Results 1 to 15 of 15
January 20, 2018, 05:03 PM #1
- Sep 2017
- 16
Pass XP-30: Any DAC recommendations?
Any thoughts out there on which DACs might have great synergy with a Pass XP-30 preamp? What are others here using?
January 20, 2018, 11:26 PM #2
- Nov 2013
- St. Louis, MO, USA
- 3,041
Re: Pass XP-30: Any DAC recommendations?
This may be a reach as I'm on a smaller scale than you, I like my Levinson with Pass, I still have Pass pre but switched from Pass amp. Brian of Bricasti used to be with Levinson and I like his DAC quite a bit. The way the Bricasti was set up the times I heard it, I found it to be quick and nimble with a smooth presentation, not warm, just a nice musical presentation. I suspect it would have nice synergy for you.
To my ears I found the Direct Stream to lean some more analytical than Bricasti and Lampi fuller than both, warm but not overly so.
I think Lampi would have synergy bringing a fuller presentation. It depends on which way you want the system to lean. In my system I found staying with balanced circuits to sound better. That's not always been my experience, but it was when mixing the Pass & Levinson.
There's a good Pass following here, I'm sure you'll get some good feedback.
Welcome to the Shark.Aurender ACS10 w/Audioquest Diamond USB, Esoteric N05xd
SVS PC13 Ultra
Sony XBR-75X940D & BDP
January 20, 2018, 11:33 PM #3
The DAC in my Lumin works great with my XP-22. However, I suspect any decent DAC, along with good cables, will work well with your Pass.
Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
January 21, 2018, 08:13 AM #4
I used the Esoteric K-01 Player/DAC with the Pass XP-30 preamp when I owned it and it was a terrific combination.
January 25, 2018, 05:33 AM #5
- Apr 2015
- Hong Kong
- 8
Schiit Yggdrasil DAC sounds great in my system.
Aurender N30 - EMM Labs DA2 - Pass Labs XP-30 - Pass Labs X350.8 - B&W 802 Diamond - PS Audio DirectStream P12
January 25, 2018, 10:15 AM #6
- Mar 2017
- North Carolina
- 806
January 25, 2018, 03:20 PM #7
- Mar 2017
- North Carolina
- 806
January 25, 2018, 05:45 PM #8
- Sep 2017
- 16
Budget around $2000. XLR outputs. Really would like HDMI inputs but I know that option os pretty limited. And yes, DSD.
February 3, 2018, 02:31 PM #9
Find a used Bryston BDA3.
Sent from my iPad using TapatalkPreamp/Digital: Meitner MA3
HT Processor: Bryston SP3
Amps: Bryston 14b3, Bryston 4b3
Speakers: Kef Reference 5, Kef Reference 4c
Sub: REL Carbon Special
Power: Shunyata Denali, Bryston BIT15
Wires: Wireworld Silver Eclipse XLR & SC, Ethernet - WW Platinum USB
Other: Stillpoint Ultra SS, ISO-Acoustics ISO Pucks
-Kyle
February 3, 2018, 09:17 PM #10
- Nov 2013
- Minnesota
- 1,369
Yiggy sounds like your best bet. I had this Marantz NA-11s1 and loved its tone, texture and dynamics. It has a beautiful rich mid range. However it was not a good match with my BAT preamp as the bass was too much. It had the best sounding piano and female vocals that I have heard in a DAC. It is also built like a tank.
https://www.musicdirect.com/network-...k-audio-playerMy Gear- Mains System-Pass X250 amp, BAT VK-51se preamp, Luxman DA-06 DAC, Magnepan 1.6's, Thorens TD-145 TT, Dual Martin Logan Subs, Vintage Luxman T-110 Tuner, Cables-WW Platinum 7 USB, Cardas Parsec XLR, AQ Columbia DBS 72v XLR, Belden 8402 XLR.
February 3, 2018, 11:13 PM #11
-Kyle
February 4, 2018, 02:41 PM #12
- Sep 2017
- 16
"The biggest problem with Schiit is the lack of DSD support." I agree, I think if they had it, I would be getting one.
February 4, 2018, 09:34 PM #13
- Nov 2013
- Minnesota
- 1,369
Yep, forgot that it does not do DSD. You are welcome to stop by my house in Woodbury to hear my Luxman with my Pass X250. They occasionally come up for sale used. It is still a stereophile A+ DAC. Another DAC to give a listen to is this AVA Hi Fi DAC. I had it in my system and did a review on it for Frank Van Alstine. It sounded better than my Luxman DA-06 in some respects. Frank has a 30 day money back guaranty. You can give it a listen at Frank's house in Woodbury. He lives about 3 minutes from me. Tell him Larry referred you. It punches above its price point for sure since my Luxman use to list at $6K.
https://avahifi.com/collections/d-to-a-convertersMy Gear- Mains System-Pass X250 amp, BAT VK-51se preamp, Luxman DA-06 DAC, Magnepan 1.6's, Thorens TD-145 TT, Dual Martin Logan Subs, Vintage Luxman T-110 Tuner, Cables-WW Platinum 7 USB, Cardas Parsec XLR, AQ Columbia DBS 72v XLR, Belden 8402 XLR.
February 8, 2018, 03:54 PM #14
- Sep 2017
- 16
Thanks Mechnutt,
The Luxman definitely looks like a nice option.
May 13, 2018, 01:25 PM #15
- Aug 2014
- 82
I use the xp20.
for me go with a Lumin or similar (all in one) and a cd player unit added...
if you will a"extern" Dac Métronome C8 PLUS or Emmlabs.
Rockna and Bricasti are too very interessing.
Great looking room and system! And, nice vinyl collection! Congrats to the new Clarysis owner!
