Results 1 to 35 of 35
Thread: Yggdrasil vs Luxman DA-06 DAC
December 16, 2018, 04:01 AM #1
- Nov 2013
- Minnesota
- 1,369
Tonight I had some friends over and they brought over a Yggdrasil DAC with the Gen 5 usb and an
Atma-Sphere UV-1 preamp that was modified with Teflon Caps and some other upgrades recently by Ralph of Atma-Sphere.
We compared the Yggy to my DA-06 and I was happy to hear that the Yggy did not blow the Luxman out of the water. The Yggy had a bit more detail, was crisper and had a faster pace. It was also slightly more forward. The Luxman was more rounded, smoother and slower with a bit more warmth although the Yggy was not bright at all. Sound stage was about the same. Both had similar musicality. I think that I would give a slight edge to the Yggy. How ever, I could see some people preferring the Yggy by a long shot depending upon tastes. I don't know if it is enough to make me go out and buy it though. I would like to hear it compared to the PSA Direct Stream and the T+A DAC8, 2 DAC's that I really like.
The Atma-Sphere UV-1 was very interesting. It looks like it was made in the 1920's. It does not come with a remote. It sounded very good in my system with a lot more warmth and tube sound compared to my BAT preamp which sounds almost SS in comparison. One guy pointed out that it made digital sound more like vinyl. However, it lacked the detail, resolution and clarity of the BAT. It's sound stage was good but much smaller than the BAT which sounds almost holographic in comparison. However, the UV-1 did put out deeper and punchier although not as tight sounding bass.My Gear- Mains System-Pass X250 amp, BAT VK-51se preamp, Luxman DA-06 DAC, Magnepan 1.6's, Thorens TD-145 TT, Dual Martin Logan Subs, Vintage Luxman T-110 Tuner, Cables-WW Platinum 7 USB, Cardas Parsec XLR, AQ Columbia DBS 72v XLR, Belden 8402 XLR.
December 16, 2018, 10:15 AM #2
Re: Yggdrasil vs Luxman DA-06 DAC
Speakers: Wilson Alexias
December 16, 2018, 11:48 AM #3
- Apr 2015
- 634
December 16, 2018, 12:33 PM #4
I would not change DAC on difference you described unless my overall system really needed it. When I put my Mojo in and compared it to a very nice RT Audio, I would description like the Luxman, the difference was not subtle. The whole harmonic texture and overall realism of Instruments jumped. Not only that but the soundstage gained depth and precision placement. IMO, if you hear changes like that and it's affordable to your budget, upgrade. Otherwise stay with what you have till something jumps out and grabs you.
December 16, 2018, 12:37 PM #5
AL M. .......I never turn my Yggdrasil DAC off, nor do I turn off the Simaudio Moon Neo 260 DT transport or my Aurender N100H music server in the living room system. The same is true for my Esoteric K-01x CD/SACD/DAC and Aurender N10 in the studio system. They are always warm and ready to make music at any given moment. It does make a difference.
Dan
December 16, 2018, 01:55 PM #6
- Nov 2013
- Minnesota
- 1,369
The Yggy had been on for about 3 hours before playing and we listened to for about 1.5 hours. While I have no doubt that it would sound better with longer warm up, I still don't think that it is not a huge step up from the luxman. Upsampling music on the Lux to 352 and 384 using Bug Head music player closed the gap with Yggy. We did not try DSD.
The Yggy certainly performs well above its price point and is well worth the money. If I was starting from scratch, it would be in my top 3-5 dac's in my budget.My Gear- Mains System-Pass X250 amp, BAT VK-51se preamp, Luxman DA-06 DAC, Magnepan 1.6's, Thorens TD-145 TT, Dual Martin Logan Subs, Vintage Luxman T-110 Tuner, Cables-WW Platinum 7 USB, Cardas Parsec XLR, AQ Columbia DBS 72v XLR, Belden 8402 XLR.
