Results 1 to 35 of 35
April 24, 2018, 11:38 AM #1
- Aug 2014
- 42
Berning ZOTL Pre One vs Linear tube audio MZ2
Guys, I already have the LTA MZ2 preamp with linear PSU upgrade. I love it a lot. No complains at all. I just have an opportunity to buy Berning ZOTL pre One preamp with in-built phono stage which is a huge plus for me (the phono part). I am just worried that Berning ZOTL Pre One uses a SMPS power supply (I know it is very advanced but still) and LTA allows me to use linear PSU which is very smooth and analog sounding. Has anyone heard both these preamp to comment on how they compare ?
April 24, 2018, 11:48 AM #2
- May 2017
- Guildford, UK
- 123
Re: Berning ZOTL Pre One vs Linear tube audio MZ2
I have the MZ2 into my Berning Quadrature Z's but not had the opportunity to try Berning's own pre for comparison. That said, if you speak to LTA, they have now introduced a fully-specced pre, which they believe to be a step up from the MZ2, and are considering "cloning" the Berning Pre One as a final step up, so they definitely believe there is an upgrade to be had.
The other point to note is that you can run the Pre One from a separate 12V source.
April 24, 2018, 12:04 PM #3
- Aug 2014
- 42
I totally believe that the Berning Pre One is a higher design than the MZ2 but it is the PSU that I am comparing. It is good to know that the Pre One has a 12 volt input (I had no idea of such a feature in the Pre one) but then which PSU ? Every PSU will have a different grade of sonics. If Berning himself builds one or recommends one from a third party then I would gladly take that option. Any suggestions ?
April 24, 2018, 12:39 PM #4
Dont forget LTA's new pre-amp https://www.lineartubeaudio.com/products/microzotl
April 24, 2018, 03:02 PM #5
- May 2017
- Guildford, UK
- 123
I'd email Mark at LTA and David himself if I were you - both very helpful via email.
April 24, 2018, 04:33 PM #6
January 6, 2019, 10:41 AM #7
Hi Joe,
I just took delivery of my Sit 3, is it a good match with the MZ2 ? Would you have an another preamp to advise me ?
ThanksPTP+ Schick arm+ Phasemation PP300, Aurorasound Vida, Zardoz -Meitner MA1-First-Watt Sit 3/ JobPre2-Marten
January 6, 2019, 12:13 PM #8
Congratulations!
The SIT3 is absolutely amazing. Perfect for me and my taste.
The MZ2 is a great match but I’m curious about the new full sized LTA preamp. As far as others to consider, I’d have to think about what they’d be. I think something a little lively and open like the MZ2 or similar will complement the SIT3 perfectly.
I am trying to get hold of a Conrad Johnson preamp, either GAT2 or GAT could be simply sublime. Even their new updated ET7 or ET6 would probably be awesome as well.
What kind of budget were you thinking about for the preamp? I probably should have asked first.
Your Job Pre2 should be good but the MZ2 will absolutely be better.Last edited by joeinid; January 6, 2019 at 12:17 PM.
January 6, 2019, 01:44 PM #9
Thank you Joe, yes the pre2job is not suitable, it does not have enough gain, I'll be curious to have your opinion on the LTA, here it is impossible to listen. For Budget I will not exceed that of an ET6SE for example. You have not considered an XP12 or XP22 for example?
January 6, 2019, 02:19 PM #10
I have not heard the new XP12/22 preamps yet. I am curious though.
I have owned an X0.2, XP10 and the XP30 twice. I remember liking them but not loving them. I have to be honest, I am not a Pass preamp fan but absolutely love their amps. The new XP12/22 and upcoming XP32? could be great. I personally find the ones that I owned a little too solid state sounding. I’d be willing to try the new XP12/22 because I’ve heard great reports about them and believe they would be a great compliment to the SIT3.
Pass Labs and First Watt are superb companies and excellent customer service is paramount.Last edited by joeinid; January 6, 2019 at 02:21 PM.
January 11, 2019, 09:59 AM #11
Hi Joe,
I just had a loan Thrax Dyonisos, It's wonderful match with the Sit3, certainly the budget it's high but all the qualities of the Sit3 are multiplied with an energy like a muscle car !
January 11, 2019, 12:48 PM #12
Wow! What do you think? Looks great.
January 11, 2019, 02:38 PM #13
I will try to listen also The Coincident Statement MKII line stage, but for now the Thrax will be my next préamp.
January 11, 2019, 02:54 PM #14
Excellent. I know people love the Coincident gear. I think there may have been a few updates recently. I don’t know how the sound is affected but reports are about improvements across the both amps and preamp.
January 12, 2019, 02:26 AM #15
- Sep 2014
- 766
Hi Yami, for your analog and Thrax, is it Anamighty in Paris you interact with? It's a great shop for analog.
