Results 1 to 38 of 38
November 19, 2018, 08:02 PM #1
Cybershaft 10Mhz Master Clocks available (now with 50-ohm and 75-Ohm output
CYBERSHAFT now has high-quality OCXO modules of different levels again AND 3 new products;
Newly announced Cybershaft Platimum (single output 50-ohn or 75-ohm);
http://www.cybershaft.jp/a-products/ultimate1.html
or
Cybershaft Limited2 (3 output 50-ohm or 75-ohm, selectable for each!);
http://www.cybershaft.jp/a-products/limited2.html
Can be ordered in levels OP14 up to OP20 (the higher levels are likely to be rare so best order soon!).
Kenji's been VERY busy and the phase noise and jitter specs on the higher end units are off the charts!
Brand new today (19-November-2018)
New announced (today) audiophile-grade Clock Distributor (up to 3 outputs);
http://www.cybershaft.jp/a-products/clockdist01.html
*Note the addition of 50-ohm or 75-ohm as output on each individual BNC output on all of the above!
The cost these units versus the big gun offerings at much higher prices will amaze you. I'm on my 3rd one
(upgrading all the way) for very good reason.
No affiliation/commercial relationship with this company, just a very happy owner!Legacy Audio Valor+Wavelet v2, Esoteric S-02 Amps HDPlex 300W, RevAudio Labs DC Umbilical, Esoteric Grandioso P1, P1PSU & dual D1 DACs, Cybershaft Prem Ltd OP21A 10 MHz Clock, Esoteric C-02X, Shunyata Everest 8000 & Altaira SG-NR hubs, Sigma SGC/CGC ground cables, VTX-Ag ground tails, AfterBurner8 duplexes, CSP Inc Q4B, S2B IEC plates, Shunyata Omega CLOCK-50 cables, Tubulus Concentus HDMI, Elrod Master Series Diamond SE & Masters Series Gold Power cords and Statement Gold XLRs, Diamond XLRs & Master Series Diamond XLRs, Shunyata OMEGA QR-s power cable, Anaconda Z-tron XLR, Elrod Statement Gold speaker cables, Adona Zero GX3, GX2, GX racks, Composite Audio CF-2010, Townshend Audio Podiums, HRS DPX Damping Plates, Stillpoints Ultra SS w/Ultra Bases, pArtScience 64-well, 2D QRD 3-inch SpaceArray Diffusors
Travel/Rip: Apple MacBook Pro 16” 2023 M2 Max, 12-core CPU, 38-core GPU, 32 GB RAM, 1 TB SSD for Audirvana+ v3, iTunes, REW Audio Analyzer, dbPowerAmp, DVD Audio Extractor
November 20, 2018, 09:32 AM #2
- Apr 2017
- Australia
- 1,758
Re: Cybershaft 10Mhz Master Clocks available (now with 50-ohm and 75-Ohm output
I've reached out to him twice previously via his web form contact but both went unanswered.
I'm contemplating replacing G-02X with a L2.
November 20, 2018, 07:52 PM #3
Mark, Are you available for consultation? Craig
Main Equipment: Kharma Elegance dB11-S, JL Audio F113v2, Block Audio Line & Mono SE Amplification, Bricasti M21 DAC, Antipodes Kala K-50 Server, ClearAudio Performance SE, Satisfy Arm & Maestro Wood MM Cartridge
Power: 3 x 20 Amp Lines, Shunyata Everest 8000, Sigma XC v2, Shunyata Sigma v2 NR, Block Audio Power Cords, Defender, ADDPowr Wizard
Grounding: Shunyata Altaira CGS - Alpha CGS cables
Network : Supra Cat 8+, Twin (Nenon Modified) Buffalo GS2016 Switches powered with Keces P3 LPSU,
Cables: Wireworld Platinum Starlight 8 USB, Wireworld Platinum Eclipse 8 SCs, 1M & 6M Tubulus Concentus ICs,
Other: Isoacoustics GAIA I footers on the Kharmas, GIK/Vicoustics/Stillpoint Apertures, Stillpoint Ultra SS, Furutech GTX - Gold outlets, Adona Rack
November 21, 2018, 09:58 AM #4
January 18, 2019, 08:01 PM #5
- Apr 2017
- Australia
- 1,758
Still no reply from Cybershaft. 3 webform contacts now, no response (other than a system generated reply).
January 18, 2019, 08:16 PM #6
Cybershaft is a small company with the principal, Kenji Hasegawa doing most tasks. It is worth being persistent. I couldn’t be happier with my Cybershaft OP 17 clock.
