Results 151 to 200 of 491
Thread: Magico M2
March 9, 2019, 12:20 AM #151
- Apr 2017
- Australia
- 1,758
Re: Magico M2
Actually, Mpods get screwed into a 3-point stand and the stand gets attached to the bottom of the speaker. With Spod, that is a direct fixing in the same hole as the spike that is being replaced. Magico have something called M-feet which is now the standard footer for M3. It is very similar to Spod, but much larger. Mpods and Spods are constructed differently internally.
M3 is carried by either four M-feet, or three Mpods on 3-point stand. I assume M2 is the same.
March 9, 2019, 12:35 AM #152
Re: Magico M2
Zounds. Glad I retire next month and will no longer be able to afford this stuff. It is getting to be too much for my feeble mind to keep up with.
Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
March 9, 2019, 12:40 AM #153
- Apr 2017
- Australia
- 1,758
Re: Magico M2
Huh? I thought when you retire that's when you up the spending on hobbies.
March 10, 2019, 09:45 AM #154
Re: Magico M2
If one were in the market for a new Magico speaker for a particular room size, regardless of cost, would he compare an M2 to an S3 mk2 or S5 mk 2? I think the S series generally has fewer but larger woofer drivers than the comparable M series speaker which has more and smaller woofer drivers: M3 v. S5 mk2.
Link to my system thread: https://www.whatsbestforum.com/threa...l-sound.32867/
Analog: Micro Seiki SX 8000 II, 2 NOS SME 3012R tonearms, 2 vdH Colibri Grand Cru, Colibri XPP
Electronics: Lamm LP2.1 Deluxe, Lamm LL1.1 Signature, Lamm ML2
Speakers: Vitavox CN-191 corner horns
Cables: Stock SME phono cables, DIY ICs and speaker cables, Ching Cheng power cords, custom rack and amp stands
March 10, 2019, 09:54 AM #155
Re: Magico M2
The M3 sounds noticably better than the S5 mk2. More natural and smoother, with greater tone density. The M3 tweeter is just out of this (dome) world great. Down low, I prefer the S5 mk 2 though. There is just no replacement for displacement
Adam
Speakers: Magico M3
March 10, 2019, 09:55 AM #156
Re: Magico M2
March 10, 2019, 09:55 AM #157
Re: Magico M2
March 10, 2019, 09:59 AM #158
Re: Magico M2
Thanks Mike. Do you think the M3 and S7 are designed for the same size room? And which S series speaker do you think is more appropriate for someone considering an M2? I understand that the two series have different tonal characteristics, but I am curious about room compatibility and which models one would realistically be comparing in that sense.
March 10, 2019, 10:03 AM #159
Re: Magico M2
That's interesting. Are you suggesting that Magico needs an M4/M5 to be consistently better in both the highs and lows than the S5 mk2? Do most customers prefer the lower frequencies of the S5 mk2 to those of the M3? I thought they are simply different, the S5 mk 2 being more about quantity while the M3 is more about quality. Is that wrong?
March 10, 2019, 10:04 AM #160
Re: Magico M2
The M3 fills the 20 x 25 in the store beautifully. The S5 mk2/S7 do too.
M2 would be for someone considering S3 mk2. M3 is more for someone stepping up from the S5 mk2. I’m really anxious to get my M2’s. I think in the 17 x 25 room they will sing! My hunch on the M2 is that for many, it will be THE Magico to buy.
March 11, 2019, 11:12 AM #161
- Oct 2017
- 175
Re: Magico M2
please correct me if i'm wrong, but you had the m3's singing for a little while without mpods right? the mpod vs. no mpod has been talked about before but did you have some findings to share?
i have been thinking about spods for my s5's but my biggest concern is that my furniture is low to the ground (my damned love of danish furniture) and i'm currently at a perfect level with the speaker and i worry that raising the height may lead to other issues.
March 11, 2019, 06:11 PM #162
- Apr 2017
- Australia
- 1,758
Re: Magico M2
I received the Mpods with 3 point stand about 2 months ago but I'm unable to fit them by myself. The M3 speaker is just too heavy for me to do it alone. Most customers order their M3's with Mpods and they arrive from the factory with the stand already fitted to the base of the speaker (I originally ordered my M3 without Mpods).
