Results 101 to 130 of 130
May 15, 2020, 10:06 AM #101
- May 2020
- Austria
- 35
Re: AudioQuest Niagra and Storm Power Cable Review
Intending to use Thunder for connecting Niagara 5000 and two Blizzard with Devialet 220 Pro monos. Hope that will work out well
May 17, 2020, 05:19 PM #102
- Apr 2020
- Belgium
- 16
I tried both at home. The Thunder was more dynamic then the Blizzard, especially on power amps, but the tonal qualities of the Blizzard were better. Since the Thunder feeding the Niagara 5000 will allready give you an extra boost in dynamics and separation, this could work well. Without the Niagara I would go Tornado HC on the power amps
May 17, 2020, 05:47 PM #103
- May 2020
- Austria
- 35
Thanks! I haven’t had a chance to compare the cables but got a good offer so I think to go Thunder from wall to Niagara 5000 as well as Thunder each for the Devialet monos. You think that should be better than the two Blizzard ?
May 18, 2020, 03:43 PM #104
- Apr 2020
- Belgium
- 16
it depends what your system needs, my amplifiers were quite fussy about tonal quality but needed dynamics as well, so I went with Tornado HC which are burning in as I type. As said the Thunder give more dynamics, and are better suited for power amps in this regard, but when I compared Thunder and Blizzard on preamp, I preferred the Blizzard because the timbre was more beautiful especially in the highs. I think you would compensate the loss in dynamics with the Niagara from what I read, but I never tried that in my system
May 18, 2020, 03:53 PM #105
- May 2020
- Austria
- 35
I got two Devialet 440 Pro (which is two 220 Pro monos) - so think / Hope they will benefit from the Thunder High Current.
May 18, 2020, 04:32 PM #106
- Apr 2020
- Belgium
- 16
May 19, 2020, 02:20 PM #107
Devialet use own produced switching power supplies
Gesendet von iPad mit Tapatalk
May 19, 2020, 03:01 PM #108
- May 2020
- Austria
- 35
Is this good or bad in view of the Thunder High Current?
May 20, 2020, 12:42 PM #109
You don‘t need the HC implicit.
May 20, 2020, 02:11 PM #110
- May 2020
- Austria
- 35
I ordered it already )
May 20, 2020, 02:27 PM #111
- Apr 2020
- Belgium
- 16
I use Jeff Rowland 725 amps, they use analog amplification circuitry but have switching power supplies.
I do not have a Niagara 5000, but when comparing Blizzard and Thunder on the power amps, I found they did need the extra dynamics of the Thunder on bass driven music. Switching power supply amps are very effecient but they actually need better powercords then amplifiers with normal power supplies, as the consumption of current from the net varies much more. So contradictory to what one might think because of low normal consumption of switiching power supplies, you actually do need a very good and dynamic powercord because the instanteneous current draw from the net of switching supplies could be comparatively much higher
May 20, 2020, 02:38 PM #112
- May 2020
- Austria
- 35
Very interesting to hear - thank you very much for your insights!
May 21, 2020, 02:30 PM #113
JanDedicated room: Confidence Mansion
Electronics: Trinnov Altitude32 | VAC Signature 200 IQ mono’s | Parasound Halo JC-1’s + A51 | Synology DS918+/DX517 (48TB) | Oppo BDP-105D / UDP-203 CM Stufe2
Speakers: Von Schweikert VR10-MKII system | Dynaudio Confidence C4 | Velodyne DD-18
Projection: JVC DLA-NX9 CM | Stewart 123” StudioTek 1.3 G3
Various: Artesania Exoteryc 3L + Aire racks | Schnerzinger Emi + Giga Piccolo A3 | PS Audio Stellar Power Plant 3 | iPad Pro 12.9” (2018) | Roon
Cables: AudioQuest Huricane EC | Nordost Frey speakercable | AudioQuest Diamond RJ/E | AudioQuest Diamond HDMI
May 22, 2020, 03:46 PM #114
- May 2020
- Austria
- 35
I hope to be able to report soon about the difference Niagara 5000 and Thunder cables made to my system
May 27, 2020, 07:20 PM #115
- Mar 2017
- Berlin, CT
- 259
I look back and probably should have gotten Dragons over Hurricane. Mike told me they are that much better. I heard Mikes MSB set up with Dragons and was BLOWN out of the water by it, lol. I ended up with Hurricane's throughout as Firebird wasn't out when I bought. He didn't have power or source then either. I was waiting to get them after hearing the prototypes with Garth a few years ago. Even with the clear jackets and not totally refunded yet, they were on another level than any cord I had ever heard.
Listen to Mike when he tells you to do the upgrade, lol. .System:
Vandersteen Quatro CT
Ayre AX5/20
The Memory Player with built in DAC and headphone amp built in on order
AQ Niagara 1000 power device
Audioquest William Tell bi wire speaker cable
Wireworld 8 optical cable into the Empirical Audio Synchro Mesh from the TV and Blueray to reclock
Wireworld Platnium 8 ethernet cables into the EMO 70e ethernet filter into The Memory Player from Eero mesh router
All routers, cable box and synchro mesh powered by the Wyred4sound LPS box with separate supplies for each
Audioquest power outlets and four dedicated power lines in the room
ZMF Ori headphones with the Audioarts 15' Pono balanced cable for the QX5/20
Empire Ears Phantom CIEM's
Rhapsodio 2.98 mk2 gold plated silver cable for Phantom
May 27, 2020, 07:38 PM #116
May 28, 2020, 03:21 PM #117
- May 2020
- Austria
- 35
Are you using them also in combination with a Niagara?