December 16, 2018, 05:50 PM #7
- Apr 2015
- 634
December 16, 2018, 05:51 PM #8
- Apr 2015
- 634
December 16, 2018, 06:29 PM #9
- Mar 2016
- Minnetonka, MN
- 59
December 16, 2018, 06:54 PM #10
December 16, 2018, 06:55 PM #11
December 16, 2018, 09:30 PM #12
I also concur Yggy needs a couple of days to warm up. The difference isn’t small.
December 16, 2018, 09:55 PM #13
You mentioned that you were thinking about a T+A DAC8, make sure you get the T+A DAC 8 DSD. While it is good with PCM having 8 BurrBrown chips dedicated to PCM, what it does with DSD is out of this world. They developed their own 1 bit converter. To really see it shine, if you can, try it with Roon & HQPlayer. I upsample everything to 24.6 Mgz (DSD512 with 48 Base Clock). Simply amazing.
― Neil deGrasse Tyson
December 17, 2018, 11:20 AM #14
- Nov 2013
- Minnesota
- 1,369
December 17, 2018, 11:23 AM #15
- Nov 2013
- Minnesota
- 1,369
December 17, 2018, 11:46 AM #16
The laundry list of DACs I have tried is almost scary since digital is my main source. I rip every disks I get and move them to the server. Every disk literally gets one spin . The T+A is in a league of it's own in my view. It is one piece in my system that has no chance of being replaced (unless someone wants to give me a Lampi or something ).
If you can run it with Roon & HQPlayer you will be impressed for sure!McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
December 23, 2018, 05:09 PM #17
Hey there, this thread just prompted me to register here! I just bought a Luxman DA-06 last week to compare with my Hegel HD30, and have been doing some comparisons and coming to similar conclusions as you and your Yggy comparisons.
I got the DA-06 just because I'm a big Luxman fan and thought it would play nice with my L-509X integrated, at a similar level of sound quality as the HD30 (which I was perfectly happy with). I, too, found the Luxman generally had a more musical presentation of the sound - seemingly allowing the entire composition to shine, rather than with the Hegel where - while not clinical like a Mytek, etc - it does seem to draw attention to the individual instruments (particularly percussion) a bit more.
I'm very happy with the Luxman and currently upsampling everything in Roon to DSD 128, and it sounds amazing. So I'm letting the Hegel go. But it's true that at a certain point there's not necessarily "better," just "different," and what your individual tastes are will dictate whether that "different" is better to you.
December 23, 2018, 10:30 PM #18
Welcome Jeremey!
December 24, 2018, 10:08 PM #19
Thanks Joe, good to be here!
PRIMARY 2 CH SYSTEM: Backert Labs Rhythm 1.3; Parasound JC3+ Phono pre; Luxman M900u; Pure Fidelity Harmony with Origin Live Illustrious tonearm and PF Stratos cart; Naim NDX 2; Naim 555PS; Innuos Zen MK III (Roon Core); EtherRegen; Volti Audio Rivals; JL Audio e112 (2); Transparent Super Speaker Cables; Transparent Super interconnects; Transparent Premium & High Performance power cables; Naim Fraim; Stillpoints Ultra SS; Symposium Ultra platforms; IsoTek EVO3 Sigmas conditioner; GIK Acoustics absorption and diffusion panels
December 24, 2018, 10:24 PM #20
- Nov 2013
- Minnesota
- 1,369
Welcome aboard. Glad to see you like the Luxman. I really like the Luxman, it checks all the boxes for my type of sound. I really liked the Yggdrasil with the Gen 5 usb. I was surprised that it leaned a bit to the warm side. I may eventually upgrade to it and give the Lux to my son since it is a Japanese version and I may have trouble selling it for a decent price. Or I may just go for the T+A DSD8 once my friend brings his over for me to try in my system now that I have a computer that can do DSD512. I do have quite a bit of DSD recordings and they would be a waste with the Yggy.
