Results 1 to 20 of 20
Thread: Power cable annoyance?
September 29, 2018, 02:00 PM #1
Anyone here have this annoyance whereby the shear weight of your power cable slightly drops down from the back of your component? I was recently adjusting some cables behind my pre and I accidentally touched my power cable and my pre turned off. It's due to the male end of the power cord that doesn't sit snuggley into the pre horizontally. I could try to support that end with a piece of wood or something?
I found this on youtube...I wish more manufactures would offer this Neutrik option for their power cords.
Anyone else have this annoyance? Don't move cables around while pre is on?
btw...I'm using Kimber Ascent pc'sMcIntosh - PMC - Aurender - Kimber Kable - WW - Core Audio Designs
September 29, 2018, 02:06 PM #2
Re: Power cable annoyance?
Or you could just flip the outlet upside down....
Works like a charm and it’s free.My Systems: http://www.audioshark.org/showthread...481#post158481
September 29, 2018, 02:10 PM #3
How about at the other end.... at your preamp etc. ?
September 29, 2018, 02:12 PM #4
September 29, 2018, 02:24 PM #5
- Apr 2013
- 259
While an expensive "solution" the Furutech NCF Booster products are perfect for that. I use them for MSB as my Gobel's plugs keep falling out. It works great. Not going to claim that they have a huge effect on the "sound" as I will let others speak to that.
http://www.furutech.com/products/ncf-booster-products/
September 29, 2018, 02:45 PM #6
September 30, 2018, 10:13 AM #7
I have talked about this before on multiple forums. We always have 'solutions' in search of a problem in this hobby, and sometimes those 'solutions' require yet again another 'solution' to help correct the first 'solution.' Building power cables with massive connectors that won't plug in correctly to your IEC outlet on your gear is a problem. The massive connectors always want to come out of the connection because they can't seat correctly because of their weight. Same thing on the wall plug side. The connectors always want to come out of the wall outlet. I have seen countless pictures like yours that show this happening. So now we have cable bras that will elevate your cables at the connection points and try to keep the cable straight at the connection points.
Meanwhile back at the ranch, there are lots of people with heavy expensive cables that are barely making a connection at both ends and yet the buyers swoon about how great the new cable sounds that's barely making electrical contact.Micro Seiki SX-8000 air bearing table, SME 312s arm, SME 3012R arn, Dynavector XV-1s cartridge, Lyra Etna SL cartridge, ARC Ref 3 phono stage, Otari MX-55 2 track R2R, Ampex 350 tape repros, Roon Nucleus Plus music server, HiFi Rose 150B DAC, ARC Ref 6, ARC Ref 75 with KT-150s, Parasound JC5 amp , JBL 4345 speakers, Viero Equilibro Level 3 speaker cables, and Definitive Technology Ref subs.
December 5, 2018, 06:08 PM #8
- Jun 2017
- 77
This has become one of my pet peeves in life. So I will mention two cables that I have used that are great in this regard - the Sablons are almost astonishingly flexible given their AWG, and I also have some Zu Events that are quite decent in this regard. I have sworn off ludicrously stiff cables, end of story. Everything starts with making a good connection, and if the freakin' thing is half out of your outlet or IEC due to its weight or inflexibility than IMHO that is a basic design criterion that has been ignored.
Main system: PS Audio P5, CAPS server w/HDPlex power supply, Hegel H160, AQ Colorado and Rocket 44, Vandersteen Treos, PS Audio DS DAC. NAD M4 tuner, Mcintosh MR74. Analog: Bryston BLP1, Ortofon Quintet Black, customized Tavish Adagio phono pre. AudioSensibility Statement interconnects. Rythmik Audio 15-inch sub. Other stuff: Sequerra Met 7's (original) Met 7 MK. II, REL Q108, Berning ea-230's, Micro Seiki BL51 with Grace and Rega arms. Too much else to list, I am gonna leave a heck of a pile of stuff when I die.
December 5, 2018, 07:12 PM #9
The NCF booster was invented for the very problem the OP is suffering.
Clearaudio Master Innovation + Linear Power Supply | DS Audio Master1 Cartridge System | CAD CAT Transport | CAD 5413 MKII DAC | Soulution 520 Preamplifier | Soulution 711 Power Amplifier | Maxonic TW1200 Speakers | PS Audio P20 | Tellurium Q Statement Cabling | Furutech NCF Booster + Booster Signals | CAD GC1 Ground Controls | A Chair
December 5, 2018, 08:41 PM #10
December 5, 2018, 11:55 PM #11
- Apr 2015
- 634
I use stock power chords. For some weird reason I never seem to have problems.
December 6, 2018, 05:05 AM #12Clearaudio Master Innovation + Linear Power Supply | DS Audio Master1 Cartridge System | CAD CAT Transport | CAD 5413 MKII DAC | Soulution 520 Preamplifier | Soulution 711 Power Amplifier | Maxonic TW1200 Speakers | PS Audio P20 | Tellurium Q Statement Cabling | Furutech NCF Booster + Booster Signals | CAD GC1 Ground Controls | A Chair
December 6, 2018, 09:11 AM #13
- Feb 2016
- west Michigan
- 713
I made these. Found some brass discs at the local salvage yard. Used stainless steel bolts and nuts, The green pieces are pipe clamp/supports. Sprayed the base with rubber coating and applied self stick non-slip rubber pad on bottom. Works great. cost about $10 ea.My System
Acoustic Revive RTP-4
Innuos Pulsar
Lampizator BALTIC4
Cary SLP-05
Pass XA30.5 or
Line Magnetic 845ia
Reference 3A Reflector's
Pr SVS SB3000 Subs
Core Audio Design Rack
December 6, 2018, 09:28 AM #14
- Feb 2016
- west Michigan
- 713
Front view. Sorry for the sideways pics. don't know how to correctMy System
Innuos Pulsar
Lampizator BALTIC4
Cary SLP-05
Pass XA30.5 or
Line Magnetic 845ia
Pr SVS SB3000 Subs
December 6, 2018, 10:11 AM #15
- Apr 2013
- 259
December 6, 2018, 08:53 PM #16
I use the foam plugs that come to block speaker ports to support the heavy ones.
Brian
December 7, 2018, 02:23 PM #17
December 7, 2018, 02:25 PM #18
December 7, 2018, 07:04 PM #19
I use aerospace technology to raise the telegartner connector of my Göbel cable
Francisco
March 26, 2019, 10:40 AM #20
trying out a new power cord... good thing we saved the set of building blocks.
btw: do these massive IEC / power connectors provide any benefit? I opened up the connector and the functional assembly where the wires are screwed to the prongs is rather small in comparison. maybe the large mass provides some type resonance damping? maybe it makes things worse because of the insecure connection?
can't imagine any nano-benefit is worth the PINTA -- ymmv.viking acoustics berlin r mk2 | air tight atc-5 + atm-300r | clearaudio concept + virtuoso v2 MM | t+a dac8 dsd + kanjiroba diy transport + roon rock
The original BD "Dunkirk" has a known defect where the audio cuts out on loud battle scenes. It's been corrected on the 4k version. I've had maybe 1% defective discs out of about 500 or so,...
Has anybody here received NEW...