May 28, 2020, 07:17 PM #118
May 29, 2020, 04:11 AM #119
Triangle Magellan Concerto 2 < AQ Everest < Vitus Audio SS-010 Mk2 < AQ Dragon HC < AQ WEL Signature XLR < Chord Qutest w UpTone JS-2 & AQ Dragon Source < SOtM tX-USBultra w 75Ohm Master Clock Input, Paul Hynes SR5-12 Turbo XL & AQ Dragon Source < AQ Diamond USB < Aurender N-100H w AQ Dragon Source < Gryphon PowerZone w AQ NRG-Wild < Solid Tech Hybrid < Ansuz Darkz D-TC, Darkz D2, Stillpoints Ultra SS, Omicron Harmonic Stabilizer & Gold SE < Furutech FT-SWS < Synergistic Research Blue Quantum Fuse
May 31, 2020, 07:15 PM #120
- May 2020
- Austria
- 35
Though Dragon is pricewise really hefty.
I still think Thunder & Hurricane deliver outstanding performance for a reasonable price. And especially together with a Niagara they fully unleash their potential.
June 5, 2020, 05:43 PM #121
- May 2020
- Austria
- 35
What are your experiences in burn-in time of HC power cables (I am using two Thunder for Devialet mono amps). How long does it take and to what extend will it improve performance?
June 5, 2020, 09:48 PM #122
June 6, 2020, 04:42 AM #123
- May 2020
- Austria
- 35
Ah thanks! Because I really felt bass is clumsy and midrange / treble quite stiff. Is that the normal behavior? Meaning should the starting performance be already better?
June 6, 2020, 06:15 AM #124
June 6, 2020, 11:35 AM #125
- May 2020
- Austria
- 35
Eager to progress
How far will the performance improve by your experience?
June 6, 2020, 04:56 PM #126
June 6, 2020, 06:08 PM #127
- May 2020
- Austria
- 35
Thank you for the input. Will listening at higher volume accelerate things? Or is it just a matter of time. Btw the most striking difference in the feel that things are not quite right is the perception of unbalanced frequencies / disharmonics.
June 14, 2022, 03:25 PM #128
- Sep 2016
- Germany
- 54
An AQ dealer sold me a "new" 2 .0M NRG HURRICANE HC EU IEC15 . When I unpacked it, I saw that it was red. Are there any differences between red and blue? Do they have different UPC/EAN codes? I just saw, that the picture of the hurricane on the back of the packaging is blue and there is also a picture of a red firebird? Why does AQ tell me, there is the "NRG" in the name of the cable? Is it or was it? The pictures of the AQ website in the beginning of this thread say for the red Hurricane EU connector: cold welded connectors. For the blue Hurricane US connector it says: hanging silver over red copper?
Thanks DirkVitus Audio SIA-025Mk2 + SS-025 (biamping), Gauder RC7 Diamond black edition, Vitus Audio SCD-025Mk2, Simon Yorke S9+Jan Allaerts MC1 Boron+Dr. Fuss power supply+AS Phonolab, Amazon 1+SME V+Ortofon Rohmann+Nagra BPS, Oppo BDP-105D modified by Gert Volk Audio, Melco N1Z/2 EX H60+D100B+Sbooster, Copulare Grand Porto, Magnan Signature speaker cable, Magnan Vi XLR + RCA, Göbel Lacorde Statement XLR, Göbel Lacorde Statement USB, AQ Diamond + Vodka RJE, Buffalo BS-GS2024 Switch, modified 10Gtek+Startech 1000Base Fiber, Wireworld Starlight 8 CAT8, Vitus Andromeda power cable, Aural Symphonics Magic Gem power cable, Aural Symphonics Cubed v3 power bar, Stillpoints Ultra SS + Ultra mini, Ansuz Darkz, Shun Mook Mpingo Discs, Hifi tuning supreme 3 fuses, ahp Klangmodul 4g fuse module, HMS wall socket, Block Audio C-Lock lite, Furutech NCF Booster. Room 40 m2.
June 14, 2022, 04:01 PM #129
- Mar 2017
- North Carolina
- 808
IIRC the original Hurricanes had red jackets. AQ switched to blue jackets (what I bought) before coming out with Firebirds, which had red jackets like the original Hurricanes.
June 14, 2022, 05:10 PM #130
- Sep 2016
- Germany
- 54
As far as I can see, it doesn't say "high current" anywhere on the red cable. How do I know it is the high current version? I have to weigh the cable?
Thank you for making me feel less tech challenged.:whew: FYI, The 866 works great as a straight, no nonsense integrated with DAC.
Boulder 866 app