This is off topic but-
Right now I am wrestling with the idea of selling my amp and preamp and going with a Luxman integrated or just sell my BAT preamp and buy a custom Don Sachs SP-14 tube preamp with all the upgrades and then wait and see how the Lux and T+A sounds with it. I am leaning on having the DS's preamp built and compare it with my BAT. I would have no trouble selling the BAT for $3200 or so with relatively new tubes and new Caps in the 6 pack.My Gear- Mains System-Pass X250 amp, BAT VK-51se preamp, Luxman DA-06 DAC, Magnepan 1.6's, Thorens TD-145 TT, Dual Martin Logan Subs, Vintage Luxman T-110 Tuner, Cables-WW Platinum 7 USB, Cardas Parsec XLR, AQ Columbia DBS 72v XLR, Belden 8402 XLR.
December 24, 2018, 10:54 PM #21
Thanks - I am very happy with the Luxman... curious what filters you are using for PCM and DSD? Since I'm upconverting everything in Roon, I am using the 7th Order (CLANS) filtering in Roon and the D2 filter on the Luxman. Sounds really great to me. I got a really good deal on the US version of the DA-06 ($2k) and I'm happy not only because it sounds good, but because it matches my 509X integrated (ha). I am hoping I can sell the Hegel for more than I paid for the Luxman. Before I got the Hegel, I was seriously considering the Yggy, but multiple dealers were steering me in other directions (maybe because Schitt is only selling direct - but I wasn't going to be able to demo it anywhere so that was a factor in the decision as well). It does sound like if you're heavily invested in DSD it wouldn't be the best direction to go in.
I can't tell you how the integrated compares with what you have now, but I'm extremely happy with my 509X. Definitely the center piece of my system. It drives everything with total control over the music and is a great match with the dynamics of my Klipsch La Scala IIs. I'm also using my CL40 valve preamp for certain music... the 509X has a preamp "Separate" function that allows you to use an external pre (most would use this as a HT bypass I assume). But there is content that just really comes to live with the valve preamp versus the 509X pre - and that is no slouch, I believe it's the same preamp as the c900u. If you're hesitant about the class A/B in the Luxman, the 590X (class A) appears to be highly recommended as well.PRIMARY 2 CH SYSTEM: Backert Labs Rhythm 1.3; Parasound JC3+ Phono pre; Luxman M900u; Pure Fidelity Harmony with Origin Live Illustrious tonearm and PF Stratos cart; Naim NDX 2; Naim 555PS; Innuos Zen MK III (Roon Core); EtherRegen; Volti Audio Rivals; JL Audio e112 (2); Transparent Super Speaker Cables; Transparent Super interconnects; Transparent Premium & High Performance power cables; Naim Fraim; Stillpoints Ultra SS; Symposium Ultra platforms; IsoTek EVO3 Sigmas conditioner; GIK Acoustics absorption and diffusion panels
December 25, 2018, 12:42 PM #22
- Nov 2013
- Minnesota
- 1,369
I switch back and forth between the filter with no pre and post ringing and the one with only post ringing. Currently, I use Bug Head Infinitly Blade as a music player and it has multiple settings to tailor the sound. I upsample most music with it. I have used HQP many times before and I am very familiar with Roon. Bug Head just sounds so good but is a pain to use if you want to switch around play a variety of music.
I am thinking about a Luxman L-507 uXII integrated or maybe a used higher end integrated. I am currently leaning to the Don Sachs custom preamp as so many people love it.My Gear- Mains System-Pass X250 amp, BAT VK-51se preamp, Luxman DA-06 DAC, Magnepan 1.6's, Thorens TD-145 TT, Dual Martin Logan Subs, Vintage Luxman T-110 Tuner, Cables-WW Platinum 7 USB, Cardas Parsec XLR, AQ Columbia DBS 72v XLR, Belden 8402 XLR.
December 25, 2018, 03:14 PM #23
Very cool... I find the versatility of Roon outweighs the incremental benefits I may get from going down the rabbit hole of HQP or even mConnect/iPeng, etc.
