Results 1 to 23 of 23
March 27, 2018, 05:28 PM #1
- Feb 2018
- Seattle, WA
- 7
Audio Research LS17 SE... amp parining?
Hey everyone. I just bought an ARC LS17 SE and I'm not sure what amp to pair it with. I've been using a solid state amp but I guess I'm open to tube amps as well. Looking for a warm bright sound if that helps. Does anyone here have a match they are especially fond of?
March 27, 2018, 07:32 PM #2
Re: Audio Research LS17 SE... amp parining?
Cheers ! …. Dave
March 27, 2018, 08:27 PM #3
Budget?
And current speakersFleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
April 17, 2018, 11:57 AM #4
- Feb 2018
- Seattle, WA
- 7
Mikado463, thanks man! My budget is between $1K and $2K and I have a set of Dali Mentor 5 speakers that have been very good to me. That will change soon as I'm also going to buy a pair of Harbeth C7s so that will be the amp-speaker pairing. Not in a huge rush and I'm willing to wait until the right match comes along. Definitely excited to see how the ARC LS17 sounds with the new setup.
April 17, 2018, 05:52 PM #5
here's one suggestion .......... http://www.rogueaudio.com/Products_100.htm
since you bought your ARC used I'm assuming not opposed to buying a used amp as well.......Cheers ! …. Dave
April 18, 2018, 05:39 AM #6
so you need to get a good amp to match the harbeths , what power amp are you using at the moment with the arc ?
1]bel canto EIX/ F5 monoblocks . BC cd2, tannoy eaton legacy 2]bel canto pre 5 ,arcam a85 , black ice modded dac
April 18, 2018, 08:50 AM #7
- Feb 2016
- west Michigan
- 713
Jeff, To get some solid reccomendations it is necessary to know a bit more about your music taste, what you value most in an audio systems presentation, size of the room, etc.
The more information you provide the better match could be suggested.My System
Acoustic Revive RTP-4
Innuos Pulsar
Lampizator BALTIC4
Cary SLP-05
Pass XA30.5 or
Line Magnetic 845ia
Reference 3A Reflector's
Pr SVS SB3000 Subs
Core Audio Design Rack
April 18, 2018, 09:17 AM #8
and join the harbeth facebook group run by paul yoo on here and see what amps they use . which include pass labs , sugden and many others .
April 18, 2018, 10:20 AM #9
- Feb 2018
- California
- 10
Might want to consider what Alan Shaw says in the user forum: "The question of 'will this amp work with these speakers?' seems to have a life of its own. I just cannot fathom out why there is so much anxiety about grabbing any competent amp and hooking it up to your Harbeths and making great music. It seems to me that the fundamental essence of a good amp, well designed and working to original specification is that it must be relatively load-independent and the essence of a good, well designed speaker is that it must be amplifier-independent. So what's the anxiety about then? Who has planted the fear in the minds of an entire generation of hifi consumers that the amp/speaker interface is super-critical to the musical experience? With Harbeth it isn't." That being said, congrats on the ARC LS17!
April 18, 2018, 03:51 PM #10
I not so long ago got the LS-17 SE also. I have tried a few amps along the way but am currently using the PS Audio M700 mono amplifiers. These retail at $2998 a pair but you should be able to get a pair in the low $2k's.... since these are a new model and very popular and have been getting great reviews you will probably not see a lot used out there.
The stereo version also worked rather well for me, the S300, but the M700s are considerably better.
I power KEF R700, another European designed speaker, so probably similar to the speakers you are looking at.McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
― Neil deGrasse Tyson
April 19, 2018, 09:28 AM #11
- Mar 2018
- Traverse City, Mi
- 10
I use tubes and the greatest thing about the LS17 is that I don'thave to think or worry about it. Like Mikado463 said, the amp has more to dowith the sound you want AND your speakers. Come over to the tube side... you won't be disappointed.
