Results 1 to 48 of 48
Thread: New amp, couple of pics....
October 23, 2018, 06:23 AM #1
[ATTACH=CONFIG]23987[/ATTACH]
October 23, 2018, 07:21 AM #2
Re: New amp, couple of pics....
Very cool!
George
October 23, 2018, 08:06 AM #3
- Feb 2016
- west Michigan
- 713
VERY nice looking amplifier. SET with power, that's nice.
What are your initial impressions of it's sonic signature?
As an added bonus you get to heat your audio room with it this winter.My System
Acoustic Revive RTP-4
Innuos Pulsar
Lampizator BALTIC4
Cary SLP-05
Pass XA30.5 or
Line Magnetic 845ia
Reference 3A Reflector's
Pr SVS SB3000 Subs
Core Audio Design Rack
October 23, 2018, 11:13 AM #4
Congrats Kev. Pretty!
Sent from my iPad using TapatalkMy Systems: http://www.audioshark.org/showthread...481#post158481
October 23, 2018, 01:22 PM #5
Congratulations with your new amplifier , looks cool
Flemming
Lumin X1
Rotel Michi S5
Focus Audio FS788
LS cable : Yter
Nordost QB8
Rack : Finite Elemente Pagode
October 23, 2018, 06:04 PM #6
Very cool. It's integrated? Will you drive it external or use the internal volume.
October 23, 2018, 07:26 PM #7
Made in Cypress?
How does it sound in your system?
Same maker of the $90k Kassandra DAC?Le Roy
Foundation:
October 24, 2018, 03:33 AM #8
This amp is not the integrated. It's the Diana Forte power amp.
It doesn't matter what system this amp is in, ... it is the best sounding amp I have had the pleasure of ever. Either owning, which I do or listening. As soon as I heard this I knew I am done with Soulution. The immediacy, prat, timing & absolute seperation is so scary as you sit there & bath in it. I haven't once thought about the tone or pitch after 3 listening sessions. Every time I have worried about the neighbors. Joe, I promise, this is the shizz....
October 24, 2018, 03:40 AM #9
October 24, 2018, 10:42 AM #10
So you bought the amp pre amp and DAC? I so want a SET amp. I wish I could play in that League. I probably have to buy a Decwear.
Let us know how it sounds. It would also be interesting what it's like with that DartZeel fronting itFirst Sound Mark3SI preamp. Audion Black Shadow 845 SET Monoblocks. Mojo Audio Deja Vu Server. Mojo Audio Mystic 3 DAC. Linear Solution Ethernet Switch. Gigafoil with LPS. STST Motus II TT with Vertere SG1 arm, Hana ML Cartridge, Allnic H1201 phono pre. Pure Audio Project Trio 15 Horn speakers with Mundord Supreme oil caps. Power via 10 awg Oyaide cable from panel to custom distribution strip feeding front end. Oyaide dedicated10 AWG branch circuits from panel to each amp. Inakustik speaker and interconnect cables, Genesis Interconnect.
October 25, 2018, 04:33 AM #11
No I bought the amp.
October 25, 2018, 06:18 AM #12
Hey Kev
What speakers do you run with these? I can't keep upSource: Technics SP10mk3 - Thales Simplicity II, TW Raven AC-3 - Graham Phantom, SME 3012-R, Exclusive P3,,Linn LP12 - Naim ARO
EQ: DEQX HDP-4
Speakers: Wilson Maxx3
October 25, 2018, 08:04 AM #13
Outstanding Kev. That’s supposed to be a killer amp. OMG! I’d love to hear it.
ps, I totally believe you and understand. There’s nothing like a properly designed SET amp. I’m so happy for you.Last edited by joeinid; October 25, 2018 at 08:26 AM.
October 25, 2018, 09:49 AM #14
Are you feeding it with the synco?
October 26, 2018, 03:59 AM #15
October 26, 2018, 04:00 AM #16
October 26, 2018, 04:03 AM #17
October 26, 2018, 04:03 AM #18
October 26, 2018, 06:00 PM #19
EQ: DEQX HDP-4
October 26, 2018, 06:25 PM #20
Joe, are you one of the people who has done some comparisons with the spatial and pure audio project. I have the tree of 15 and Trio 10 pure audio project. I believe I'm having some issues with my amps and I've been looking for something new. From what you're saying this amp works extremely well with an open baffle design. Is there any chance you have tried other single-ended amps that you like. Something more in the four to $5,000 range
October 26, 2018, 06:37 PM #21
Kev,
Sorry for going off topic.
I'm sorry, I have not listened to the Spatials or Pure Audio Project speakers. I've been reading and looking at them for a while. I know Jack has Spatials and Mike had early Spatials. I know Jack loves his.
I am just getting into SET now. I have Avantgarde Duo XD on order and it should be a few more days. Many years ago I had George Wright 2A3 amps and loved them but only had bookshelf Klipsch at the time. They were/are over-rated in the sensitivity department and those amps were barely enough at the time.
I've heard a limited few SET amps since them and just recently jumped in with the Luxman MQ-300. Sadly over that budget limit.
I fell in love with Bastanis speakers driven by Whammerdyne.
This exact setup in fact.
October 26, 2018, 06:58 PM #22
- May 2013
- 3,242
I would reach out to Doug Schroeder about compatible amps as he has assembled and reviewed multiple versions of them. I found with two versions of the Spatial's that the efficiency specs are a bit misleading as they are from 200hz and up.
October 26, 2018, 09:18 PM #23
October 26, 2018, 09:19 PM #24
Joe, the derail doesn't bother me.