January 12, 2019, 03:42 AM #16
[DEVIS = bonzo; 259136] Bonjour Yami, pour ton analogue et Thrax, est-ce que tu interagis avec Anamighty à Paris? C'est un bon magasin pour l'analogique. [/ QUOTE]
Yes , they are very competent in the field of analog , and their choices are excellent. I listened recently a Thrax Orphéus (Phono), WOW... it's a phenomenon of resolution and naturalness !PTP+ Schick arm+ Phasemation PP300, Aurorasound Vida, Zardoz -Meitner MA1-First-Watt Sit 3/ JobPre2-Marten
January 12, 2019, 03:46 AM #17
- Sep 2014
- 766
Here is my write up on the visit to Anamighty. On my blog you will also find another Thrax vs FM 123 phono compare, where we preferred the Thrax
http://zero-distortion.org/analog-sh...amighty-sound/
January 12, 2019, 07:34 AM #18
[DEVIS = bonzo; 259140] Voici mon article sur la visite à Anamighty. Sur mon blog, vous trouverez également une autre comparaison phono Thrax vs FM 123, où nous avons préféré le Thrax
http://zero-distortion.org/analog-sh...amighty-sound/ [/ QUOTE]
Beautiful report ! It's really a nice place and Anamightysound Team is friendly.PTP+ Schick arm+ Phasemation PP300, Aurorasound Vida, Zardoz -Meitner MA1-First-Watt Sit 3/ JobPre2-Marten
March 15, 2019, 07:49 PM #19
- May 2015
- 206
Joinid, As we have some of the same gear, (Avantgarde Duo XD, Luxman MQ-300), and I'm thinking about trying the new LTA pre-amp with the Luxman. I've listened to the LTA MZ2 and 3 as an amp and really like it, but not quite as dramatic as the Luxman.
So, I was wondering if you've listened to your LTA before the Luxman and what you think of their synergy? ThanksSource: Taiko Audio Server, Cisco 2960 Switch, Gigafoil, Lampizator Pacific Dac. Amp: Bakoon 13r Speakers: AvantGarde Duo Mezzo XD, Cables: Alan Maher Designs Power, Duelund Speaker, Shunyata Sigma IC's Audioquest Diamond ethernet. Room Treatment Vicoustic.
March 15, 2019, 07:59 PM #20
Hi,
I have the MZ2 and like it but feel, for my taste, it's a little "too neutral" even with 300B type amps on my Duo XD. Even with Brimar or similar NOS tubes, I'd like a little "more". I need some warmth or a little sweetness.
I don't know about the new LTA preamp but think the house sound might carry through the same way.
I think there's a matching MQ-300 preamp coming which has me intrigued. Even my C900u was awesome and prefer it to the MZ2 oddly enough but the C900u is very special and a little more expensive though.
I don't know when the Luxman pre is coming. Mike may be able to find out.
ps. I don't like to use any dac direct to my amp, no matter which dac. I always like a preamp in the chain.Last edited by joeinid; March 15, 2019 at 08:12 PM.
March 15, 2019, 08:13 PM #21
- May 2015
- 206
So you like the solid state c900u with the Luxman 300b amp? I was thinking a good solid state might be a nice mix with the 300b power amp. And I'm also thinking about the less expensive c600f which I think came out before the "u" pre amps.
March 15, 2019, 08:14 PM #22
- May 2013
- 3,242
Joe
I think Terry found the house sound of the two LTA's the same just one was more and would be for over twice the price. The MZ3 which is considerably more expensive than the MZ2 might be closer. So if you want to go back to the CJ side of the spectrum probably not it. Might need to look for a 6SN7 based preamp.Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
March 15, 2019, 08:37 PM #23
March 15, 2019, 08:44 PM #24
Hi Jack,
Thank you. It's not in my signature yet but I was finally able to get what I really wanted, the CJ GAT2. I absolutely love that thing, even more than my original GAT. It's pretty amazing. I'm pretty much done now. Maybe some cable tweaks, possible new dac and that's it. I am so content at this point that I can not believe it. Some amps will be out the door soon. But the Luxman MQ300, SIT3, Valvet E2, and Wooden amp and preamp from Bulgaria are here to stay.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
March 16, 2019, 10:53 AM #25
March 16, 2019, 02:49 PM #26
DPT4ME - Dynamics, Presence & Tone for Musical Engagement; MBP (3) - stripped down for music only; Shunyata Omega & Sigma USBs; ISO REGEN w/short Curious USB links; Berkeley Alpha USB; Aqua La Scala II Optologic DAC; Schiit Yggdrasil - fully updated; Ayre Codex dac - updated; Pass Labs INT-60 integrated amp; Wyred 4 Sound STP-SE-2 preamp, Quicksilver Mono 120 amps w/Tung-Sol KT150s; Quicksilver Mid Mono amps w/Gold Lion KT77s; Fyne Audio 703s; Symposium Svelte Plus & Ultra Platforms; REL S-812 subwoofers; Duelund DCA12GA speaker cables; AV Room Service EVPs, Stein Music Harmonizers, Duelund DCA16GA & 20GA ICs; Shunyata Denali 6000S/V2; Tripp Lite PCs; Wyred 4 Sound power cords; AudioDharma cable cooker; dedicated custom room; various GIK & ASC room treatments; etc.
www.getbettersound.com
March 16, 2019, 03:05 PM #27
March 16, 2019, 03:06 PM #28
March 16, 2019, 03:33 PM #29
March 16, 2019, 06:34 PM #30
February 9, 2020, 10:49 AM #31
- Feb 2017
- 2
I have a Berning Zotl pre one. The switching power supply causes no problems whatsoever. It’s a wonderful preamp.
February 18, 2020, 05:55 PM #32Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
February 18, 2020, 10:50 PM #33
- Feb 2017
- 2
Thank you for the welcome. I am a huge fan of Berning products.
February 18, 2020, 11:22 PM #34
May 3, 2020, 08:32 AM #35
My understanding of power supplies:
1 typical switching power supply - cheap and kinda sucks
2 Linear power supply - much better than the switching
3 David Berning’s switching power supply - expensive, complicated and difficult to build but far superior to anything else out there. Far different from a typical PS, a true master piece.
The new Clarisys Piccolo’s stole the thunder from the Minuets…and everything else. Sent from my iPhone using Tapatalk Pro
