Results 51 to 71 of 71
Thread: AQ Diamond Ethernet
January 17, 2019, 02:19 AM #51
Re: AQ Diamond Ethernet
Just saying, the manual states that they have tested replacement power supplies up to 1 KEUR, and found them to have a detrimental effect.
Not sure whether anyone on the forum has tried it anyway. At least so far, I have not. I do have a bunch of LPSUs at home, e.g. from Sbooster.
But I think the grounding might be a great idea.
January 17, 2019, 02:27 AM #52
January 17, 2019, 02:32 AM #53
Would be interesting to hear about the impact of the Wavelength product in comparison.
The relative cost for the Aqvox-modded Netgear switch is mind boggling, but also its impact is surprising. Especially soundstage, imaging, separation and dynamics improve quite nicely. Just shows what a messy affair digital music reproduction is.
But you do need good Ethernet cables with it.
January 17, 2019, 03:02 AM #54
January 17, 2019, 03:31 AM #55
January 17, 2019, 06:22 AM #56
- Jan 2017
- Leyden
- 596
Pre amp: Ocatve Phono Module Power amps: Octave MRE130 Turntable: SAC Girati Grande. Tonearm: Dynavector 507mkII Cartridge: Dynavector Ikeda 9TT Streamer: Aurender A10 Power Distributor: Anzus Mains D8 Speakers: Raidho X-3 Speaker Cables: AudioQuest Rocket 88 XLR Interlink: Ansuz A2, [B]XLR Interlink: [B]Phono interlink: Cammino Serie 1.0 - PH 1.0s Power cables: Anzus Mains Ceramic, two Pom, Aluminium, X series Audio Rack: Rack of Silence 4 and 2.
January 17, 2019, 09:28 AM #57
Speakers: Wilson Alexias
January 17, 2019, 04:39 PM #58
AQ Diamond Ethernet
Chin, your and Ritmo’s positive experiences with the AQ Diamond convinced to try it in my system as well.
So, today I placed an order for an AQ Diamond Ethernet cable to put between the Aqvox SE and the DAC. Let’s see what is the impact, so far my experiences with AQ are rather good.
January 17, 2019, 04:47 PM #59
January 17, 2019, 04:51 PM #60
January 17, 2019, 05:05 PM #61
I currently have:
AQ Vodka > Aqvox SE > AQ Diamond > Lumin X1. I liked the Aqvox when I installed it a few months ago... I think I probably should do an AB comparison and listen to the differences again. As with many things the Aqvox is a bit system dependent, but most commentary seems to agree that it makes a positive difference. Of course, there will always be naysayers, but I have liked it so far.
January 18, 2019, 03:27 PM #62
With my current setup I have a switch attached to my Orbi unit in a upstairs closet. I have a few devices hardwired to that switch including my dCS Upsampler which is connected to the switch via a long run of ethernet cable. I was considering adding a second switch just before the Upsampler and then using a high quality ethernet connection such as the AQ Diamond to complete the connection. Disregarding other devices this is how it would look.
Cable modem--->Orbi Router--->Network switch---long ethernet cable---->Network switch---->AQ Diamond??--dCS Upsampler
Would you expect any SQ improvement with the addition of a second switch and the AQ ethernet connection?Jim
January 18, 2019, 04:11 PM #63
Hi Jim - No and only for the reason I am a believer less is more using the straightest, shortest path. I do believe you would gain if you make your current switch an audio switch and use a higher end ethernet cable like you mention. AQVox makes a switch I use and like, and The Linear Solution whom I stumbled on in the greater Seattle area literally 5 miles from my home makes OCXO and TCXO switches and routers.
Hope this helps.Source Analog: Kuzma Stabi R w/4point 11 arm | Kuzma 50 Cartridge
January 18, 2019, 04:51 PM #64
Thanks for the suggestion.
I will stay with the TrendNet switch(s). That switch did what nothing else seemed to be able to do and that is eliminate 100% of all Roon dropouts I was experiencing when I switched from Apple to Netgear Orbi back in August.
The reason I asked about adding the additional switch and AQ cable is that I don't want to clutter my 2-channel room with extra devices so that is why my network
gears remains hidden in a closet with all of my network gear. I just have one hidden ethernet cable entering my 2 channel room. I have absolutely no complaints on met SQ but was just looking for a simple and hidden upgrade.Jim
January 19, 2019, 04:29 PM #65
DPT4ME - Dynamics, Presence & Tone for Musical Engagement; MBP (3) - stripped down for music only; Shunyata Omega & Sigma USBs; ISO REGEN w/short Curious USB links; Berkeley Alpha USB; Aqua La Scala II Optologic DAC; Schiit Yggdrasil - fully updated; Ayre Codex dac - updated; Pass Labs INT-60 integrated amp; Wyred 4 Sound STP-SE-2 preamp, Quicksilver Mono 120 amps w/Tung-Sol KT150s; Quicksilver Mid Mono amps w/Gold Lion KT77s; Fyne Audio 703s; Symposium Svelte Plus & Ultra Platforms; REL S-812 subwoofers; Duelund DCA12GA speaker cables; AV Room Service EVPs, Stein Music Harmonizers, Duelund DCA16GA & 20GA ICs; Shunyata Denali 6000S/V2; Tripp Lite PCs; Wyred 4 Sound power cords; AudioDharma cable cooker; dedicated custom room; various GIK & ASC room treatments; etc.
www.getbettersound.com
January 20, 2019, 08:38 PM #66
I have the normal Aqvox (not SE) the input voltage is 5 volt.
Effectively the manufacturer recommends not changing the PSU. In my experience the LPSU of Kenneth Lau is much better than the SMPS that comes from origin.
On the other hand I have two Ethernet AQ Diamond cables that I have not used. The one that goes from the Aqvox to the Melco because I changed it for a Göbel cable and the one that went from the Melco to the Lumin because I changed the Lumin for a USB DAC, so soon the two will come out for sale. If someone is interested, PM to me.Francisco
January 25, 2019, 02:23 PM #67
Just installed the AQ Diamond Ethernet. I’m extremely pleased with the performance. While I expected to improve on the off the shelf cable I had been using, I was not expecting the significant difference and improvements I’m hearing. Highly recommended!
_______________
Phono Pre: Pass XP-27
Speakers: MBL 101E MKII
Rack: Artesania Exoteryc
January 25, 2019, 03:21 PM #68
Jim
January 25, 2019, 03:53 PM #69
_______________
January 25, 2019, 07:14 PM #70
AQ Diamond Ethernet
Added the AQ Diamond to my system about a week ago. First day was horrible , with the cable sounding thin and flat against the AQ Vodka. Details were good though. But could not avoid the thought “ah, this is how a silver cable sounds like”.
But after settling in a bit, it developed very nicely. Detail retrieval is great, tonality is transparent and balanced. But IMHO it really blows other cables away with its dimensionality, incredible soundstage width, and especially depth, and ability to convey ambiance of the venue. Very happy with it.
January 26, 2019, 12:00 PM #71
Jim
Congrats Mike! Great sounding and beautifully finished gear. Heard them at FL Expo in 2022 and 2023 front ended by Lampizator - very enjoyable.
Tobian SoundSystems
