Results 101 to 105 of 105
Thread: Luxman D-08u
September 19, 2019, 03:35 PM #101
- Apr 2016
- 590
Re: Luxman D-08u
I dont own the D-08u but have used quite a few streamers. In my experience the Lumin software is far more intuitive and stable than Aurender’s. I also enjoy Melco’s simpler but super stable player software. I have also found that Melco’s player retrieves Tidal songs a little better than Lumin... but there may be a number of things goin on here.
September 20, 2019, 02:38 AM #102
- Nov 2018
- 1
Re: Luxman D-08u
I have the D-08u, and i use a mac ---->USB to the D-08u and the sound is fantastic. The dac is right up there with the best. I have also try to use Bricasti M1 and Lumin X1 beside the D-08u, but i sold them because the Luxman was better than M1 and very close to reach X1 on my system. I have Spendor sp 200, and I use Tidal Premium.
September 21, 2019, 05:27 AM #103
Re: Luxman D-08u
September 21, 2019, 08:56 AM #104
- Apr 2016
- 590
Re: Luxman D-08u
Has anyone intermittently lost USB connection while streaming music to the D-08u from an attached USB streamer? This would only be apparent if you have a long playlist playing in the background from say a Lumin?
September 21, 2019, 11:34 AM #105
Re: Luxman D-08u
I've used Aurenders with the D08u. Sounds good to me. I compared the Lumin U1 to the x100 in a different system/dac and, while the U1 had marginally better detail retrieval I prefer Aurender's Conductor app to Lumin's and love Aurenders physical buttons (don't always have to have handheld in hand) and fade in/fade out on play/pause. SQ wise it's probably a wash between the N10 and U1.
VBR is not precise. Please ignore the bit rate display.
Lumin supports Plex