March 12, 2019, 09:58 AM #163
- Oct 2017
- 175
Re: Magico M2
ahh that's right. well in that case i think your thoughts are even more helpful as i'm not aware of any posters who have had such lengthy experience without the mpod - most posts i have seen have suggested that mpods were added shortly after purchase. especially curious about this since you mentioned earlier that you think the m3-q3 differential might be higher with the mpod going back to the q3 sounding "broken" in comparison comment earlier
March 12, 2019, 06:14 PM #164
- Apr 2017
- Australia
- 1,758
Re: Magico M2
My M3 are on M-feet which is an M version of the Spod. M3 used to ship with basic steel spikes. Now they ship with M-feet as standard. So I haven't heard M3 on standard spikes. I did upgrade my Q3 from standard spikes to Spods and they are worth the price of entry. Read into that my M3 on M-feet are likely to be better than earlier production M3 that had basic spikes. I'm expecting M3 will sound better on the Mpods, but not by as much as the early M3 on spikes (because my M3 are on M-feet).
March 14, 2019, 02:06 AM #165
Re: Magico M2
Magico claims the quietest enclosures in the industry. Here testing the M2 enclosure using a Laser Vibrometer.
March 14, 2019, 02:09 AM #166
- Apr 2017
- Australia
- 1,758
Re: Magico M2
I'd like to see how those measurements change with and without Mpods.
March 14, 2019, 02:49 AM #167
Re: Magico M2
I think that is a good one. Maybe a question to inquire Magico about.
March 14, 2019, 09:08 AM #168
March 14, 2019, 09:12 AM #169
- Apr 2017
- Australia
- 1,758
Re: Magico M2
Really? I thought the Mpods channeled cabinet noise into the Mpod elastomerics and dissipated it as heat?
March 14, 2019, 09:49 AM #170
Re: Magico M2
Perhaps Magico is trying to develop cabinet technology which reduces the vibrations regardless of whether it can then be drained later by the use of specific footers. I think it would be interesting to see measured efficacy of the M pods on the vibrations of the cabinet. I suspect Mágico has this data but may not be willing to share it.
March 14, 2019, 01:00 PM #171
Re: Magico M2
The MPOD measurement u all should be interested in is how much noise is eliminated on the surface they are sitting on....
"We all know real when we hear it"
March 14, 2019, 01:34 PM #172
Re: Magico M2
I agree. That would be interesting too. But, I do think it would be fascinating to measure cabinet resonance and then see how much of that resonance is drained away from the cabinet through the use of different footers. There is also isolation between the cabinet resonances and the floor. It seems the M Pods do a bit of both, draining energy out of the system and preventing it from reaching the floor.
I think testing with and without the M Pods would simply help to demonstrate how effective they are at what they do. Listening is useful too, obviously. I have heard their effect on my friend's M Pros. I was impressed.Link to my system thread: https://www.whatsbestforum.com/threa...l-sound.32867/
March 18, 2019, 07:29 PM #173
Re: Magico M2
I don't know about MPODs but IsoAcoustics Gaia feet improvements to cabinet vibrations are measurable. MPODs most likely too.
http://www.isoacoustics.com/isoacoustics-speaker-isolation-technology/1. ITX PC - Mola Mola Makua - Apollon NC800SL - Thiel CS3.7
2. LG 77C1 - Marantz SR7005 - Apollon NCMP6200 - Monitor Audio PL100+PLC150+C265 - SVS SB-3000
3. PC - RME ADI-2 DAC FS - Audeze LCDi3 - Neumann KH 80 DSP
4. Phone - TempoTec Sonata E44 - Moondrop Blessing2 Dusk
5. PC - Meizu HiFi DAC - Moondrop Chu
March 18, 2019, 08:47 PM #174
Magico M2
First pair of M2 will showing at Montreal audio show this week by Audio by MarkJonesPaul
March 18, 2019, 09:15 PM #175
- Apr 2017
- Australia
- 1,758
Re: Magico M2
I can't help but feel sad when I see a fine speaker like that end up in ridiculous installation like that.
March 18, 2019, 09:31 PM #176
March 18, 2019, 09:38 PM #177
- Apr 2017
- Australia
- 1,758
Re: Magico M2
If M2 are similar to M3 re break in, there aren't anywhere near enough 24/7 left between now and then to get them anywhere near primed for debut. Some is better than none, of course.
