Page 2 of 2 FirstFirst 12
Results 51 to 65 of 65
  1. #51
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,091
    Re: So has anyone replaced the 6550s in their Ref 10 with KT88s?
    Quote Originally Posted by mep View Post
    Geez, I have a NOS GE 6550 that came from ARC as a spare for a D-79 I used to own. I wonder how that would sound in the Ref 6?
    I bet they would be great.
  2. #52
    Senior Member
    Join Date
    Jan 2016
    The Matrix
    Posts
    1,131
    Mark it will sound fantastic! This is what I am using in my REF5SE. Try it you may like it...….
    Marty
    MSB Premier
    PS Audio Powerplant 15
  3. #53
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Hi Mark !!!!
  4. #54
    Senior Member
    Join Date
    Jan 2014
    Kentucky, USA
    Posts
    624
    [QUOTE
    WOW!!! These things are great! Thanks Mike!
    =Mike;245924]I swapped out the Sovtek 6550’s today and installed my NOS, matched SED Winged C 6550’s (from here: https://rover.ebay.com/rover/0/0/0?m...2F283069212072)
    Much fleshier sound, slight increase in sweetness, just a touch of warmth. Vocals were the most improved. Vocals and instruments had a greater 3D presentation. I would consider the improvement quite significant.
    Sent from my iPhone using Tapatalk[/QUOTE]
    Rance
  5. #55
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,091
    Rance, that’s fantastic.
  6. #56
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,091
    Tried a NOS 6550 today. Added quite a bit of warmth. Not as sweet on top as the Winged-C, but certainly warmer.
  7. #57
    Senior Member
    Join Date
    Jan 2016
    The Matrix
    Posts
    1,131
    Mike I ordered a Winged-C- for the REF5SE on your review and recommendation. Thanks for being the Guinea pig for us.
    Marty
    MSB Premier
  8. #58
    Senior Member
    Join Date
    Jan 2016
    The Matrix
    Posts
    1,131
    Marty
    MSB Premier
  9. #59
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,091
    Quote Originally Posted by nc42acc View Post
    Nice Marty! Keep us posted.
  10. #60
    Mike...I may be incorrect however I kinda read Marty's post more along the lines of I would like to hear about user experience of this implementation before I consider such, rather than, I am in the process of making the swap to KT88's watch this space.
  11. #61
    Senior Member
    Join Date
    Jan 2016
    The Matrix
    Posts
    1,131
    Sorry Mike the GE had to go back in. There is much synergy with this one!
    Marty
    MSB Premier
  12. #62
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,091
    It’s wonderful!
  13. #63
    Senior Member
    Join Date
    Oct 2015
    Near Philadelphia
    Posts
    135
    This may have been mentioned elsewhere, but whatever 6650/KT88 power tube you like in your ARC Reference power supplies, you may not be hearing what they sound like if you're not using tube dampers on them. As I've improved my system setup, I began to notice a very slight haze/dryness using the SED Winged "C"s. It made me wonder too about my REF10 phono where I switched to Shuguang Treasure Zs.
    For the last week, I've been using Herbie's Audio Lab high-temperature HAL-O IIIs on these tubes and really noticed a significant improvement in clarity and detail without any downsides of a more analytic presentation. They are made with titanium, not PTFE/Teflon or Sorbothane. Note, these tubes reach temperatures of 450 F so I wouldn't cheap-out with dampers of some other material, although PTFE ones will work.
    I liked them enough, I'll be experimenting with the smaller size on the 6H30s instead of the ARC supplied dampers.
    Note that Herbie's recommends the "50s size" for bulb-shaped KT88s, but that only allows them to be placed at the very top of the tube, not the middle. That seems to be just fine though. Have fun!
  14. #64
    Senior Member
    Join Date
    May 2016
    Bucks County, PA
    Posts
    115
    Thanks for sharing that info Barry. Will def have to pick some up for my REF 10 and other gear. The comments/reviews on these are insanely positive. Never heard of these suckers before....could be a game changer!!
    Amps: First Watt SIT-3, Pass XA25, Valvet E2 SE, LTA ZOTL40, First Watt SIT-1 Mono's, ARC Ref75SE, Decware Zen TorII MK4, Line Magnetic 845 Premium, Raven Reflection MK2, Audio Hungary Qualiton X200, Kingko 101Pro, Audio Hungary Qualiton I50
    Pre-Amps: Luxman 900U, Coda 07X, ARC MP-1 Multi-Channel, Conrad Johnson Met-1 Multi-Channel
    Disc Spinners: Luxman D-10X, Ayre DX5, Oppo 105/205
    Speakers: Cube Audio Nenuphar Mini, Fleetwood Deville, Volti Razz, Spendor Classic 100, Rosso Fiorentino Certaldo 2, Klipsch Cornwall IV, Harbeth SHL5+, Harbeth C7XD, Omega Compact 8, Triangle Comete 40th Anniversary, Audio Solutions Figaro M, Graham LS3/5A
    Check out my Facebook Page RIAA AWARD COLLECTORS to see over 3800 authentic Music Industry Awards (Gold and Platinum Records) from my personal collection. New awards added every month. https://www.facebook.com/riaaawards
  15. #65
    Senior Member
    Join Date
    Oct 2015
    Near Philadelphia
    Posts
    135
    So I tried the smaller Herbie's HALO-IIIs on the 4 ARC REF40 6H30 gain stage input tubes in place of the dampers that ARC supplies. Can't categorically say they're better. It would take more A/B listening and that's complicated since I'm using Center Stage Feet and it takes a while for those to settle when I move the preamp. I am going to leave the dampers in however. The HALO-IIIs on the big 6550/KT88s power supplies still sound like a good improvement to me. I don't think you can't go wrong with them. They seem to eliminate a slight haze that was bothering me.
    These damping titanium rings are a tight fit and the pads don't seem to roll on the tubes like some others. Be patient and careful when you put them on!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
