Results 1 to 25 of 25
Thread: Racks that don't break the bank
September 25, 2018, 09:16 AM #1
- Jan 2017
- Leyden
- 596
I was looking to replace my SolidSteel rack and buy a separate rack for my power amps.
First I was looking at QuadraSpire but my power amps are 50cm wide, that is too wide for the QuadraSpire. Next I was looking at he Finite Elemente Tragwerk but they are not available anymore.
There are lots of brands but most are very expensive. Also I don't want some black monstrosity. Preferably I want white wooden platters. I want the platter to be max 20cm from each other. So now I'm looking at Creaktiv racks, the Audio line. But for some reason I don't really like them. The Creaktive Little reference looks better but is too expensive.
Any tips. Most shops seem to sell Bassocontinuo their least expensive model is semi affordable but is ugly. They have better looking models but price go up very fast.
I don't understand why the racks need to be so expensive.
Anyone with some tips?Pre amp: Ocatve Phono Module Power amps: Octave MRE130 Turntable: SAC Girati Grande. Tonearm: Dynavector 507mkII Cartridge: Dynavector Ikeda 9TT Streamer: Aurender A10 Power Distributor: Anzus Mains D8 Speakers: Raidho X-3 Speaker Cables: AudioQuest Rocket 88 XLR Interlink: Ansuz A2, [B]XLR Interlink: [B]Phono interlink: Cammino Serie 1.0 - PH 1.0s Power cables: Anzus Mains Ceramic, two Pom, Aluminium, X series Audio Rack: Rack of Silence 4 and 2.
September 25, 2018, 09:18 AM #2
- Jan 2017
- Leyden
- 596
Re: Racks that don't break the bank
Edit:
To safe space I want to stack my power amps. So I need a rack with two platters and about 20/25cm in between.Pre amp: Ocatve Phono Module Power amps: Octave MRE130 Turntable: SAC Girati Grande. Tonearm: Dynavector 507mkII Cartridge: Dynavector Ikeda 9TT Streamer: Aurender A10 Power Distributor: Anzus Mains D8 Speakers: Raidho X-3 Speaker Cables: AudioQuest Rocket 88 XLR Interlink: Ansuz A2, [B]XLR Interlink: [B]Phono interlink: Cammino Serie 1.0 - PH 1.0s Power cables: Anzus Mains Ceramic, two Pom, Aluminium, X series Audio Rack: Rack of Silence 4 and 2.
September 25, 2018, 09:52 AM #3
September 25, 2018, 10:11 AM #4
September 25, 2018, 11:48 AM #5
Critical Mass Sotto Voce at around $3500 depending on configuration is fabulous. Might be above your budget, don’t know as you didn’t really indicate a number.
September 25, 2018, 12:29 PM #6
- Jan 2017
- Leyden
- 596
I'll look into brand. The budget is about double of what I think a audio rack should cost. I'd feel a bit silly putting 10k worth of audio in a 4k audio rack.
My budget for the power amp rack would be around 600-1000 euro. Double that for the second rack for the rest of my system.Pre amp: Ocatve Phono Module Power amps: Octave MRE130 Turntable: SAC Girati Grande. Tonearm: Dynavector 507mkII Cartridge: Dynavector Ikeda 9TT Streamer: Aurender A10 Power Distributor: Anzus Mains D8 Speakers: Raidho X-3 Speaker Cables: AudioQuest Rocket 88 XLR Interlink: Ansuz A2, [B]XLR Interlink: [B]Phono interlink: Cammino Serie 1.0 - PH 1.0s Power cables: Anzus Mains Ceramic, two Pom, Aluminium, X series Audio Rack: Rack of Silence 4 and 2.
September 25, 2018, 12:37 PM #7
September 25, 2018, 01:29 PM #8
- May 2013
- 3,245
If you're in the EU try this custom shop in the UK. Another member just bought from them.
https://www.hifiracks.co.uk/Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
September 25, 2018, 02:37 PM #9
- Jan 2017
- Leyden
- 596
September 25, 2018, 10:39 PM #10
September 26, 2018, 04:25 AM #11
- Jan 2017
- Leyden
- 596
December 24, 2018, 05:54 PM #12
- Jan 2017
- Leyden
- 596
My rack of silence 2 regular has arrived and I like it a lot. Not sure if it has any positive or negative influence on the sound but it looks good.
December 25, 2018, 03:06 AM #13
This is an old iteration of my system past. The reason I post it now is that it is very dense hardwood, top shelf will hold in excess of a ton +, bottom shelf will do 5 ton + with support in the middle. Because of the structure & character of hardwood, it isolates as well absorbs vibration, as all wood does. Because it is rated as some of the hardest of hardwood, it does not lend "tone" to the sound of the component as it is passive. No gimmicks. Cheap too....