April 19, 2018, 09:49 AM #12
- Apr 2018
- 8
ARC is a solid brand so congrats on the new ARC LS17! If you're open to both Tube or SS, I'd say solid-state are, watt for watt, cooler running, more reliable and cheaper than tubes. That being said, Tubes are still around for a reason... because they offer such a unique sound. Personally, I like both for different reasons. Tubes can be a bit finicky with certain speakers and SS amps tend to be more forgiving in their speaker pairings. Since your open to both, you might want to look into Pass Labs Alephs amps or a used Luxman Tube Amps.
April 21, 2018, 10:39 AM #13
have a look here re amps for harbs . personally i would use a nice powerfull ss amp with your arc
What amp on Harbeth speakers ?
like a modwright or a belles
i used arc ref 5 and 5se into belles monoblocks1]bel canto EIX/ F5 monoblocks . BC cd2, tannoy eaton legacy 2]bel canto pre 5 ,arcam a85 , black ice modded dac
June 26, 2018, 06:06 PM #14
I am changing directions on the amp(s) that I am using with my ARC LS-17 SE. I am going to try a T+A amp. From all I have read and hear they are supposed to be the type of amplifiers that should fit the bill for me. Knowing how much I love my T+A DAC I know the quality, build and design will be satisfying. The sound performance should be right up my alley, so to speak!
June 26, 2018, 10:36 PM #15
- Nov 2013
- St. Louis, MO, USA
- 3,067
Suncoast mentioned on another thread he took in an ARC 75se, may be out of the budget, you'd have to check, I'd think ARC would work well with ARC and be a nice match with the Harbeth.
SVS PC13 Ultra
Sony XBR-75X940D & BDP
July 13, 2018, 04:35 PM #16
It really depends on your use as well. I have had amplifiers with way too much power (PS Audio, Son of Ampzilla, etc.) but I seem to prefer the amps with lower power. Maybe because I do not listen very loud and I love open amps with great sound stage and instrument definition.
I really enjoyed the First Watt and the Goldmund Job amps, but felt neither would be my long term solution. I also really loved the sound of the Quicksilver tube amps I owned, but they were way to finicky and seemed to change with the weather (very weird indeed), and the classic ARC tube amp I had. loved the build but felt it was a bit too old to depend on it completely moving forward.
The T+A gives me everything that I loved with the FW (accurate, open, smooth) and the speed of the Goldmund.... warmth of the QS, plenty of power for my use.... the only issue that I see is believing that so much can come from such a small package.McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
July 18, 2018, 10:41 AM #17
- Oct 2017
- 175
i paired my ls17se with an arc d120 (recapped in 2008) and an odyssey kismet (every single possible upgrade without going monoblocks). i also had it function as the pre for an ayon spirit 3. they ran great on a pair of raidho c1.1 and dyn contour 1.4le but i sold the ls17se for a soulution 721 so did not have a chance to test on my magicos
the ls17se was a great preamp but after some time i noticed that the soundstage depth was lacking and that the overall tone was whitish. i haven't had the pleasure of hearing some of arc's higher end pres.
if i may make a suggestion: i've found that preamps are the 2nd most important part of the chain (speakers being first) in terms of setting system tonality. one test that helped me come to this conclusion was the ls17se+ayon pairing...without it the ayon tonality was there in the system, with it - the sound was remarkably close to the arc stack i was running prior. the raidhos preferred the solid state amp so i noticed the sound stage was a it smaller and bass didn't go as deep. but it was pleasant and i ran that set up for a few months
i threw more money at a pre and will upgrade amps in the future. if you snag a screaming deal on an amp you might get some real value out of applying the saved funds towards an even higher pre in the arc line. if not, then rest assured that the ls17se is a fantastic choice. i don't want to turn this into an unsolicited ad, but if you're interested in the d120 feel free to pm me. it is sitting unused and is a great piece of gear
sorry for the scattered thoughts - writing this at work between meetings!
August 10, 2018, 09:45 AM #18
- Aug 2018
- 7
Everyone responds to this type of thread by recommending what they own, so one more wont heart, right?
Odyssey makes solid state Kismet monoblocks housed in their Khartago boxes to keep the price lower. These can be found used between $1k and $2k. Besides being comfortable with about any load, you mentioned wanting warm/bright sound. Those terms don’t normally go hand in hand, but the cool thing about these Odyssey amps is that they can be biased to produce warmer or more detailed (brighter) sound. Dial them in for the best synergy with your system, room and ears.
