Results 1 to 40 of 40
Thread: Tube Integrated Help
January 19, 2018, 11:09 AM #1
Hello All!
I am looking to jump back into the game with a very small and very budget-oriented setup in my bedroom. I am looking for a tube integrated that produces sound that is typical of valves (warm, organic, etc.) but won't come close to breaking the bank - does that exist (check out my budget below)?
A few items I am hoping to stick to:
- Under $1,000
- Headphone jack (not a deal-breaker, though)
- Smaller footprint (hoping to put this on/near my nightstand)
- Open to used equipment
A few things to keep in mind - I am hoping I can stay this cheap as it won't take much to improve what I am using now, which is an Amazon Echo to listen to music and podcasts at night. I figure a low powered integrated will be more than adequate to power some efficient bookshelves. I have been souring the boards here and the rest of the interwebs to get as educated as I can on (budget) tube amps. Here are a few that I have come across so far:
- Icon Audio MP 3 (From an UK-based company that sells on Music Direct; I don't know if they offer this model in the US so I might be out of luck)
- Jolida 1102/3502 (I read how Joe loved his 3502 before letting that go to his brother. Obviously, this hits above my budget)
- Icon 20 PP
Please let me know what additional info will help you help me. All advice is appreciated; thanks in advance!Sean
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
AudioQuest Hurricane HC
HRS E1
January 19, 2018, 11:47 AM #2
Re: Tube Integrated Help
PS Audio Sprout seems to get a lot of nice comments in the reviews
And the NAD 3020
Arcam A19
A tad over $1000 the Rogue Sphinx
What speakers you using2chl : Vincent Sp331MkII, W4S STP-SE Stage 2, Kef 201/2, KEF 140, Vapor Breeze, Lumin, Bryston CD, BHA-1, Quicksilver Headamp, HD650, HD800s, HD820's, Dan Clark 1.1, Focal Stellia, OPPO 203, 105. ( Boxed up: Pass Xa-30.5, VPI Classic, Dynavector DV-20XL, Manley Chinook, Cadenza Bronze)
January 19, 2018, 12:05 PM #3DSkipGuest
Jolida is about as nice as it gets for a tube integrated under $1,000. However, IF you can find a used one OR up your budget to $1,500, the iFi Stereo 50 is an incredible value and unmatched in the $1,500 and under price category. For your application, it sounds perfect. I sold mine about a year ago and have regretted it since.
If you want to try something that doesn't have the glow but gives the sound of an entry-level tube integrated, check out the Dayens Ampino. An upgraded unit with Mundorf caps runs $672 new. I recommend this unit to most anyone who is looking for tube integrateds under the four figure mark.
January 19, 2018, 01:36 PM #4
So I would pull my cheap but decent HT surrounds for interim use - AAD M series bookshelf.
For down the road, I was looking at things like the Klipsch RP 150/160 and Martin Logan LX16. Again, primary restriction being keeping the budget down. I am open to suggestions for these, though, too.
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
HRS E1
January 19, 2018, 01:41 PM #5
January 19, 2018, 04:10 PM #6
- Nov 2013
- St. Louis, MO, USA
- 3,068
I know there's a Van Alstine Ultra Valve integrated used for $1100.00. I'm not sure what the going price is used on those normally. You can check hifishark
Just another option and Frank still answers the phone if you need support.Aurender ACS10 w/Audioquest Diamond USB, Esoteric N05xd
SVS PC13 Ultra
Sony XBR-75X940D & BDP
January 20, 2018, 09:52 AM #7
Sean
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
HRS E1
January 20, 2018, 07:44 PM #8
Hi Sean,
It’s great to see you again. There’s some good choices here.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
January 20, 2018, 08:42 PM #9
- Nov 2013
- Minnesota
- 1,369
The Ultra Valve is not an integrated amp. It requires a preamp. I agree about the Jolida. People seem to like them.
Here are a couple of used options-
https://www.audiogon.com/listings/tu...7-70f8ef6653f5
https://www.audiogon.com/listings/tu...20-integratedsMy Gear- Mains System-Pass X250 amp, BAT VK-51se preamp, Luxman DA-06 DAC, Magnepan 1.6's, Thorens TD-145 TT, Dual Martin Logan Subs, Vintage Luxman T-110 Tuner, Cables-WW Platinum 7 USB, Cardas Parsec XLR, AQ Columbia DBS 72v XLR, Belden 8402 XLR.
January 20, 2018, 11:01 PM #10
- Nov 2013
- 3,068
SVS PC13 Ultra
January 20, 2018, 11:33 PM #11
January 20, 2018, 11:35 PM #12
January 20, 2018, 11:36 PM #13
Sean
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
HRS E1
January 20, 2018, 11:41 PM #14
Thanks! I'd love to say I'm done but you never know with me
I absolutely loved my Jolida and so did my brother. He had to have it and took it home. I finally got the money out of him. Thank goodness.
If you are a headphone guy, my Linear Tube Audio MZ2 is insane. You can start small for about 1100-1200 but unless you have little super efficient speakers, it may not cut it.
Sent from my SM-N910P using TapatalkFleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
January 21, 2018, 09:18 AM #15
Sean, for music and podcasts, you might also consider the Dynaudio Music 7.
Looks good and produces very decent sound.
Just under 1K here.
https://www.dynaudio.com/home-audio/music/music-7
I know it's not a tube thingie (which I love by the way!), but it has a high wife acceptance factor and streams and has speakers on board (40 Hz - 20 kHz).
