Results 51 to 73 of 73
Thread: AMP8
June 30, 2018, 01:26 PM #51
Re: AMP8
Randy.......Your new T+A components are quite attractive. The sleek and compact design exudes typical German attention to detail without being pretentious. The T+A AMP 8 packs a lot of power into its diminutive package. I was impressed to read the amplifier uses ThermalTrak output transistors. This advanced transistor design allows each transistor to bias itself independently in real time according to the output device's temperature. This ensures extremely low distortion and nearly perfect linearity across the audio frequency band and beyond at all output levels. I noticed also that there is a cooling fan. Is it audible at any time?
Your sound system has been in a relatively constant state of flux these past few years but it appears you are now reaching a level that should satisfy you for years to come. Congratulations on a fine looking sound system.Dan
June 30, 2018, 03:05 PM #52
Re: AMP8
Thank you Dan. I think I am finally reaching a point of satisfaction. I am really liking the T+A gear. Very high quality, and as they have stated, the gear is not design to last for years, it is designed to last decades!
I have never heard the fan; T+A say you probably will never hear it because it is a low spin fan.McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
― Neil deGrasse Tyson
July 1, 2018, 09:12 AM #53
Re: AMP8
I feel Randy should now add the MP8 and have a total T&A system
July 1, 2018, 09:31 AM #54
- Jun 2013
- St Louis, MO
- 145
July 1, 2018, 10:01 AM #55
Re: AMP8
Sounds good... you guys pitching in to get one for me ....
Yea, the MP 8 would be sooooo much nicer if it played SACD... and as the most expensive of the threeMcIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
July 1, 2018, 11:30 AM #56
Re: AMP8
July 1, 2018, 01:09 PM #57
Re: AMP8
It is definitely designed to go along with the DAC 8 DSD; however this should not exclude it from doing SACD. It could be like Esoteric, McIntosh, PS Audio, etc., and do direct link to the DAC and use their proprietary converter for SACDs ...
July 7, 2018, 10:44 AM #58
Re: AMP8
The amp continues to break in nicely. Very subtle differences. It seems like it has settled into what I assume is the T+A sound in first 30+ hours. Not sure how many actual hours are on the amp. I would guess under 100 for sure; it is really smoothing out. Very fast, similar to the Goldmund, but much smoother and seems to be very well made. I still am very impressed with the sound stage. Better then any if the others I have had, and better then I have heard (other than the MBL that a buddy has, then again his system is probably 10 times the price of mine ).
July 7, 2018, 11:51 AM #59
Re: AMP8
Glad to hear your amp is breaking in nicely, Randy. Please continue to update as any changes come about.
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
AudioQuest Hurricane HC
HRS E1
August 1, 2018, 07:25 PM #60
Re: AMP8
The T+A AMP 8 is settling in very nicely. I can honestly say that I am very pleased with the sound and the quality of construction. I would serious consider their higher level products if I could afford to look for equipment in that price range.
There are only two small considerations; thoughts if you will.
1) I am not particularly fond of the auto power. It seems to work fine, but having the amp power up from signal on the inputs would not be my choice. The trigger cable from the DAC is fine, but I mostly want them to power separately. Would prefer a power switch on the front or standard power trigger from the pre-amp.
2) The size . It is so darn small (for a power amp) that it is hard to wrap my head around how good it is .McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
August 1, 2018, 09:37 PM #61
Re: AMP8
Glad to hear the T+A amp is settling in nicely, Randy. It’s been a great watching your journey (in your other thread). Keep the updates coming!
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
HRS E1
October 28, 2018, 02:39 PM #62
Re: AMP8
Randy did you sell your AMP 8?
Marty
MSB Premier
PS Audio Powerplant 15
October 28, 2018, 08:45 PM #63
Re: AMP8
Hey Marty,
I have not yet. I was going to be putting together an ad in the next couple days.
It is a really great amp, and absolutely amazing if someone is looking for a compact top quality German built amplifier.
My problem is I just got the SET amps that I am enthralled with. I also got the classic McIntosh that looks and sounds like the day it rolled out of the factory (and being from Binghamton this has to stay in my system). I just don't think I need a third amplifier at this time. This makes the newest and arguably the better of the three as the odd man out.McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
December 22, 2018, 03:36 PM #64
Re: AMP8
Today we are going to be hosting family for our Christmas get together. I have been listening to the SET amp comparing some NOS tubes I recently picked up. Enjoying the heck out of it.
