Borresen Acoustics Loudspeakers, Borresen Model 01 Compact monitor loudspeakers with Ansuz Darkz T2s Supreme resonance control, Audio Video Manufaktur GmbH (AVM) Inspiration amplifier & streamer, Innuos Zen MKII music server, Ansuz Acoustics cables & accessories. Please visit my system thread hosted on Audioshark for more details. Disclosure: The author is materially connected to Ansuz, Aavik & Borresen Acoustics via friendship with an owner.
January 6, 2019, 10:49 AM #72
- Aug 2013
- Burb of Chi-town
- 588
I should have clarified that I was referring to the original C speaker cables not power cords or interconnects.
George
January 6, 2019, 11:09 AM #73
- Jul 2017
- Arizona
- 224
Bud<br>
AAVIK: S-280 Streamer, D-280 DAC, I-280 Integrated Amplifier]
NAIM: Atom HE Headphone Amp, Superlumina Speaker Cables, Power Cables
HARBETH: 30.2 40th Anniversary Speakers
FOCAL:: Utopia Headphones
ANSUZ: C2 Power Cable, A2 Power Distributor, D2 Ethernet Cables, D2 PowerSwitch, D2 Interconnect
NORDOST: Heimdall 2 Ethernet and Power Cables
QUADRASPIRE: SVT Equipment Stand
SKYLAN: Speaker Stands
UPTONE:Linear Power Supply
DANACABLE:: Headphone cables
January 6, 2019, 11:19 AM #74
- Aug 2013
- Burb of Chi-town
- 588
Absolutely. The D-TC is a pretty big step up from the D2.
George
January 6, 2019, 11:26 AM #75
- Jul 2017
- Arizona
- 224
Bud<br>
March 11, 2019, 09:21 PM #76
- Jul 2015
- Golden, CO
- 858
Can someone tell me which of these Duelund cables is best for speakers? Thanks.
https://www.partsconnexion.com/cgi-b...p=20&sort_by=1
March 11, 2019, 09:28 PM #77
- Feb 2016
- west Michigan
- 713
Those that use it use either DCA12GA ot DCA16GA
My System
Innuos Pulsar
Lampizator BALTIC4
Cary SLP-05
Pass XA30.5 or
Line Magnetic 845ia
Pr SVS SB3000 Subs
March 11, 2019, 09:31 PM #78
For most applications and what I've read from Dueland fans, they generally recommend the 12AWG tinned copper with oil impregnated cotton jacket as being best.
March 11, 2019, 09:38 PM #79
- May 2013
- 3,243
March 11, 2019, 10:08 PM #80
Unheard of... to have two audiophiles agree on anything audio related!
March 11, 2019, 10:38 PM #81
- Jul 2015
- Golden, CO
- 858
Thank you!
March 11, 2019, 10:50 PM #82
- May 2013
- 3,243
Rob
Dueland recommends bare wire ends but if you want to add connectors look at the Furez solid copper ones from Douglas Connection. Easy to use with double Torx screw connection.
https://www.douglasconnection.com/se...keywords=furezMain - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
March 12, 2019, 02:30 PM #83
March 12, 2019, 08:36 PM #84
March 12, 2019, 08:46 PM #85
March 12, 2019, 09:12 PM #86
Necessary caveat: All of our ears, systems, rooms, are different! BUT.....
Power Cables: During the last year or so I have been through the upper levels of Shunyata, Nordost, and AQ. For my system and my ear I came to these conclusions:
Nordost Power: Way too much money for what you are getting. Nice? Yes, but the competition seems to have them beat for what is often a substantially lower price when considering the higher end of the line. I kind of feel like their technology is aging on the power front.
Shunyata Power: Fine but did not really stand out one way or another. Definitely a high quality brand, nice and smooth, etc, but I can't say I noticed a real signature sound of those cables in my system. I'm sure others will disagree. I do absolutely love the Typhon / Triton combo with a hurricane coming from the wall. Better than the Niagara 5000/7000? I think so... I think it's just a finer wine, but at a substantially higher price. Worth it? Depends on your system. I have a hurricane > Niagara 5000 on my home theatre and have zero reason to change it out. It really helped power movies correctly with a strong and constant feed to my power amp. It also calmed down all of the little boxes like directv, apple tv, etc.
AQ Power: The first Hurricane I put in my system was a revelation moment... next level of technology to me. ABSOLUTELY the best bang for the buck for me, and I could be happy for life with hurricanes. Yet, I liked the hurricanes so much that I bit the bullet and went for dragons. Dragons are in the silly price range for sure, and I doubt many systems out there will notice much more than an incremental change (maaaaaybe 1.5 levels higher than a hurricane for 4x the cost). You would need to do an A-B comparison to really "miss" the dragon over the hurricane. BUT, there is no doubt that a loom of dragons make a great system sparkle like a diamond in a way that hurricanes can't achieve. I really question if there is a better power cable than the dragon. In short, get the dragon if you have entered the somewhat crazy level of audiophile land, as you won't regret it... especially if your gear is at a high enough level to really benefit from the dragon. My experience is the better the gear, the higher the sensitivity to small changes. Or, get hurricanes and save the money for other gear that will actually make a much more substantial improvement.
Side note: I also got a bunch of the AQ X, Y, and Z cables for my TV's, apple TV, directv, etc. I think they really helped.