October 26, 2018, 10:00 PM #25Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
October 26, 2018, 10:03 PM #26
October 26, 2018, 10:10 PM #27
October 27, 2018, 04:42 AM #28
They're on the back lawn... the neighbor said no way I'm not buying that shit, look at the colour of it!!
October 27, 2018, 05:02 AM #29
November 7, 2018, 06:20 PM #30
Congratz on the new amp. I have become enthralled with SET recently. There is just something about the sound that sucks you in ... Such absolute separation, rich smooth sounding... all instruments just seem to be there... one thing I love is that I feel I can hear not only the instrument, but can tell what type of material is being used... I can tell that the performer is using a very special piano, for example... loving SET at this point... plenty of power for my KEFs!
And my SET amps are not even in the same world as yours... so I can only imagine the sound coming from your new amp!!!McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
― Neil deGrasse Tyson
November 8, 2018, 11:53 PM #31
- Sep 2015
- 167
That amp is a beast!
January 6, 2019, 03:13 AM #32
yes it is, heavy too....
January 6, 2019, 05:32 AM #33
Kev,
Just seen this update. Congrats on the Aries Cerat amp. What a beast. A 60W SET.
Are spare tubes difficult to source? I know those big guys are not exactly mainstream.
Does it party in the bass department or this more of a midrange epiphany?
And does this mean you have plans to change out your loudspeakers too?
At least I can now see the reason for having such a solid rack. Future planning. Clever bugger!Borresen Acoustics Loudspeakers, Borresen Model 01 Compact monitor loudspeakers with Ansuz Darkz T2s Supreme resonance control, Audio Video Manufaktur GmbH (AVM) Inspiration amplifier & streamer, Innuos Zen MKII music server, Ansuz Acoustics cables & accessories. Please visit my system thread hosted on Audioshark for more details. Disclosure: The author is materially connected to Ansuz, Aavik & Borresen Acoustics via friendship with an owner.
January 11, 2019, 10:04 AM #34
- Jan 2017
- Leyden
- 596
I've once heard a Aries Cerat amp. If I remember correctly it was an integrated amp. Also using Aries Cerat DAC driving stenheim alumine 2 speakers. One of the best sounding distributors at the show.
But the distributor didn't not expect to sell any Aries Cerat amps or Stenheim speakers in Western Europe because of the price and the size.Pre amp: Ocatve Phono Module Power amps: Octave MRE130 Turntable: SAC Girati Grande. Tonearm: Dynavector 507mkII Cartridge: Dynavector Ikeda 9TT Streamer: Aurender A10 Power Distributor: Anzus Mains D8 Speakers: Raidho X-3 Speaker Cables: AudioQuest Rocket 88 XLR Interlink: Ansuz A2, [B]XLR Interlink: [B]Phono interlink: Cammino Serie 1.0 - PH 1.0s Power cables: Anzus Mains Ceramic, two Pom, Aluminium, X series Audio Rack: Rack of Silence 4 and 2.
January 11, 2019, 10:06 AM #35
- Sep 2015
- 167
I would of thought a good match.
The Aries cerat for the performance is quite reasonably priced imo
January 11, 2019, 01:08 PM #36
I thought my 3 year old lease returned Porsche Cayman S with PDK and leather was a good deal too, and cost less. 😊
January 12, 2019, 05:19 AM #37
January 12, 2019, 05:21 AM #38
January 12, 2019, 06:52 AM #39
January 12, 2019, 11:46 AM #40
I spent $47k USA out the door with 2 years Porsche warranty. Bought it from a dealer.
I am envious of your amp. I do love music. The car is really my wife's daily driver. I have the Mercedes ML550.
January 13, 2019, 03:50 AM #41
January 13, 2019, 07:31 AM #42
- Jan 2017
- Leyden
- 596
January 13, 2019, 07:33 AM #43
- Sep 2015
- 167
Hmm depends where you live I guess.
If no local dealers then your right its hard to demo.
January 13, 2019, 07:35 AM #44
- Sep 2015
- 167
Not quite sure i understand what you mean by “unknown brand”
Its been around for a while. Was watching a video from munich 2014 the other day. With Aries cerat.
Also they were at munich in 2010 i believe w Tune Audio
January 14, 2019, 06:46 AM #45
- Jan 2017
- Leyden
- 596
I'm Dutch there has never been a Dutch distributor or dealer as far as I know. In the last 20 years I've only seen them at 1 Dutch audio show. That makes them IMHO pretty unknown.
If a shop wants to become a dealer/distributor of the brand you need some stock. People want to see and hear before they buy. That means an 10-40k investment that is a lot of money for something that you might never sell.Pre amp: Ocatve Phono Module Power amps: Octave MRE130 Turntable: SAC Girati Grande. Tonearm: Dynavector 507mkII Cartridge: Dynavector Ikeda 9TT Streamer: Aurender A10 Power Distributor: Anzus Mains D8 Speakers: Raidho X-3 Speaker Cables: AudioQuest Rocket 88 XLR Interlink: Ansuz A2, [B]XLR Interlink: [B]Phono interlink: Cammino Serie 1.0 - PH 1.0s Power cables: Anzus Mains Ceramic, two Pom, Aluminium, X series Audio Rack: Rack of Silence 4 and 2.
March 26, 2019, 03:25 AM #46
March 26, 2019, 04:39 AM #47
March 27, 2019, 03:10 AM #48
feeling a bit horny.... with the integrated....
heard the large ones twice, pretty nice
Clarisys - Axpona 2024
