Results 1 to 23 of 23
Thread: Maple Block for Turntable
September 1, 2018, 04:00 PM #1
After several suggestions to get my turntable off of the glass shelf that it was sitting on, I picked up this maple block.
Speakers- Dynaudio Contour 1.8 Mk II, Amp - Pass Labs X150.5, Preamp - McIntosh C2600, Turntable - Music Hall MMF-9.3, Cartridge - Goldring Eroica LX, Phono PreAmp - Sutherland Insight, Digital Playback - Rotel RCD-1072, DAC - Bryston BDA-3, Headphones - Sennheiser HD-660S, and Drop + Dan Clark Audio Ether CX. Headphone Amp - Bryston BHA-1
September 1, 2018, 04:05 PM #2
- Oct 2013
- Sacramento
- 1,130
Re: Maple Block for Turntable
And?
September 1, 2018, 04:12 PM #3
- May 2013
- 3,244
Jack
Just a suggestion, put some sort of isolation pad between the butcher block and the glass. Something like these are cheap and simple plus the same as the ones Mapleshade sells for ten times the price.
https://www.ebay.com/itm/4-PACK-ANTI...8AAOxyrrpThNvH
The also come with cork as the middle layer. I am using Herbies Fat Dots but these will work fine either type.Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
September 1, 2018, 05:27 PM #4
Jack.......Looks good but you need to go a little farther. I raised my Michell Gyro SE turntable off the glass shelf with a Boos Block maple board and there was a definite improvement, but when I raised the Boos Block off the glass shelf with Symposium Fat Padz the vinyl playback performance truly came together. http://www.symposiumusa.com/fatpadz.html
Dan
September 1, 2018, 10:01 PM #5
September 2, 2018, 12:32 AM #6
- Nov 2014
- 227
I had problems with a Clearaudio Innovation on my old rack (Lovan Sovereign), and a maple block like that one (I had a friend who was kind of a jack-of-all-trades that put it together for fun) made a positive difference. Looks good! Definitely add pads under it, as suggested above.
September 3, 2018, 07:10 PM #7
Jack.......Do you think you might give the Symposium Fat Padz a try under your solid maple block?
Dan
September 4, 2018, 07:48 AM #8
September 4, 2018, 09:47 AM #9
Dan
September 10, 2018, 06:54 AM #10
- Aug 2014
- Fleming Island, FL
- 77
I have been using Herbie’s grunge buster dots between a Billy Bags rack and the 3” thick maple platform for my TT. I have experimented with having them in place vs having the block directly on the rack’s top shelf. I perceive greater clarity with them present. Awaiting on my new Adona rack to arrive and will then have to do the evaluations all again...
Gryphon Diablo 300 w/DAC, Rockport Mira II, Wolf Audio Alpha 3SX, DSA Phono 2, Origin Live Sovereign MK3, Enterprise MK4, Conqueror MK4, SoundSmith Hyperion, Miyajima Zero
September 10, 2018, 11:01 AM #11
I need better isolation for my TT. At times I have tried different products and they do change the sound. I am actually most curious as to a wall mounted bracket. Has anyone compared a decent stand to a wall mount.
September 10, 2018, 12:53 PM #12
Here's an idea. I'm a pretty heavy tweaker so I have taken a rega rp6 and bastardized the whole thing into a new table. What worked very effective for me was taking materials such as Corian and acrylic and separating them with druzy stones. I do have some cat eye in the mix also. It would not hurt to take a sheet of acrylic and a sheet of Corian clamp them together and drill a small hole through both plates. Do this in all four corners. Then remove the clamps and dimple the inside holes with a larger bit. Put four very small druzy beads in the dimples and drop the Top plate on the bottom plate. I find the mix of Corian which is slightly bright and acrylic which is pretty darn neutral if not slightly dull to equal a very Lively and clear sound. Rapping on my bottom sheet to my top plinth plate reveals there is pretty decent isolation. Just something you can try for very little money. All you need is a cabinet shop to cut you a piece of Corian and Tap Plastic to cut you the acrylic.20180910_094906.jpg
September 10, 2018, 01:01 PM #13Speakers- Dynaudio Contour 1.8 Mk II, Amp - Pass Labs X150.5, Preamp - McIntosh C2600, Turntable - Music Hall MMF-9.3, Cartridge - Goldring Eroica LX, Phono PreAmp - Sutherland Insight, Digital Playback - Rotel RCD-1072, DAC - Bryston BDA-3, Headphones - Sennheiser HD-660S, and Drop + Dan Clark Audio Ether CX. Headphone Amp - Bryston BHA-1
September 10, 2018, 01:05 PM #14
September 10, 2018, 03:10 PM #15
- Aug 2014
- 77
Eris 6dw with cherry trim and oversized top platforms.
http://www.adonacorporation.com/eris6dw.htmlGryphon Diablo 300 w/DAC, Rockport Mira II, Wolf Audio Alpha 3SX, DSA Phono 2, Origin Live Sovereign MK3, Enterprise MK4, Conqueror MK4, SoundSmith Hyperion, Miyajima Zero
September 10, 2018, 04:40 PM #16
Drrsutliff.......The Adona Eris 6dw is a gorgeous looking audio rack. Looking forward to seeing photos once you have it installed and the gear in place.
Dan
September 11, 2018, 08:37 AM #17
September 15, 2018, 12:26 PM #18
- Aug 2014
- 77
New Adona RackGryphon Diablo 300 w/DAC, Rockport Mira II, Wolf Audio Alpha 3SX, DSA Phono 2, Origin Live Sovereign MK3, Enterprise MK4, Conqueror MK4, SoundSmith Hyperion, Miyajima Zero
September 15, 2018, 12:34 PM #19
- Oct 2013
- Sacramento
- 1,130
Perfect fit and a very attractive setup.
September 15, 2018, 01:48 PM #20
September 15, 2018, 02:27 PM #21
- Aug 2014
- 77
Size was a consideration, though many of the double width racks would have fit... No I do not play the sax. Found the lamp at a local consignment furniture store a friend of mine owns. He is always informing me when unique musical themed things show up and I thought it would be an interesting addition. Made from what was a functioning sax at some point in time and the keys all work so a lot of fun in the room.
September 15, 2018, 05:40 PM #22
Regards,
Steve
https://www.audionirvana.org/forum/t...geezr-s-system
I only do what the voices in my wife's head tell her to tell me to do.
September 15, 2018, 07:50 PM #23
- Aug 2014
- 77
I found that with my Adona rack, that my old VPI Scout, with the upgraded footers, sounded better without the maple block. Before I had the Adona rack, it sounded better on the maple block, on my previous rack.Gryphon Diablo 300 w/DAC, Rockport Mira II, Wolf Audio Alpha 3SX, DSA Phono 2, Origin Live Sovereign MK3, Enterprise MK4, Conqueror MK4, SoundSmith Hyperion, Miyajima Zero
The beauty of downsizing today is so many components perform superbly without taking up enormous space, including speakers !
Adventures in Downsizing