Since I have the house to myself this Christmas week, I am considering doing some experiments with by bringing my Anthem MRX 720 back into the mix to experiment with Anthem Room Correction with this setup. I'll be sending the analog signal out from the Luxman back into the analog input of the Anthem, so I realize the signal will be re-digitized... but now I'm curious about any benefits I may get from ARC considering I'm sending a pristine analog signal into the Anthem from the Innuos and Luxman DAC.PRIMARY 2 CH SYSTEM: Backert Labs Rhythm 1.3; Parasound JC3+ Phono pre; Luxman M900u; Pure Fidelity Harmony with Origin Live Illustrious tonearm and PF Stratos cart; Naim NDX 2; Naim 555PS; Innuos Zen MK III (Roon Core); EtherRegen; Volti Audio Rivals; JL Audio e112 (2); Transparent Super Speaker Cables; Transparent Super interconnects; Transparent Premium & High Performance power cables; Naim Fraim; Stillpoints Ultra SS; Symposium Ultra platforms; IsoTek EVO3 Sigmas conditioner; GIK Acoustics absorption and diffusion panels
December 25, 2018, 03:27 PM #24
I agree with the versatility of Roon, it is amazing. However being a Roon fan does not preclude HQPlayer. Roon is designed to work hand in hand with HQP, and the improvements are quite enormous. Roon is the finest interface, music management, meta data, etc., and HQPlayer is the best playback engine in my view. Together they make an amazing digital playback system! Both are great in their own rights, but together they are much better.
December 25, 2018, 03:53 PM #25
December 25, 2018, 03:58 PM #26
I was using ARC with my frankenstein HT/2 channel system when I was running Atmos in here. It did clean up things quite a bit with movies for me. I spent quite a bit of time learning the ins and outs of ARC. But I never really liked it for music. Now I'm curious about how it would sound running pre-outs into the Luxman L-509X, especially since the new STR integrated/amps are getting such rave reviews (with ARC as a big feature). Before I was using all internal Anthem amps.
Heading out to the storage unit to haul some of this stuff back here and see what's what!PRIMARY 2 CH SYSTEM: Backert Labs Rhythm 1.3; Parasound JC3+ Phono pre; Luxman M900u; Pure Fidelity Harmony with Origin Live Illustrious tonearm and PF Stratos cart; Naim NDX 2; Naim 555PS; Innuos Zen MK III (Roon Core); EtherRegen; Volti Audio Rivals; JL Audio e112 (2); Transparent Super Speaker Cables; Transparent Super interconnects; Transparent Premium & High Performance power cables; Naim Fraim; Stillpoints Ultra SS; Symposium Ultra platforms; IsoTek EVO3 Sigmas conditioner; GIK Acoustics absorption and diffusion panels
December 25, 2018, 04:26 PM #27
I used to have MRX500 a long time back and tried ARC for a week, but never really liked it for both music and movie. I preferred it off. Never turned it on again, then I got AVM60 mainly for 4K pass-through and the Anthem sound that I like for movies.
December 25, 2018, 04:58 PM #28
- Nov 2013
- Minnesota
- 1,369
Today I upgraded my Luxman drivers to the latest version and I was pleasantly surprised at a change in sound for the better I think. It is a little darker, blacker and smoother sounding. The sound stage is more focused but not quite as wide. It sounds more analog.
December 25, 2018, 06:25 PM #29
How do you update the drivers? Is this the same as updating the firmware on the DAC? I don't have it connected to a computer, mine is connected to the Innuos.
December 25, 2018, 08:10 PM #30
The only driver shown on the Luxman site for the DA-06 DAC is a Windows USB driver, so it wouldn't apply unless you have a Windows based server.
December 25, 2018, 11:18 PM #31
- Nov 2013
- Minnesota
- 1,369
What can I say, I updated from 1.040 to 1.090 and the sound is different for some reason. My son heard it too. The sound stage is more focused and it is warmer and darker. I put on a harsh recording that was not pleasant to listen to with the old driver and now it does not make me cringe to listen to it. I am using Win 10 on a dedicated desktop music computer. It did something to the sound for some odd reason.