What more do you need in a bedroom?!Vivid Audio - Burmester - Hegel - Marantz - Oppo - Pioneer 60" - Wireworld
January 21, 2018, 02:47 PM #16
saw this on tubedepot.com and thought i would pass it along just in case... very budget friendly and small footprint for the nightstand.
http://www.tubedepot.com/products/tu...tube-amplifier
January 21, 2018, 08:16 PM #17
Sean
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
HRS E1
January 21, 2018, 08:20 PM #18
Thanks for a super practical solution to my difficult ask. Bluetooth speakers are so simple and produce good enough sound for various tasks, especially streaming; they’re hard to ignore. I just think I won’t be happy unless I go the tube route...so I guess I’ll have to open up my budget to be able to check all the right boxes.
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
HRS E1
January 21, 2018, 08:21 PM #19
January 21, 2018, 10:06 PM #20
- Jul 2015
- Golden, CO
- 858
Sean,
I second Skip’s endorsement for the iFi Retro 50. The Swiss Army Knife of tube amps. I picked mine up on AudioKarma for around 1/2 off retail. I also have a Melody SP3 which cranks out around 40 wpc of pure tube goodness. You should be able to find a nice one for under $700. Happy hunting.
January 21, 2018, 11:39 PM #21
- Nov 2013
- Minnesota
- 1,369
If you are going to increase your budget, then you may want to consider a used Primaluna Integrated.
January 22, 2018, 09:03 AM #22
- Jan 2018
- 3
... Sure - there's alot out there in the vintage/used market - BUT I recently took a chance and shelled out $150 for a new Monoprice integrated amp and am pleasantly surprised with it. It easily powers my JBL L-25 Prima speakers (a previous vintage find), and appears to respond well (meaning jumps in sound quality) to different interconnects (presently Harmonic Tech Pro-Silway MK lll I got as pat of another deal) and power cords (presently using a 2 meter used PS Audio X-Stream Statement SC I purchased for $175). So I skinned the cat by maximizing the machine with vintage speakers and quality ancillaries...
I'd suggest you put your money into music - try the Monoprice amp for 30 days and realize it's most times the music not the equipment that brings you joy and makes you smile.
January 22, 2018, 09:24 AM #23
This is a tad above your price point, but a killer little hand made amp by Steve Monte of Quest for Sound for $1350
http://www.questforsound.com/amps/amps_sq84-V2.htm
Brian
January 22, 2018, 10:11 AM #24
January 22, 2018, 02:49 PM #25
Sean
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
HRS E1
January 22, 2018, 03:37 PM #26
- Jan 2018
- 3
February 2, 2018, 12:20 AM #27
Thanks for all the suggestions. I think I’ll just kill my budget and do a McIntosh MA-252.
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
HRS E1
February 2, 2018, 03:01 AM #28
Excellent choice.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
February 3, 2018, 06:47 PM #29
I think so, too, Joe. Mac, after all, was what got me into Audio in the first place.
Now, which cables (SC and IC) will pair well with the MA-252? Joe - Are you still enjoying Kimber Kables?
Speakers will be further down the road; so just my AAD towers for now:
M-5T
Type 2.5-way Floorstanding Loudspeaker
Sensitivity 90dB
Impedance 6 ohm
Frequency Response 40Hz-40KHz +/-3dB
Sean
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
HRS E1
February 4, 2018, 10:17 AM #30
February 4, 2018, 09:44 PM #31
February 5, 2018, 03:24 PM #32
Chris, I am in agreement. Mac's first hybrid integrated hasn't gotten a lot of review ink (at least that I can find) but I imagine it will fall right in line with what we've come to expect from McIntosh, albeit in a watered-down fashion.
I love how the package looks on paper - smaller footprint, headphone output, tube pre, ample solid-state power, and the storied Mac brand. What's not to like?
I won't be purchasing for a bit (after our move), so I will have time to research cables (and speakers for down the road) that mate well with the little amp. Color me excited.
Sean
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
HRS E1
February 5, 2018, 03:28 PM #33
Good to hear. Joe. I know we've seen lots of forum members extremely happy with WW but I'll be open-minded and will start another thread as I continue to research synergistic cables. I want to check out the value-based offerings from the likes of Acoustic Zen, Kimber, AudioQuest, WW, etc.
Sean
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
HRS E1
February 5, 2018, 03:32 PM #34
February 6, 2018, 12:14 AM #35
February 6, 2018, 01:00 AM #36
- May 2013
- 3,242
Sean
I have never heard the Belden's but I have the Dueland IC's and SC and they are a steal.Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
February 6, 2018, 11:13 AM #37
February 7, 2018, 09:24 AM #38
MA-252... nice choice sean! i will be very interested to follow your experience w/ this hybrid amp.
i can also highly recommend cables made from Duelund wire... very economical, even for professionally manufactured cables using this wire. imo, a classic 90/25 situation: 90% of the performance at 25% of the cost. i use both SC and IC employing this wire. for the IC, i am running unshielded as my system and environment are not noticeably impacted by RFI/EMI -- this is less expensive and has better SQ.
February 7, 2018, 08:25 PM #39
I will be sure to share the experience as I bring in the 252; bear with me, though, please. I’ll be looking to acquire after a move in the next couple of months.
More support for Duelund! Must be something to that - thanks for chiming in.
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
HRS E1
March 9, 2019, 04:38 PM #40
- Jun 2016
- 62
Since used was mentioned, for under $1000 you can get a rebuilt HH Scott 299 series which is kind of magical to me. Or you can get a non rebuilt which is what I've done and send it to NOS Valves (Craig is the owner) and have him redo it and should run just under $1k if your a little lucky. Unless you have very inefficient (power hungry) speakers this could work out.
CAT and Clarisys | AXPONA 2024 - Part-Time Audiophile Sent from my iPad using Tapatalk Pro
Clarisys - Axpona 2024
