Page 3 of 3 FirstFirst 123
Results 101 to 118 of 118
  1. #101
    Junior Member
    Join Date
    Nov 2019
    Lisboa
    Posts
    21
    Re: Luxman M900u Monos and C900u
    Hi Mike
    First, I would like compliment you for your You Tube videos. They are fantastic.
    I wonder if can give me your personal opinion on something.
    I recently bought a Luxman M-900U that I really like and that I feel it's a great match for my B&W 800D3.
    It replaced my Simaudio Moon Evolution 860A.
    I'm using a Simaudio Moon 740P preamp.
    In your opinion, what would be the best upgrade, replace the 740P with a C-900U or keep the 740P and buy another M-900U?
    Thank you in advance for your time.
    Happy new year!
  2. #102
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Welcome to the forum pnp88, thank you for joining.
  3. #103
    Junior Member
    Join Date
    Nov 2019
    Lisboa
    Posts
    21
    Thank you, joeinid.
  4. #104
    Junior Member
    Join Date
    Nov 2019
    Lisboa
    Posts
    21
    Hi Mike
    Please let hear from you.
    Thank you
    Kind regards
  5. #105
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,044
    Quote Originally Posted by pnp88 View Post
    Hi Mike
    Thank you
    Kind regards
    Hi, welcome and thank you for the kind words. Buy another 900u would be my recommendation. The pre change will be a lateral move. The 900u will take your power from 150 watts to over 600 in mono mode, and still handle the impedance swings of the 800D3 just fine. You will hear a much bigger soundstage, more relaxed and effortless presentation.
    Keep us posted on how things work out!
  6. #106
    Junior Member
    Join Date
    Nov 2019
    Lisboa
    Posts
    21
    Hi Mike
    Thank you for your reply.
    I believe you're right.
    I will keep you posted on any upgrades.
    Kind regards
  7. #107
    Junior Member
    Join Date
    Nov 2019
    Lisboa
    Posts
    21
    Hi
    Has anyone tried the Luxman M900-u in horizontal biamping vs bridged mono vertical biamping?
    Kind regards
  8. #108
    Junior Member
    Join Date
    Dec 2020
    Heaven
    Posts
    11
    I would go Boulder with Focal or VAC. Pass X260.8/XP22 would be another more cost effective option. The Luxman m900/c900 would be very good too, but I would want more meat on the bones with the Focal tweeter.
    Dear Mike,
    To be clear, instead of 2 bridged Luxman M-900u's, you'd still prefer the Pass Labs X260.8 monoblocks? These have less than half the Luxman's power. If so, it's not about watts per channel but rather the style or character of the power?
    P.S. I have no opportunity to go out and compare these components myself, so I'm very grateful for you sharing your expertise here.
  9. #109
    Junior Member
    Join Date
    Nov 2019
    Lisboa
    Posts
    21
    [QUOTE=Mike;320675]Hi, welcome and thank you for the kind words. Buy another 900u would be my recommendation. The pre change will be a lateral move. The 900u will take your power from 150 watts to over 600 in mono mode, and still handle the impedance swings of the 800D3 just fine. You will hear a much bigger soundstage, more relaxed and effortless presentation.
    Hi Mike,
    My dealer gave me the chance to try a C-900U on my system. Not a lateral move but huge back move.
    I was hoping for a better match between it and the M-900U, than with the 740P.
    Well, much to my surprise it was the absolute opposite. The match with the 740P is so much better that I was amazed. Compared with it the C-900U was lacklustre and the bass sound weak.
    For now the 740P stays...
    Thank you for your time...
  10. #110
    Senior Member
    Join Date
    Apr 2015
    Front Row Center
    Posts
    3,456
    Did you try 900U in mono as suggested ..?
    * An Audiophile is only as old as his latest Class D incarnation *
  11. #111
    Junior Member
    Join Date
    Nov 2019
    Lisboa
    Posts
    21
    Yes, I did.
    Didn't like it.
    Voices became a little more present, the bass became a little stronger but lost clarity and definition, and the treble was the major disappointment because it became aggressive.
    Overall, I felt the sound lost refinement and the sensation of ease and grace of the stereo.
    Not my cup of tea but may work well for others...
  12. #112
    Senior Member
    Join Date
    Apr 2015
    Front Row Center
    Posts
    3,456
    Not disagreeing with your assessment but did you try different cabling to see if any of it changed, sometimes optimization for one isn't the same for all ..!
    Regards
  13. #113
    Senior Member
    Join Date
    Jul 2019
    Israel
    Posts
    177
    Yes, I did.
    Didn't like it.
    Did you connect the speakers cable to the upper bindings as required in BTL mode?
    From your descriptionit i suspect you might mis configure speaker cables place, connecting them as in stereo mode.
  14. #114
    Junior Member
    Join Date
    Nov 2019
    Lisboa
    Posts
    21
    Quote Originally Posted by exupgh12 View Post
    Everything was correctly connected.
  15. #115
    Junior Member
    Join Date
    Nov 2019
    Lisboa
    Posts
    21
    Quote Originally Posted by a.wayne View Post
    Regards
    Cables were kept the same. Changing cables would be entering a never ending path of experimentation between mono and stereo mode.
  16. #116
    Senior Member
    Join Date
    Apr 2015
    Front Row Center
    Posts
    3,456
  17. #117
    Senior Member
    Join Date
    Jul 2019
    Israel
    Posts
    177
  18. #118
    Senior Member
    Join Date
    Feb 2019
    Southeast Iowa
    Posts
    992
    Be still my booming heart!! One of these days... Actually I'm very contented with what I have. But, be still my booming heart anyway.
    Amplifier: Pass Labs INT 250 integrated.
    DAC/Streamer: MSB Discrete Dual Power Supply.
    Server: Roon Nucleus with lifetime subscription.
    Speakers: Harbeth Super HL 5+ 40th Anniversary
    Model.
    Headphones/Amp: Focal Stellia phones, NAIM Uniti Atom Headphone Edition headphone amp/music player/server/streamer.
    Cables: AudioQuest Rocket 88 speaker cables,
    Mackenzie interconnects.
    Speaker Stands: HiFi Man.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