If you have had no exposure to the Japanese culture, soft/gentle/polite persistence should be rewarded. I might suggest you mention Bob, SCAudiophile in your message to Hasegawa-San.
CraigMain Equipment: Kharma Elegance dB11-S, JL Audio F113v2, Block Audio Line & Mono SE Amplification, Bricasti M21 DAC, Antipodes Kala K-50 Server, ClearAudio Performance SE, Satisfy Arm & Maestro Wood MM Cartridge
January 18, 2019, 08:18 PM #7
- Apr 2017
- Australia
- 1,758
3 attempts over 6 months or so, the effort required should not be more than that.
I just had a simple question. What OP level would be similar performance to Esoteric G1.
January 18, 2019, 09:00 PM #8
Sorry. My experience was great.
January 18, 2019, 09:26 PM #9
I believe I have mentioned here but am sure I've mentioned on other forums where many here participate that the web form is for
some reason not working or at least not reliable in my experience. Please send to this email address and mention Craig (Crwilli)
and Mark (SCAudiophile).
hasagawa@cybershaft.jp
and as a backup cc:
cybershaft777@yahoo.co.jp
Others who had needed help have PM'ed me direct and I get on the phone or email directly and get them in contact one
way or the other.
The answer to your question (IMHO, you should still ask Kenji) is that with an OP17 and certainly above that, you will equal the
measured performance of the G1 for a fraction of the price.Legacy Audio Valor+Wavelet v2, Esoteric S-02 Amps HDPlex 300W, RevAudio Labs DC Umbilical, Esoteric Grandioso P1, P1PSU & dual D1 DACs, Cybershaft Prem Ltd OP21A 10 MHz Clock, Esoteric C-02X, Shunyata Everest 8000 & Altaira SG-NR hubs, Sigma SGC/CGC ground cables, VTX-Ag ground tails, AfterBurner8 duplexes, CSP Inc Q4B, S2B IEC plates, Shunyata Omega CLOCK-50 cables, Tubulus Concentus HDMI, Elrod Master Series Diamond SE & Masters Series Gold Power cords and Statement Gold XLRs, Diamond XLRs & Master Series Diamond XLRs, Shunyata OMEGA QR-s power cable, Anaconda Z-tron XLR, Elrod Statement Gold speaker cables, Adona Zero GX3, GX2, GX racks, Composite Audio CF-2010, Townshend Audio Podiums, HRS DPX Damping Plates, Stillpoints Ultra SS w/Ultra Bases, pArtScience 64-well, 2D QRD 3-inch SpaceArray Diffusors
January 18, 2019, 09:50 PM #10
- Apr 2017
- Australia
- 1,758
Can a single output Cybershaft sync P1 + D1? I'm thinking connect clock to P1, connect P1 clock out to D1, and it will sync with the other D1 via ESLINK.
January 18, 2019, 11:43 PM #11
Yes, that is how I have my D02 and P02 daisy-chained for some time now however I go from Cybershaft into D02 then out to P01. I plan on going to D1's later this year and will go clock->D1->D1->P02 and later P1 when I upgrade that. On advice from both Kenji at Cybershaft and Caelin at Shunyata (I'm using their SIGMA CLOCK50 BNC cables) I use proper 50-ohm terminators and Tee connectors.
January 19, 2019, 02:09 AM #12
- Apr 2017
- Australia
- 1,758
If you want D1 and P1 you'd better be quick, Esoteric aren't building them any more. The only ones available are dealer stock, and very few dealers will keep a Grandioso in stock.
January 19, 2019, 09:10 AM #13
Good point,...my D1s are on layaway and already set aside for final purchase later this year. As for the P1 when it's time I'll gladly pick up a dealer demo. The X series are potentially compelling but I already love what I hear with the existing Grandioso P1/D1 combo (and C1 pre-amp) so that will frankly be 'top of the world heap' enough for me to be happy for the next 5-10 years. The X probably won't hit the street in the US until much later into 2019 and the price is likely to be a big jump here in the US so frankly the P1/D1 are what I'm looking for.