Odyssey will bias them for you, but it would be best guess based on a conversation. Also, Odyssey is very backlogged right now so it would take a while. Call them for instructions and do it yourself!
August 10, 2018, 10:08 AM #19
- Oct 2017
- 175
yeah my process with klaus @ odyssey was extremely seamless and the bias to the voltage in your socket is super helpful. in nyc, my 110v socket was actually putting out 124v on average (and on median). so having it biased for my weirdly high voltage helps everything
the only negative is the back log. i ended up having to wait 6 months for my amp and at many times through the process i would see attractive pieces on agon and consider cancelling my order. one time, i called klaus and asked him if i should cancel to pick up another amp i was eyeing. he, very simply, walked me through why he though the kismet would be better and where the competitor amp might outshine - it is hard to express just how un-salesy and not-pushy he was in that convo (as well as all my convos with him)
i am super glad i waited because the product i got blows my mind. it's just as comfortable with magicos and a soulution pre as it was with some raidhos and a caravan of pre's (none touching the refinement or price! of the soulution). i genuinely feel its a world class amp and will be the last piece i upgrade and would only really be replacing it with a 710/711 or equivalent constellation/boulder gear i.e. mega-amps when thats a fiscally responsible decision.
August 10, 2018, 10:09 AM #20
- Oct 2017
- 175
p.s. for any sharks in the nyc area that would like to hear the amp - shoot me a pm and i'm happy to have you over for a demo
September 26, 2018, 01:42 PM #21
So a bit of an update. I really like my LS17 SE. It seems to be built fantastic, sounds wonderful without a bunch of frills. One feature it has that I really find important is that the pre-amp has three outputs which is very important to me.
The reason that three outputs is so important is a bit of a change in direction. I love the T+A amp, even though it is so small... , and as I said I was impressed with the Goldmund Job 225 amp... so a recent find thanks to another AS member.... the NuForce STA200.... this little amp is developed by Goldmund and distributed under the NuForce name... basically it is the Job 225 at a little less power.... The rear looks identical to the Job other then better connection being used on the NuForce.
The bottom line is the recent sale was so low that I could not resist.... getting a Goldmund amp at this price was simply incredible... and I have been able to use my Rothwell Attenuators to match the levels.... and using both amps in a bi-amp configuration... it seems to be a really great combination ...
Therefore three outputs are important because bi-amping uses two outputs and the third to go to the subwoofer. From what I can tell the current ARC pre-amps have only two outputs (assuming that on output 1 and 2 you can use either the XLR or RCA, but not both).McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
September 26, 2018, 01:48 PM #22
- Oct 2017
- 175
awesome! sounds like a great set up. pardon my ignorance, but are all nuforce amps developed by goldmund? until i read this post i didn't know there was any relationship between the two companies. any links with more info are appreciated
September 26, 2018, 01:59 PM #23
From my understanding, no. This is a special case. As I read, Goldmund wanted to offer a more value oriented line of gear, but not in the Goldmund name. They already had a relationship with the company that owns NuForce (they made projectors, etc., which Goldmund uses), so Goldmund approach them with this idea. The STA200 is a first, test model to see if this might be warranted. It is basically a slightly lower power version of the Job 225. Reviews, including one done by The Absolute Sound have been very positive!
So, the Job 225 priced at $1699 and 125 WPC; the NuForce STA200 priced at $1299 and 80 WPC. Might be the Job is a better value??? But, Audio Advisor has them on sale for $499. My God, what a deal....
Certainly not flashy; very basic case (but it is metal and solid) and no real feet at all... little rubber strips.... so I use some isolation cones I have under the amp .... but it is a wonderful sounding amp and definitely has step up binding post and RCA inputs then those used on the Job...
One other thing I just came across, a photo inside the NuForce which shows the Job label on the boards begin used... nice!
Here is TAS review:
http://www.theabsolutesound.com/arti...wer-amplifier/
Job vs NuForceMcIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
Yes, the Digital Director was used in that setup with MSB monoblocks, and Magico M2's.