December 27, 2018, 09:41 AM #14
- Jan 2017
- Leyden
- 596
December 28, 2018, 05:03 AM #15
Your living room is less than 2 mtrs wide? Also i am done with conventional box speakers as in "iteration of my system past" !!!
December 28, 2018, 06:07 AM #16
- Jan 2017
- Leyden
- 596
July 22, 2019, 11:37 PM #17
- May 2019
- Malaysia
- 155
Box Furniture Co racks if you are into all American handmade racks.
Solid Tech is another one. I use the Rack of Silence Reference.
Sent from my iPhone using TapatalkTurntable: VPI Prime - Ortofon Quintet S Black - VPI ADS
Digital Source: dCS Bartok w/headphone amp
Preamp: Soulution 520
Amplifier: Soulution 511
Speakers: Rockport Atria II
Power conditioning- Shunyata Research Denali 6000T v1
Power cord: AQ Thunder/Transparent Audio XL Gen 6
Interconnect: Transparent Audio Super Gen 5 XLR and tonearm cable / Transparent Audio Gen 6
Rack: Critical Mass Sotto Voce/ Critical Mass Black Platinum/MXR spike
July 23, 2019, 09:31 AM #18
- Aug 2014
- east of Seattle
- 821
I use Adona racks, very well made and modestly priced. made in Florida, USA. $2500 USD plus shipping for a nice 3 shelf rack. and a modest cost to add another shelf. you can order longer legs to accommodate more shelves.
modular, so flexible, and made with quality materials. granite/wood shelves. my system is fairly high end, and these racks deliver what I want from a solid rack. where racks get expensive is when you ask them to do the job of footers and de-couple in some way. I want my rack to stay totally solid so I can predictably treat my gear with footers. then I'm not trying to sell some huge expensive rack when I want to improve my de-coupling. if you have ever tried to sell a large rack......you end up giving it away just to be rid of it.
here are two of my Adona GTX racks side by side. http://www.adonacorporation.com/zerogxt.html
July 23, 2019, 09:53 AM #19
Speakers: Wilson Alexias
July 23, 2019, 09:57 AM #20
- May 2016
- 574
I’ve never understood the concept of “filter “ racks. Aka the Hrs and CMS ones. What are they filtering out ?
The Artesania ones look like they objective solve the problem (de couple ) over their expensive counterparts.
Also looks Artesania has released an entry level model so , might be with checking out.
July 23, 2019, 10:16 AM #21
Vibration that contributes noise.
July 23, 2019, 04:24 PM #22DPT4ME - Dynamics, Presence & Tone for Musical Engagement; MBP (3) - stripped down for music only; Shunyata Omega & Sigma USBs; ISO REGEN w/short Curious USB links; Berkeley Alpha USB; Aqua La Scala II Optologic DAC; Schiit Yggdrasil - fully updated; Ayre Codex dac - updated; Pass Labs INT-60 integrated amp; Wyred 4 Sound STP-SE-2 preamp, Quicksilver Mono 120 amps w/Tung-Sol KT150s; Quicksilver Mid Mono amps w/Gold Lion KT77s; Fyne Audio 703s; Symposium Svelte Plus & Ultra Platforms; REL S-812 subwoofers; Duelund DCA12GA speaker cables; AV Room Service EVPs, Stein Music Harmonizers, Duelund DCA16GA & 20GA ICs; Shunyata Denali 6000S/V2; Tripp Lite PCs; Wyred 4 Sound power cords; AudioDharma cable cooker; dedicated custom room; various GIK & ASC room treatments; etc.
www.getbettersound.com
July 23, 2019, 05:51 PM #23
I have a 4 shelf maple rack by Mapleshade. It weighs almost 500 pounds, and helps keep vibrations that affect the sound down. Forget what I paid, but I think it was around $2K.
https://www.mapleshadestore.com/samsonracks.phpBud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
July 23, 2019, 10:04 PM #24
- Nov 2014
- 2,117
I use Salamander racks. They are fairly inexpensive, which let you put the money in the equipment.
https://www.salamanderdesigns.com/modular-open-stands/
July 28, 2019, 07:52 AM #25
I have been very pleased with Core Audio Designs. Arnold is a true craftsman and a joy to deal with. http://coreaudiodesigns.com
AUDIO ROOM: CH Precision I1, Luxman D-10X, Luxman PD-171A, Stenheim Alumine Three, Shunyata Everest, Tellurium Q, Sitech cables and interconnects, CORE Audio Design racks and a whole host of other silly audiophile accessories!
HOME OFFICE: Luxman L-595ASE, Hi-Fi Rose 150B, Diapason Neos, Tellurium Q Cables.
Hahahaha , Mike is looking for someone with an Audio System...! Regards
Charleston, SC