BTW...if you still want some help getting in touch with Cybershaft, send me a PM with your email address and I'll send him a note and make an intro as I did with Craig and others.Legacy Audio Valor+Wavelet v2, Esoteric S-02 Amps HDPlex 300W, RevAudio Labs DC Umbilical, Esoteric Grandioso P1, P1PSU & dual D1 DACs, Cybershaft Prem Ltd OP21A 10 MHz Clock, Esoteric C-02X, Shunyata Everest 8000 & Altaira SG-NR hubs, Sigma SGC/CGC ground cables, VTX-Ag ground tails, AfterBurner8 duplexes, CSP Inc Q4B, S2B IEC plates, Shunyata Omega CLOCK-50 cables, Tubulus Concentus HDMI, Elrod Master Series Diamond SE & Masters Series Gold Power cords and Statement Gold XLRs, Diamond XLRs & Master Series Diamond XLRs, Shunyata OMEGA QR-s power cable, Anaconda Z-tron XLR, Elrod Statement Gold speaker cables, Adona Zero GX3, GX2, GX racks, Composite Audio CF-2010, Townshend Audio Podiums, HRS DPX Damping Plates, Stillpoints Ultra SS w/Ultra Bases, pArtScience 64-well, 2D QRD 3-inch SpaceArray Diffusors
January 19, 2019, 09:14 AM #14
- Apr 2017
- Australia
- 1,758
My dealer has quoted me on both P1 and P1X. P1 for immediate delivery and P1X for February delivery. The price difference between the 2 is considerable (P1X is >50% more expensive than P1).
January 20, 2019, 08:59 AM #15
Where are you located? I had been told the P1X and D1X would not arrive in US until much later this year so I'm guessing that you live elsewhere (?)
The price difference (in US) is supposed to be a substantial amount above the current P1/D1 US pricing so probably out of reach for sure for me until these units start to hit
the used market some years from now (or I decide to fly to Japan and go with grey market to get more realistic pricing as I have friends there that can help me if ever there
were a warranty claim to be filed). I've always found Esoteric markup here in the US with the selling endpoint inflexibility with discount to be somewhat obscene, same with
Accuphase. Other geographies get these products for much more reasonable (but still high and reflective of their quality) pricing and the dealers and distributors seem to do
just fine; this is also a result of import pricing/duties/taxes here so it's really no one's fault per se.Legacy Audio Valor+Wavelet v2, Esoteric S-02 Amps HDPlex 300W, RevAudio Labs DC Umbilical, Esoteric Grandioso P1, P1PSU & dual D1 DACs, Cybershaft Prem Ltd OP21A 10 MHz Clock, Esoteric C-02X, Shunyata Everest 8000 & Altaira SG-NR hubs, Sigma SGC/CGC ground cables, VTX-Ag ground tails, AfterBurner8 duplexes, CSP Inc Q4B, S2B IEC plates, Shunyata Omega CLOCK-50 cables, Tubulus Concentus HDMI, Elrod Master Series Diamond SE & Masters Series Gold Power cords and Statement Gold XLRs, Diamond XLRs & Master Series Diamond XLRs, Shunyata OMEGA QR-s power cable, Anaconda Z-tron XLR, Elrod Statement Gold speaker cables, Adona Zero GX3, GX2, GX racks, Composite Audio CF-2010, Townshend Audio Podiums, HRS DPX Damping Plates, Stillpoints Ultra SS w/Ultra Bases, pArtScience 64-well, 2D QRD 3-inch SpaceArray Diffusors
January 21, 2019, 08:16 AM #16
- Apr 2017
- Australia
- 1,758
What taxes on an Esoteric would be due on arrival in the US via private import?
BTW Accuphase is a brand that has very sensible pricing in Australia.
I have indirect access via dealer to Esoteric in Japan and I've been assured from Japan side late February/early March for 230V P1X/D1X. I'm likely to settle on P1 now and D1X later.
January 21, 2019, 09:39 AM #17
October 14, 2019, 10:11 PM #18
How does one order a Cybershaft digital clock? The Cybershaft web site is entirely in Japanese.
October 15, 2019, 01:28 AM #19
http://www.cybershaft.jp/overseas01.html
Speakers: Wilson Alexias
October 15, 2019, 05:31 PM #20
Yes...that's it. Additional notes;
- use Google Chrome, it will help translate the other parts of the site
- they often get involved in build & test work and this can influence email response time since it's basically one many doing the most critical portions of the work
- these email addresses work;
hasegawa@cybershaft.jp
*The Inquiry Form at the link above works too but I've always followed it up with an email just in case.