I certainly was not expecting the usb driver to sound different. Very strange.
http://www.luxman.com/product/detail.php?id=22My Gear- Mains System-Pass X250 amp, BAT VK-51se preamp, Luxman DA-06 DAC, Magnepan 1.6's, Thorens TD-145 TT, Dual Martin Logan Subs, Vintage Luxman T-110 Tuner, Cables-WW Platinum 7 USB, Cardas Parsec XLR, AQ Columbia DBS 72v XLR, Belden 8402 XLR.
December 26, 2018, 10:47 AM #32
December 26, 2018, 11:54 AM #33
Since I'm streaming to my Luxman from the Innuos it doesn't sound like any driver updates are needed for me. Interesting that there are updates that affect the sound though only on Windows systems.
Regardless, I spent a few hours yesterday and last night tweaking my system even further and I do have to say the DA-06 is sounding absolutely amazing. It was like church last night after finally getting a few things straightened out. I am upsampling everything in Roon to DSD128 and it sounds incredibly smooth, musical, natural and lifelike. Voices have amazing imaging... I was missing the "hanging in the air" effect from my Hegel HD30.
Further tweaks may push the envelope of "audiophile" but I do not care - the sound of the system as a whole is what I'm after. Bringing in the Anthem MRX 720, I ran RCA out from the Luxman DAC into the analog input of the Anthem and did room measurements and ARC correction. I'm running the balanced XLR outs from the DAC into the 509X and running pre-outs from the Anthem into the Main/HT Bypass section of the 509X. All good quality Wireworld Eclipse interconnects. I also re-installed my front height Klipsch RP-140SA speakers on the front wall.
End result is, this allows me room-correct & EQ my SB-16 Ultra subwoofer and use the Anthem Logic:Music DSP to send a small amount of signal to the front heights, while sending a completely virgin signal from the DA-06 into the balanced line input of the 509X. I level match the La Scala IIs from the 509X with the preout signal of the Anthem, so the bass is EQ'd and the soundstage sounds 9 feet tall - absolutely massive - with the Klipsch front heights.
For movies & TV, I use the "Separate" function on the 509X to utilize the fully-EQ'd signal from the Anthem in the mains from UHD player and Apple TV.
It all sounds complicated but in practice the results are stunning.PRIMARY 2 CH SYSTEM: Backert Labs Rhythm 1.3; Parasound JC3+ Phono pre; Luxman M900u; Pure Fidelity Harmony with Origin Live Illustrious tonearm and PF Stratos cart; Naim NDX 2; Naim 555PS; Innuos Zen MK III (Roon Core); EtherRegen; Volti Audio Rivals; JL Audio e112 (2); Transparent Super Speaker Cables; Transparent Super interconnects; Transparent Premium & High Performance power cables; Naim Fraim; Stillpoints Ultra SS; Symposium Ultra platforms; IsoTek EVO3 Sigmas conditioner; GIK Acoustics absorption and diffusion panels
January 14, 2019, 05:21 PM #34
- May 2015
- Marin,Ca.
- 127
I bought the DA08 because I don't do USB, and could not be happier. The best SACD I have heard to date and an excellent DAC.
Venture Audio Grand Ultimate in Macassar Ebony, Thrax Dionysos pre, Thrax Tres mono's, Magnus MA-300 w/ MA-500 power supply, Stealth digital RCA, Acoustic Zen Absolute Silver pc's, Prana Wire Cosmos sp. cables, LG 65" OLED, ModWright modified Oppo 103D(transport), Reference Line Stage power conditioner, SME 20-2w/ Graham 2.2 tonearm, Ortofon Windfeld, Canary Audio MC10, PranaWire Linebacker, Luxman D-08 cd/sacd/dac.
February 9, 2019, 05:05 PM #35
- Jan 2018
- 26
HI Mechnutt, I pm'd you
sonus faber guarneri evolution and raidho c1.2, berkeley alpha dac 2, micro Zotl m2z preamplifier, classe cam 400 mono amps, audio note lexus speaker cables, audioquest water interconnects
Peter is...awesome. 👌 Absolutely superb and responsive customer support.
Can't Get Spoft to Play Through...
