Thread: System and Room Pictures
December 18, 2018, 10:33 PM #1
My wife and I relocated to FL a little over a year ago. We had the opportunity to custom design and build our new home on the gulf coast of the state. As part of the plan, we included a music room for our stereo system.
The dedicated music room is acoustically treated, has dedicated power, all walls and ceiling insulated. The acoustical treatments are recent - Vicoustics and Stillpoints Apertures (both purchased from Mike) and custom made corner bass traps from Acoustimac.
_______________
Phono Pre: Pass XP-27
Speakers: MBL 101E MKII
Rack: Artesania Exoteryc
December 18, 2018, 11:03 PM #2
Re: System and Room Picutes
Mike,
Absolutely beautiful system.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
December 18, 2018, 11:23 PM #3
What a transformation you’ve done with this Mike! Looking great.
December 19, 2018, 12:15 AM #4
Good for you, Florida is starting to sound real good as winter in the Northwest kicks in.
Also pictures are not showing on an iPad
Sent from my iPad using Tapatalk ProSource Analog: Kuzma Stabi R w/4point 11 arm | Kuzma 50 Cartridge
Speakers: Wilson Alexias
December 19, 2018, 12:24 AM #5
Mike.......You have done a fine job creating a dedicated listen room. It looks fabulous. With the pedigree of gear I see, I am certain the system sounds awesome. Here's to many years of splendid audio enjoyment for you and your wife.
Dan
December 19, 2018, 06:07 AM #6
_______________
December 19, 2018, 09:27 AM #7
Mike that is an amazing room you have assembled there!!!! You should host the group for a night of listening during the Florida Audio Expo....
Marty
MSB Premier
PS Audio Powerplant 15
December 19, 2018, 09:38 AM #8
December 19, 2018, 10:29 AM #9
Looking good Mike!
Love the earth tone scheme.
December 19, 2018, 10:30 AM #10
Friggin Awesome!
Brian
December 19, 2018, 10:32 AM #11
Mike-Congrats on your new home and your beautiful custom built stereo room. I'm curious as to how you decided on the number and placement of your extensive room treatments.
December 19, 2018, 11:13 AM #12
Well done Mike.
December 19, 2018, 12:25 PM #13
Thx Mark!
I worked with several audiophiles locally to measure the room with a microphone. Found issues with several frequencies that I needed to address. Also, worked with Mike Bovaird (AS and Suncoast) to determine the number of panels as well as used several of the tools online to determine required coverage based on the size of the room. And, I spent a couple of days doing the installation per the plan (corner traps to address low frequencies, absorption for first and second reflection, some difussion and absorption in the front and rear walls).
I still need to measure the results and do a comparison to the earlier measurements. With that stated, the difference when listening to music is quite remarkable. Previously, the room was very lively with a significant echo and ring; that is not the case anymore. Now, there is sharpness with voices and instruments that was not there before, bottom end is tighter and there is an increase in dimension that was not there before.
I underestimated the improvements and musical enjoyment that a properly setup room with acoustic treatments can provide. Best investment in audio I’ve made in my 40 yrs in this hobby.
Again, even with the very positive results I’m experiencing in the room, I want to re-measure the space. And, if necessary, make additional adjustments as appropriate._______________
December 19, 2018, 01:24 PM #14
December 19, 2018, 01:53 PM #15
Super nice room Mike! Congrats with your beautiful work.
I'm curious, what are your room dimensions?Avanti Audio
December 19, 2018, 03:15 PM #16
Mark - That was my concern as well. The models I ran indicated 112 sq ft of coverage. The installation is 108 sq ft. I have a few panels left that I could install if needed. Again, we’ll find out after we re-measure the room.
December 19, 2018, 03:23 PM #17
December 19, 2018, 04:00 PM #18
Re: System and Room Pictures
December 19, 2018, 09:32 PM #19
Wowza. Absolutely beautiful.
Sent from my iPad using TapatalkPaul
December 19, 2018, 09:57 PM #20mauidanGuest
Mike,
Are those Stillpoint Aperture Acoustical panels on the wall behind the speakers?
December 19, 2018, 11:47 PM #21
_______________
December 19, 2018, 11:49 PM #22
Mike, I’ve heard about the Aperture panels, but not had them in my room.
Could you describe what they do, and how their effect differs from the Vicoustic panels?
December 20, 2018, 02:32 AM #23
Avanti Audio
December 20, 2018, 08:01 AM #24
They are supposed to provide both diffusion and absorption. In my experience, when placed on the front walls (center behind the speakers) as well as on the rear wall in a similar installation configuration they do a nice job with focus and image. I have included Stillpoints link below for additional info.
http://www.stillpoints.us/index.php/...randing_View_2_______________
December 20, 2018, 11:58 PM #25
Very, very nice!
Regards,
Steve
https://www.audionirvana.org/forum/t...geezr-s-system
I only do what the voices in my wife's head tell her to tell me to do.
May 22, 2020, 06:58 PM #26
Just making some changes...
B6311567-F69E-4ED4-A51F-DC69EB2654F2.jpeg_______________
May 22, 2020, 07:22 PM #27
May 22, 2020, 07:28 PM #28
OMG! As the youngsters would say.
I was very happy with my prior system. But, Mike spoke with my wife about MBL (which she loved during a visit to his the store) and, five months later, new speakers, amps and pre.
