Results 1 to 18 of 18
Thread: New Brinkmann Oasis is in
July 21, 2018, 12:54 AM #1
Was thinking to get either AMG or Oasis or Bardo and finally pulled the trigger on Oasis with 10.5 arm.
So far loving it . Any one else has them ? If so when you flip the disc do you shut the power off and unscrew the clamp or do it while it’s spinning ?
July 21, 2018, 03:09 AM #2
Re: New Brinkmann Oasis is in
Lovely table - congrats
First up, listen to some records with and without the record clamp. If you prefer without, you save yourself a lot of trouble of switching off and on the table while you unscrew and screw.
cheersSource: Technics SP10mk3 - Thales Simplicity II, TW Raven AC-3 - Graham Phantom, SME 3012-R, Exclusive P3,,Linn LP12 - Naim ARO
EQ: DEQX HDP-4
Speakers: Wilson Maxx3
July 21, 2018, 11:38 AM #3
- Jan 2014
- Los Angeles
- 1,775
Brinkmann's clamp is an integrated part of its platter system - its not an option. Yes, you need to power down and unscrew while flipping or putting on a new record - make it thumb tight
Congrats on the new table Paul! I have the Bardo as you know which is basically a plinthless Oasis. The 10.5 is such an easy to use tonearm as well.Brinkmann Bardo w/ EMT HSD-006 cart, MSB Reference DAC --> Linear Tube Audio MicroZOTL --> Ampzilla 2000, 2nd Edition --> Fyne Audio F1-12
July 21, 2018, 12:45 PM #4
Gorgeous turntable ...... enjoy Paul!
Buddy
Boulder 1160 Amp, 1110 Pre-Amp
Audio Research Ref. 3 Phono-Pre
Vivid Audio Giya G2S2 Speakers
MSB Reference DAC
Innuos Statement w/Next. Gen. PS
B & W DB1D Subwoofer X2
Audioquest Niagara 5000 Power Conditioner
Kronos Pro Turntable w/Kronoscope RS tonearm + SCPS-1 PS + MSL Platinum Cart.
VPI HW-40 Turntable w/ Lyra Etna cartridge
Jay's Audio CDT3-MK3 CD Transport
Schiit Mjolnir 2 HPA + Audeze LCD X headphones
Adona Equipment Rack and Amp Stands
Furutech Outlets and Plates + NCF Booster
Shunyata Cables
Synergistic Research Galileo SX Ground Block, FEQ 4, Ethernet Switch UEF, Black Box + Room Acoustic treatments
July 21, 2018, 02:24 PM #5
Yes it’s an excellent table. I did tried with other clamp without those small ring. It worked fine and I found it interesting the sounds was way different than original clamp.
However do I have to wait till stop ( will take forever sigh )or just force it stop by your hand and changing it ?
July 21, 2018, 07:01 PM #6
- Jan 2014
- Los Angeles
- 1,775
About the platter system:
The platter mat covers the record-groove area, leaving an indentation for the label, which allows a perfectly flat record to lie flat without clamping. The platter has a recess around the spindle that accepts a removable spindle insert, included with the record-clamp option. This raises the label area and allows the clamp to leverage down the rim of the record more effectively.
So yes, take the spindle insert out if trying something else.
As far as use, I give a very slight shove after turning on and slow down the platter with my hand after turning off. It’s German - you won’t break it
July 21, 2018, 08:49 PM #7
Excellent. Good to know. Thanks Keith
July 21, 2018, 11:06 PM #8
EQ: DEQX HDP-4
July 21, 2018, 11:22 PM #9
July 21, 2018, 11:49 PM #10
EQ: DEQX HDP-4
July 27, 2018, 08:45 AM #11
Nice looking table Paul, enjoy
August 1, 2018, 06:42 AM #12
Congrats! Beautiful table. How is it comparing to the Sparta?
Industry Disclosure: Owner Epiphanic Audio. Bespoke 2 channel resource in Virginia Beach VA. Dealer for darTZeel and other great brands.
August 2, 2018, 12:16 AM #13
August 9, 2018, 07:48 AM #14
- Jun 2016
- Guelph, ON
- 5
Fantastic turntable ... I own one too with 10.5 arm and Brinkmann EMT ti cartridge and like you say lots of punch and dynamics. I usually use the microfiber cloth to stop the platter by hand and give it a little spin to get it started.
Good choice and enjoy
August 9, 2018, 10:31 AM #15
February 3, 2019, 06:48 PM #16
February 3, 2019, 08:20 PM #17
Hi Don.
They both amazing turntables. Very similar sound as well. However the best analog set up I ever listened to was based on Brinkmann and that was the main reason. I don’t think you can’t go wrong with either AMG or Brinkmann. Superb engineering and best build quality.Paul
February 4, 2019, 03:56 PM #18
Thank you so much for your reply! I’ve heard the Balance and the AMG V12 and enjoyed both tables... both of which being belt driven. Never heard the Direct Drive Oasis and was curious as to if it had a different presentation.
Thanks again,
Don