March 18, 2019, 10:04 PM #178
Magico M2
Hoping I can hear them soon .
March 18, 2019, 10:32 PM #179
March 18, 2019, 10:36 PM #180
March 18, 2019, 10:44 PM #181
- Apr 2017
- Australia
- 1,758
Re: Magico M2
Disagree with you on that...break-in completes the whole package that then establishes the speaker above all others. Prior to being broken-in they might just be any of a number of other speakers. But it is an audio show, so getting them out there and visible is the most important thing, even if they are under-done with break-in. They will be drooled over no matter what they sound like.
March 19, 2019, 09:11 AM #182
Re: Magico M2
March 22, 2019, 06:57 PM #183
March 22, 2019, 07:30 PM #184
Re: Magico M2
At the show now
March 22, 2019, 07:32 PM #185My Systems: http://www.audioshark.org/showthread...481#post158481
March 23, 2019, 05:09 AM #186
Magico M2
Only passive demo or what...?
March 23, 2019, 06:35 AM #187
- Apr 2017
- Australia
- 1,758
Re: Magico M2
With those electronics I should think the sound would be quite presentable, not-withstanding the newness of the speakers.
March 23, 2019, 11:21 AM #188
Re: Magico M2
Magico M2 CF box:
Adam
Speakers: Magico M3
March 23, 2019, 04:37 PM #189
Re: Magico M2
thickness of the CF box looks impressive, will be very strong
Moon 700i V2, YG Acoustics Hailey, Aurender N10, dCS Rossini, Oppo BDP103D (audiopraise board), Ansuz Mainz 8 D2
March 23, 2019, 07:44 PM #190
- Apr 2017
- Australia
- 1,758
Re: Magico M2
Presumably the M6 box is similar, and the M3 box is not?
March 23, 2019, 07:47 PM #191
Re: Magico M2
Correct.
Adam
Speakers: Magico M3
March 23, 2019, 08:26 PM #192
- Apr 2017
- Australia
- 1,758
Re: Magico M2
The top cap of the M2 cabinet is still CNC aluminium, right?
March 23, 2019, 08:48 PM #193
Re: Magico M2
March 23, 2019, 08:59 PM #194
- Apr 2017
- Australia
- 1,758
Re: Magico M2
They didn't pull the pins out of the Mpods for the show demo?
March 23, 2019, 11:27 PM #195“Life’s too short to listen to bad audio.”
March 24, 2019, 02:53 AM #196
- Apr 2017
- Australia
- 1,758
Re: Magico M2
The M3 has an internal metal skeleton similar to the Q platform.
March 24, 2019, 07:40 AM #197
Re: Magico M2
M3 have CF 'skins' over aluminium structure. It is my understanding, that when you take the drivers out and look inside, you will not see CF - all walls and bracing are aluminium.
Both M2 and M6 have what we can call 'next generation' Magico enclosures. Thay are far more advanced CF monocoque designs.Adam
Speakers: Magico M3
March 24, 2019, 07:43 AM #198
- Apr 2017
- Australia
- 1,758
Re: Magico M2
That's right. I expect M3Mk2 will evolve into the CF monocoque design, with associated weight reduction.
March 24, 2019, 11:22 AM #199
Re: Magico M2
The different construction techniques between the M2 and M3 are fascinating. I am curious about the aluminum curved top plate on the M2. Does it simply attach somehow to the curved CF box? Also, it seems as though there is a front side to the box attached with screws before the curved aluminum front baffle is attached with the long rod/bolt system first seen in the Mini 2. Is the tweeter attached to the baffle while the mid and woofer drivers are attached to the box before the front baffle is attached?
The M2's carbon fiber cabinet harks back to the birchply cabinet of the Mini with front and rear aluminum baffles clamped on with tension rods through the structure. Very different from the aluminum skeleton structure of the Q series, MPro and M3.
Thank you for posting that image of the M3 brodricj. It is the first I've seen of the M3 interior.Link to my system thread: https://www.whatsbestforum.com/threa...l-sound.32867/
March 24, 2019, 11:41 AM #200
- Oct 2017
- 175
Re: Magico M2
damn - my desire for an m2 is increasing by the day!
Upgrade on the way...