Geez, I’m supposed to be retired. May end up having to go back to work!_______________
May 23, 2020, 04:45 AM #29
May 23, 2020, 05:34 PM #30
But wait, this was missing...
1A3D86C2-0F84-46E8-A91F-E9B9DD77B4D0.jpeg_______________
May 23, 2020, 07:44 PM #31
Fantastic setup. I bet it sounds wonderful.
Gary
Main: Lumin A1, Accuphase E-650, Tannoy Canterbury GR, Shunyata, Audience
Secondary: Lumin M1, Linton Heritage, Shunyata, Audience
May 25, 2020, 08:11 PM #32
Thanks Gary! I can say that I’m humbled and, certainly, enjoying music with a wonderful system.
_______________
September 23, 2021, 08:22 PM #33
Well, I’ve made a few more changes:
- Added two REL Carbon Special Subwoofers
- Replaced the wonderful Lumin X1 with the exceptional Esoteric N01-XD
I’m extremely happy with the changes. The already fine sounding system is providing me with a higher level of musical enjoyment._______________
September 24, 2021, 06:31 AM #34
It's a beautiful room!! It already sounded good, I can't wait to hear it now with the subs.
Mark
Kharma DB9 Signature
Pass Labs XP32......incoming
Pass Labs X350.8
Esoteric N-05XD
Manley Chinook Phono Pre
Kharma Elegance interconnects
REL Subs
September 24, 2021, 07:18 AM #35
Looking awesome! I’ll be over later today for a listen.
Sent from my iPhone using Tapatalk ProMy Systems: http://www.audioshark.org/showthread...481#post158481
September 25, 2021, 05:23 AM #36
- Jun 2013
- Ontario Canada
- 805
Very nice system.
September 26, 2021, 03:14 PM #37
Mike, you have an AWSOME setup! Congrats on your new MBLs!
George
September 26, 2021, 03:19 PM #38
I had a chance to visit Mike (RITMO) on Friday afternoon. We listened primarily to digital with his new Esoteric N-01XD. Mike has also added two REL subwoofers. The addition of these two subs and new source has really taken his system to a whole new level. He’s got the subs dialed in beautifully and it honestly sounds like a 101 Xtreme “lite” system. Just a big big step up. Well done Mike
Sent from my iPad using Tapatalk ProMy Systems: http://www.audioshark.org/showthread...481#post158481
September 26, 2021, 05:06 PM #39
Thanks guys!
I’m extremely pleased with the system. While my system has been wonderful, I agree with Mike, the addition of the Esoteric N01XD and the REL Carbon Special subs have been transformational._______________
September 26, 2021, 05:59 PM #40
Congratulation Mike, beautiful system and room.
Synology 1019D+ - SGC Sonictransporter I9 w Roon/HQ Player- UltraRendu- PBD Stream IF to Playback Designs MPS5 via fiber optic - ARC 40th Anniversary Pre - ARC 610 T's - Martin Logan CLX's - 4 Martin Logan Depth i Subs - Shunyata Hydra, DIY PCOCC interconnects, speaker cables and power cords with Furutech terminations. Blue Jeans CAT 6's. Acoustically treated room with one permanent chair.
September 27, 2021, 02:32 PM #41
Awesome system! I have listened to those speakers at a buddies house. He has the MBL pre and MBL mono blocks also. He listen mainly to vinyl... amazing gear, congratulations!
McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
― Neil deGrasse Tyson
September 27, 2021, 04:24 PM #42
Wow Mike, fantastic all around. Congratulations and enjoy as much as possible.
Paul
Tape Deck Otari 5050B II2
Music Server: Aurender N100H
September 27, 2021, 04:28 PM #43
- Jun 2013
- 1,068
Mike, congratulations on the upgrades. I know you're experiencing things on a whole new level. How much fun is that!
What are the damping plates you have on your components?
September 27, 2021, 05:33 PM #44
Thanks guys! It’s been a great journey.
I’m extremely happy with the system. The synergy of the MBL speakers with the MBL pre and mono amps is fabulous. The addition of the subs which I have crossed under 30HZ has added a wonderful dimension and increased the size of the soundstage in a big way.
And, the new Esoteric N01XD has taken the digital music presentation to a higher level. Lastly, I also enjoy vinyl quite a bit via a VPI Avenger (Magnetic platter, three belt pulley and ADS) with a 12” Fatboy arm, Ortofon Windfeld TI, Pass Audio XP 27.
Bob - The damping plates are from the Artesania Exoteryc rack._______________
September 27, 2021, 06:01 PM #45
- Aug 2014
- lachen / sz
- 1,061
the system / room gives a good feeling from just looking at it.
dont change a thing!
January 6, 2022, 12:58 AM #46
Dang, now that system and that room look like some serious music. Very impressive, one of my favorites so far all-around!
Main System
Lumin X1 > Boulder 1161 > Scansonic MB3.5 B
Headphones
Home: HiFiMan Susvara > Schiit Lyr+
Portable: Focal Radiance > AQ Dragonfly Cobalt / Chord Hugo 2
January 12, 2022, 05:59 PM #47
Thanks so much!
The hard work and investment have resulted in a wonderful, quiet and comfortable space in which I’m able to enjoy music at its fullest. And, I have been lucky enough to be able to put together a very nice system. Lastly, a wonderful wife that enjoys music, understands how important music is to me and has treated me to some nice components as well._______________
Altaira or Gemini CGS on...
