Results 1 to 12 of 12
August 15, 2018, 07:22 PM #1
Conrad-Johnson CAV45-S2 Stereo Control Amplifier ....
I'm thinking about getting a new control amp (integrated) for one of my desktop computers and saw this little baby. I want a little better sound when I surf and I think this would be great.
Here is a nice review:
http://www.hifiplus.com/articles/con...ted-amplifier/
Specifications
Power
45 watts per channel RMS both channels driven into 4 ohms from 30Hz to 15kHz at no more than 1.5% total harmonic distortion or intermodulation distortion.
Small Signal Distortion
less than .1% at mid-band
Frequency Response
20Hz to 20 kHz +0/-.5 dB
Hum and Noise
100 dB below rated power output
Phase
speaker output is phase correct
Input Impedance
100 kOhms
Dimensions
13.375”D x 17.375″W x 6.625″H
Net Weight
42 lbs.Last edited by joeinid; August 15, 2018 at 07:30 PM.
August 15, 2018, 07:50 PM #2
Re: Conrad-Johnson CAV45-S2 Stereo Control Amplifier ....
Fun! I know you’ve always been a big CJ fan. Can’t wait to see what you decide.
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
AudioQuest Hurricane HC
HRS E1
August 15, 2018, 08:49 PM #3
I'd say............................ Get It!
Magnepan 20.7 - CJ ART 300s - CJ GATV2 - Meitner MA-1 V2 -Dedicated JRMC + Synology NAS
August 15, 2018, 09:12 PM #4
Joe.......How will you feed a signal to the CJ amp? Does your computer have a dedicated sound card with clean analog outputs, or will you be feeding the amp from the typical computer mini-jack output of the motherboard? It seems to me that if you are not feeding the CJ amp with a clean quality signal your efforts are a bit overkill. If you don't have a dedicated sound card, you may want to consider some decent power speakers instead, something like a pair of Audioengine 5+ powered bookshelf speakers.
https://www.needledoctor.com/Audioen...&custcol125=25
I'm not trying to discourage you from a Conrad-Johnson integrated amplifier purchase, just encouraging you to ensure your audio signal is worth the extra cost.Dan
August 15, 2018, 09:21 PM #5
Hi Dan,
Ha! Those Audioengine speakers are way too practical.
I'd be using a USB dac via an RCA out to the CJ integrated. Overkill for sure, but I like to have music playing and this would be an excuse to get back into CJ in smaller way with some EL34 tubes. I love the way it looks and can imagine it being a spectacular piece.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
August 15, 2018, 09:23 PM #6
August 16, 2018, 11:07 AM #7
- Nov 2013
- Minnesota
- 1,369
You may want to consider a used Hegel H160 integrated. It sounds great and has a good built in DAC. You can pick them up for about $1800 used. A Peachtree Nova and Nuprime gear with built in DAC's are also worth a look although I can certainly understand wanting to go with CJ. That CJ integrated is a beautiful piece.
August 16, 2018, 12:15 PM #8
August 16, 2018, 01:13 PM #9
- Nov 2013
- St. Louis, MO, USA
- 3,068
He reads the post and thinks to himself, I wonder how a CJ preamp would sound with the XA25. He decides not to write anything though as it's not practical for the application posted about
SVS PC13 Ultra
Sony XBR-75X940D & BDP
August 16, 2018, 01:19 PM #10
Ha!
That’s going through my mind too but one step at a timeFleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
August 26, 2018, 03:34 PM #11
Nah Joe, Put the Ref10 and Luxman in there. There is no such thing as overkill ...
― Neil deGrasse Tyson
August 26, 2018, 04:41 PM #12