However, since I do not like all of the tubes up there playing away, all day, without watching over them at least for the most part, I decided to hook the T+A amplifier back up. I forgot what a wonderful sounding amplifier this truly is. Full rich, cool running; perfect for this type of use.
I have had this amplifier on the market for a little bit thinking do I really need three amplifiers (well four if you count the mono blocks ). I believed that I could always hook up the McIntosh if I wanted to give some Solid State lovin... and yes I could, but I keep the McIntosh more or less as a showpiece because it is in Museum quality shape and it holds a soft spot in my heart reminding me of my hometown. But this T+A is really good... so now I have a dilemma again. Do I sell it or hang on to it for these types of situations? Definitely a first world problem... right now I am thinking if someone wanted it I would probably sell it, but by the end of the day I maybe will not ....McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
December 22, 2018, 03:39 PM #65
- Jul 2015
- Golden, CO
- 858
Re: AMP8
I’d you’re not sure, keep it!
February 13, 2019, 03:39 PM #66
Re: AMP8
So I hooked up the Amp 8 today. What a great sounding amp! I have a decision to make. I have to sell one of my amps to help finance the new laptops my wife wanted. Falcon Northwest laptops are not cheap . So either the T+A or the SET need to be sold. It seems people simply do not understand how fantastic T+A is here in the States ...
The Audio Mirrors coming off The Absolute Sound rave review might be easier to sell... I could live with either, the T+A or the SET mono blocks.
Going to give it a few days to decide... I guess we will see how it goes.McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
February 13, 2019, 03:41 PM #67
Re: AMP8
how much money does a gamer laptop cost nowadays?
Avanti Audio
February 13, 2019, 09:44 PM #68
Re: AMP8
The Falcons are true desktop replacements; desktop CPU and GPU, etc. Coming in at over $3k... each...
A very good machine like an Alienware or Republic of Gamers can be had under $2k. But with Falcon you get something pretty special .McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
April 15, 2019, 01:21 AM #69
Re: AMP8
Since I recently sold the McIntosh amp the T+A is staying put as my SS backup for the SET mono blocks. I decided to hook it up today to see how it matches up with the Stage 2 pre. What a wonderful sounding amplifier. People who avoid this amp because of its size are simply missing out.
This is definitely one of the best sounding amplifiers I have owned... period!McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
April 15, 2019, 01:37 AM #70
Re: AMP8
T + A makes great gear. I’m sure it’s even better with the stage 2.
April 15, 2019, 01:57 AM #71
Re: AMP8
Yes Joe, it is fantastic. T+A is very impressive gear! Very happy where I am at. The SET amps for when I want some toobs... and the great T+A, which might become my main stay amp... so so good with the Stage 2!
August 30, 2019, 01:48 AM #72
Re: AMP8
The T+A definitely won out. So much so that I sold the Audio Mirrors. The more I listen the more I did not want to listen to the tubes. The T+A is amazing sounding amp and the bottom end was sooo much better then the Tubes.... incredible sound stage and very inviting sounding, very musical in every way... all in all, after I finally got over the feeling that it can't be great because it is small, I have came to realize that this may very well be the best sounding amplifier I have ever owned! Such an amazing little amplifier!
October 6, 2019, 09:53 AM #73
Re: AMP8
I hosted our audio club meeting last weekend. This steller little amp played all day, at fairly high levels. The audio club guys definitely like to get a little volume behind things. It was an absolute champ all day. Never once did I detect any kind of clipping no matter how hard they pushed it.
The club came away impressed with the wonderful T+A gear. Our one member who writes for Stereophile was very impressed. He stated that the synergy between the Stage 2 and the T+A was amazing. He had wrote a review of the DAC a while back but never had heard the amp before. He stated that he was shocked at how good it is!
At this point I can definitely state that the T+A Amp 8 is the finest amplifier I have ever owned. Unless I can ever afford an amp at many times the price I simply cannot imagine finding a better sounding amplifier! I am very happy I stuck it out with the T+A until it was fully broken in. It accomplished something that I had thought would not be possible; it won out over the SET mono amplifiers!McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
Nucleus one