Speakers and interconnects:
I went through various Nordost lines (Heimdall 2/ Frey2 / Tyr 2 / Valhalla 2). V2 is great. Good enough that I stopped there before Odin. It's commonly said that Nordost is slightly to the bright side, and I would agree. But, I like that. Nordost is well respected and all, but the prices don't always seem to match up well with the competition for me. I have moved on to MIT 2C3D Level 1 for speakers and for the interconnect from preamp > amp. I made the choice because MIT and Magico are a great fit due to MIT being what Magico has commonly used in development of their speakers. I would agree that MIT has something special. For me, they have a thicker feeling than Nordost, definitely better layers and snappiness in the low and low mids, and slightly tilted to a darker side... slightly. I hear AQ speaker cables in a very similar way, but MIT speaker/interconnect just seem to produce a far classier sound than AQ in all ways to me.
I still use Nordost Heimdall 2 and Frey 2 on my home theatre. I love them for that use, as they keep the sound wide open and with plenty of air for me. That helps with sports games, and balances out movies that have lots of low end sound.
One brand I really wish I tried more was Transparent. I have heard some fabulous systems with their cables, but I have no idea if I would have liked them in my system.Jeremy
Speakers: Magico S3 MkII
Power Amp: VAC 200iQ (stereo)
Source/DAC/Preamplifier: MSB Reference DAC (Femto 77 / Dual Powerbase)
Power: Shunyata Triton V3 / Shunyata Typhon QR / AQ NRG 20 Outlet / Dedicated 20 amp circuit
Power Cables: AQ Dragons to components / AQ Hurricane to Typhon QR
Speaker Cables: MIT Heritage MI 2C3D - Level 1
Interconnects: MIT Heritage MI 2C3D - Level 1 (XLR)
Ethernet: AQ Vodka > Aqvox SE > AQ Diamond > MSB Reference DAC
Racks: Critical Mass Sotto Voce with Black Platinum shelves
March 13, 2019, 11:56 AM #87
2 Channel Stereo :
July 30, 2019, 05:02 PM #88
Greetings, my own experiences with various cables has been an interesting journey to say the least. My current cable array is as follows:
Wireworld Starlight Platinum 7 USB, Black Cat Silverstar USB, Furutech 75 Ohm digital cable, Linn Blacks RCA, and the speaker wire/cabling is 47 Laboratory Stratos. 40 mm. My most amazing results are from the 47 Labs speaker wire, relatively inexpensive and the most “bang for the buck” I have experienced. Thank you for looking!
Cheers
My goodies, changes again, Still modest, but effective...(at least on my level).
47 Laboratory Midnight Blue 4733, Audiolab 6000CDT, OPPO BDP103, iFi Zen Blue, Sparkler Audio S301B diva. Cabling: RCA, Linn Blacks,
47 Laboratory 4708 speaker cables. Morrow Audio DIG3 w/KLE Pure Harmony connectors. DH Labs Red Wave A/C power (for the 4733) Yep,that's it. My aim is high, but sometimes I forget to wear my glasses...
August 1, 2019, 09:27 PM #89
I'm using Bis Audio.
For the speakers, it’s the Type3 bi-wire, two paires of Vivat interconnects ( one pair RCA-RCA and one paire balanced) and the power cables are all AC20.
It’s a small business from near Montreal, Qc.Modwright KWH 225i + PH 9.0 - Rega P8 + Ania Pro - Audiolab 9000CDT - Elac AF-61/Gaia II - Luna Cable Mauve
August 2, 2019, 08:19 PM #90
- Mar 2015
- Leesburg FL
- 39
Complete system wired with MIT’s best products. Performance is just insane.
August 3, 2019, 10:24 AM #91
- May 2016
- 574
Nice. I’m also an MIT user and was proven wrong about their technology. Was never a fan of “networked cables” until I actually gave MIT cables a try in my own system.
I’ve found that a full of loom of MIT (interconnects +speaker cables) are ideal to get hear the full benefit they can deliver. Rather than one pair of interconnects or just the speaker cables and mixed with other brands.
However, the end result is a very big, open and dynamic sound. Such presence and you are there feeling. At least IMHO.
Of course this hobby is very subjective but, MIT cables have delivered for me and are an end game destination cable for me.
August 3, 2019, 12:23 PM #92
August 5, 2019, 04:30 AM #93
Excellence is rarely cheap
If you don't want to pay the insane current gen prices and don't use all the knobs, switches, etc. (which I don't and which IMO ruin the sound other than the treble and bass tone controls which are handy if needed) their last gen Oracle cables (relatively speaking, super affordable second hand) get you all the way there to current gen Oracle less a little bit of speed, which can in any case be realized elsewhere in the chain.EMM Labs TX2 SE|DA2 V2| Ayre KX-R Twenty | D'Agostino Momentum M400 | Focal Maestro Utopia III | MIT Oracle MA | VH Audio | Shunyata King Cobra CX | Shunyata Everest | Harmonic Resolution Systems | CAD Ground Control
August 5, 2019, 04:27 PM #94
- May 2016
- 574
August 5, 2019, 04:32 PM #95
August 5, 2019, 05:40 PM #96
- May 2017
- Cleveland, Ohio, USA
- 531
August 6, 2019, 12:41 PM #97
- Mar 2015
- Leesburg FL
- 39
August 6, 2019, 01:32 PM #98
- Mar 2017
- North Carolina
- 813
My version of 'excellence' will need to include a reasonable price, something like 80% of the performance at 20% of the price.
August 6, 2019, 04:30 PM #99
- May 2017
- 531
August 6, 2019, 06:37 PM #100
- Mar 2017
- North Carolina
- 813
Smooth this morning, as well. Thanks Mike & Co.
Forum Software Update