Right now there are lower to mid-price new units offered in the more accessible cost categories. I"m told there may be news soon of new models and high-end OCXO grades.Legacy Audio Valor+Wavelet v2, Esoteric S-02 Amps HDPlex 300W, RevAudio Labs DC Umbilical, Esoteric Grandioso P1, P1PSU & dual D1 DACs, Cybershaft Prem Ltd OP21A 10 MHz Clock, Esoteric C-02X, Shunyata Everest 8000 & Altaira SG-NR hubs, Sigma SGC/CGC ground cables, VTX-Ag ground tails, AfterBurner8 duplexes, CSP Inc Q4B, S2B IEC plates, Shunyata Omega CLOCK-50 cables, Tubulus Concentus HDMI, Elrod Master Series Diamond SE & Masters Series Gold Power cords and Statement Gold XLRs, Diamond XLRs & Master Series Diamond XLRs, Shunyata OMEGA QR-s power cable, Anaconda Z-tron XLR, Elrod Statement Gold speaker cables, Adona Zero GX3, GX2, GX racks, Composite Audio CF-2010, Townshend Audio Podiums, HRS DPX Damping Plates, Stillpoints Ultra SS w/Ultra Bases, pArtScience 64-well, 2D QRD 3-inch SpaceArray Diffusors
October 15, 2019, 10:41 PM #21
October 15, 2019, 11:52 PM #22
I'm really wondering what a clock like CyberShaft will do to etherREGEN?
Anyone know a price range?Source Analog: Kuzma Stabi R w/4point 11 arm | Kuzma 50 Cartridge
October 16, 2019, 12:06 AM #23
October 16, 2019, 09:25 AM #24
It will take some thought before purchasing a Shunyata Clock Cable that could easily cost more then this switch.
Mark, What specs would you look at to make an educated guess on whether an external clock would be better than the internal clock in the EtherReGen?Main Equipment: Kharma Elegance dB11-S, JL Audio F113v2, Block Audio Line & Mono SE Amplification, Bricasti M21 DAC, Antipodes Kala K-50 Server, ClearAudio Performance SE, Satisfy Arm & Maestro Wood MM Cartridge
October 16, 2019, 10:53 AM #25
October 16, 2019, 11:01 AM #26
October 16, 2019, 12:20 PM #27
October 18, 2019, 08:52 PM #28
October 18, 2019, 08:55 PM #29
On the home page (using Google Chrome for translation) the new models Platinum2, Soul2 and Espirit are listed on the left hand side. Click on those.
If I heard correctly there may also be some new product introduction very soon but watch the website for anything new that is offered.Legacy Audio Valor+Wavelet v2, Esoteric S-02 Amps HDPlex 300W, RevAudio Labs DC Umbilical, Esoteric Grandioso P1, P1PSU & dual D1 DACs, Cybershaft Prem Ltd OP21A 10 MHz Clock, Esoteric C-02X, Shunyata Everest 8000 & Altaira SG-NR hubs, Sigma SGC/CGC ground cables, VTX-Ag ground tails, AfterBurner8 duplexes, CSP Inc Q4B, S2B IEC plates, Shunyata Omega CLOCK-50 cables, Tubulus Concentus HDMI, Elrod Master Series Diamond SE & Masters Series Gold Power cords and Statement Gold XLRs, Diamond XLRs & Master Series Diamond XLRs, Shunyata OMEGA QR-s power cable, Anaconda Z-tron XLR, Elrod Statement Gold speaker cables, Adona Zero GX3, GX2, GX racks, Composite Audio CF-2010, Townshend Audio Podiums, HRS DPX Damping Plates, Stillpoints Ultra SS w/Ultra Bases, pArtScience 64-well, 2D QRD 3-inch SpaceArray Diffusors
October 18, 2019, 10:29 PM #30
October 20, 2019, 05:45 PM #31
November 6, 2019, 10:59 AM #32
NEW PRODUCT JUST ANNOUNCED TODAY:
Cybershaft 10 M clocks : UPOCXO-OP20A/OP21A
http://www.cybershaft.jp/a-products/op20a.html
Looks like the bar just got raised again.Legacy Audio Valor+Wavelet v2, Esoteric S-02 Amps HDPlex 300W, RevAudio Labs DC Umbilical, Esoteric Grandioso P1, P1PSU & dual D1 DACs, Cybershaft Prem Ltd OP21A 10 MHz Clock, Esoteric C-02X, Shunyata Everest 8000 & Altaira SG-NR hubs, Sigma SGC/CGC ground cables, VTX-Ag ground tails, AfterBurner8 duplexes, CSP Inc Q4B, S2B IEC plates, Shunyata Omega CLOCK-50 cables, Tubulus Concentus HDMI, Elrod Master Series Diamond SE & Masters Series Gold Power cords and Statement Gold XLRs, Diamond XLRs & Master Series Diamond XLRs, Shunyata OMEGA QR-s power cable, Anaconda Z-tron XLR, Elrod Statement Gold speaker cables, Adona Zero GX3, GX2, GX racks, Composite Audio CF-2010, Townshend Audio Podiums, HRS DPX Damping Plates, Stillpoints Ultra SS w/Ultra Bases, pArtScience 64-well, 2D QRD 3-inch SpaceArray Diffusors
November 6, 2019, 12:52 PM #33
- Apr 2017
- Australia
- 1,758
Pricey. OP21A is about half the price of the Grandioso G1?
