Results 1 to 30 of 30
Thread: Audio Research REF 160M
January 14, 2018, 11:55 PM #1
https://www.stereophile.com/content/...parent-ref160m
“If you look closely at the photo, you can see that the illuminated power meter on the front panel is transparent, allowing you to see the glowing tubes behind it.” Cool!
January 15, 2018, 12:37 AM #2
Re: Audio Research REF 160M
Those should be amazing.
January 15, 2018, 01:50 AM #3
Just started dreaming about GS150 so now I need to rewire my brain and focus on those - uber cool looking - Livio did a fantastic job once again
LS: Vienna Acoustics Klimt "The Music"
PowerAmp: Nagra VPA
PreAmp: Tobian Soundsystems SC12
DAC: LampizatOr Horizon
Server: LDMS Maximus Music Server
CDT: CH Precison D1
Switch: Edison Creation Silent OCXO Extreme, FiberBox
Power: LampizatOr Kraftwerk 10
Cabling: Signal Projects loom
January 15, 2018, 07:17 PM #4
Curious, 150 watts per channel with 4 KT 150, when CJ in the new ART 150 only uses 2.
I thought that AR when designing an amplifier from the beginning based on KT 150, would "tighten" them more than in REF 150SE.Francisco
January 15, 2018, 07:29 PM #5
Are you sure? I think the ART 150 uses 4. You can’t really tighten anything since each KT150 tube is rated at a maximum output of 70 watts, which if run that hard, would dramatically decrease life span and cause other problems (noise, etc).
January 15, 2018, 08:12 PM #6
Looks good. Carries forward a bit of the GS design. I’m sure it will sound amazing - in the tradition of ARC amps.
_______________
Phono Pre: Pass XP-27
Speakers: MBL 101E MKII
Rack: Artesania Exoteryc
January 15, 2018, 08:24 PM #7
Personally, I like the new REF/GS look better than the old. I'm sure others feel the opposite.
Rance
January 15, 2018, 08:28 PM #8
The pic above is prototype and no where near the finished product.
January 15, 2018, 08:30 PM #9Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
January 15, 2018, 08:35 PM #10
[QUOTE=Mike;227330]The pic above is prototype and no where near the finished product.
Gotcha. But it still seems they are continuing with the same design of the GS, REF 6, etc. which I think is a really cool modern look.Rance
January 15, 2018, 08:39 PM #11
January 15, 2018, 09:01 PM #12
The CJ ART 150 is a stereo model. It has 4 tubes (2 per channel) and gives 150 watts.
The ART 300 is a mono model and with 4 tubes per monoblock (like the AR 160) it delivers 300 watts.Francisco
January 15, 2018, 09:04 PM #13
January 16, 2018, 05:17 PM #14
Here it is
https://www.stereophile.com/images/s...18-ARC-600.jpg
"The Ref160M monoblock offers around 150W into 8 ohms and will cost in the region of $30,000/pair. If you look closely at the photo, you can see that the illuminated power meter on the front panel is transparent, allowing you to see the glowing tubes behind it"
February 6, 2018, 02:02 PM #15
- Dec 2015
- 7
Does anyone know what this means for the current REF 250 SE mono blocks? Is ARC planning on discontinuing the 250 SE's? Thank you.
February 6, 2018, 03:01 PM #16
February 6, 2018, 10:17 PM #17
I am drooling... dam!
― Neil deGrasse Tyson
February 7, 2018, 03:51 AM #18
I do not like the massive gaping hole in the fascia....I can only hope ARC will create the option to buy the amp with a stock standard fascia.
February 7, 2018, 06:16 AM #19
A case of swings and roundabouts, the valve and bias circuit tolerances are more important to match as close as possible with the ARC design, however the CJ is running the KT's a fair bit harder than the former, which design topology produces the least measurable distortion ?
V12 engine Or V6 if you like.
February 7, 2018, 06:20 AM #20
February 7, 2018, 08:41 AM #21
It’s nice that ARC is going to have a lower power and less heat monoblock alternative to the Reference 250SE. It is attractive looking and should be very popular.
February 7, 2018, 08:46 AM #22
February 10, 2018, 05:14 PM #23
February 10, 2018, 05:33 PM #24
Absolutely gorgeous... to bad I will never be able to afford one
February 10, 2018, 05:58 PM #25
I still do not like the look...give me the more easily recognizable distinctive ARC look...
I suspect the new look also draws a definitive line between the old and new designers at ARC.
February 11, 2018, 09:44 AM #26
Hmmmmm, For my part I tend to agree with Jozua on this one.Whilst I love the styling of the GS150 with its large opaque meter panel I find this design to be style too far over function, having said that I haven't seen an image ofthe amp powered up, however I cannot see that swaying me on this one.
February 24, 2018, 04:12 PM #27
Dam, every time I look at this I start drooling again!
February 24, 2018, 04:24 PM #28
February 25, 2018, 08:40 AM #29
Is ARC showcasing it at Axpona?
_______________
July 13, 2019, 09:34 PM #30
Thx for responding, bryans. My experience so far has been incredible. Beyond my expectations.
T+A PSD 3100 HV Owners Around?