November 6, 2019, 01:18 PM #34
I do not think you mathematics are correct on this;
Grandioso G1 Price (2019 USA): $26,000 (More in AUS/other parts of the world I think)
OP21A level new Cybershaft clock: 743,700 JPY in USD, $6827 (OANDA FX as of a few minutes ago)
Definitely not 1/2 the price of the G1 even with FX variation.
Question is,...how is the performance of one versus the other?Legacy Audio Valor+Wavelet v2, Esoteric S-02 Amps HDPlex 300W, RevAudio Labs DC Umbilical, Esoteric Grandioso P1, P1PSU & dual D1 DACs, Cybershaft Prem Ltd OP21A 10 MHz Clock, Esoteric C-02X, Shunyata Everest 8000 & Altaira SG-NR hubs, Sigma SGC/CGC ground cables, VTX-Ag ground tails, AfterBurner8 duplexes, CSP Inc Q4B, S2B IEC plates, Shunyata Omega CLOCK-50 cables, Tubulus Concentus HDMI, Elrod Master Series Diamond SE & Masters Series Gold Power cords and Statement Gold XLRs, Diamond XLRs & Master Series Diamond XLRs, Shunyata OMEGA QR-s power cable, Anaconda Z-tron XLR, Elrod Statement Gold speaker cables, Adona Zero GX3, GX2, GX racks, Composite Audio CF-2010, Townshend Audio Podiums, HRS DPX Damping Plates, Stillpoints Ultra SS w/Ultra Bases, pArtScience 64-well, 2D QRD 3-inch SpaceArray Diffusors
November 6, 2019, 01:21 PM #35
- Apr 2017
- Australia
- 1,758
Grandioso G1 price in USA ($26,000 + tax) is far more expensive that AUS price ($19,269 incl tax).
November 6, 2019, 01:29 PM #36
Good to know thanks....had heard from a friend who bought D1s that they were more in Oz but I could have heard incorrectly.
So you are correct for AUS$ which is not as favorable against the JPY, it's about 50% of the AUS$ price of the G1.
I haven't heard this unit and did not hear about it factually until late last night,...I'm dying to know how it stacks up and performs
but if it is at least as good (and probably better) than my current OP21, in side by side, it will definitely win the comparison here (all FWIW, IMHO).Legacy Audio Valor+Wavelet v2, Esoteric S-02 Amps HDPlex 300W, RevAudio Labs DC Umbilical, Esoteric Grandioso P1, P1PSU & dual D1 DACs, Cybershaft Prem Ltd OP21A 10 MHz Clock, Esoteric C-02X, Shunyata Everest 8000 & Altaira SG-NR hubs, Sigma SGC/CGC ground cables, VTX-Ag ground tails, AfterBurner8 duplexes, CSP Inc Q4B, S2B IEC plates, Shunyata Omega CLOCK-50 cables, Tubulus Concentus HDMI, Elrod Master Series Diamond SE & Masters Series Gold Power cords and Statement Gold XLRs, Diamond XLRs & Master Series Diamond XLRs, Shunyata OMEGA QR-s power cable, Anaconda Z-tron XLR, Elrod Statement Gold speaker cables, Adona Zero GX3, GX2, GX racks, Composite Audio CF-2010, Townshend Audio Podiums, HRS DPX Damping Plates, Stillpoints Ultra SS w/Ultra Bases, pArtScience 64-well, 2D QRD 3-inch SpaceArray Diffusors
November 6, 2019, 01:34 PM #37
- Apr 2017
- Australia
- 1,758
Dealers in AUS sell used G1 for $13,757 incl tax, and you can usually get another 10% knocked off that price.
November 6, 2019, 02:12 PM #38
