Results 1 to 30 of 30
Thread: Show us your Harbeth stands
January 4, 2018, 10:51 PM #1
I designed these stands and the guys at Core Audio built them out of solid Wenge.
January 4, 2018, 11:41 PM #2
Re: Show us your Harbeth stands
Wow. Amazing.
Sent from my iPad using TapatalkPaul
January 4, 2018, 11:46 PM #3
They look awesome, Caelin.
I still have a pair of stands for the 40’s that are begging for speakersFleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
January 4, 2018, 11:54 PM #4
January 5, 2018, 01:24 AM #5
Something you fellas might try; I am using a beeswax impregnated parchment to couple the stands to the speaker. This instead of using metal feet or soft sorbothane like pucks. The thin parchment helps to couple vibration energy from the speaker - draining it into the stands. Try it if you have wooden stands.
January 5, 2018, 02:53 AM #6
Sounds interesting. I use the classic blue tac on the 3PSRs. But of course that creates more of a spot contact.
Beautiful speakers btw.
January 5, 2018, 09:31 PM #7
January 5, 2018, 09:43 PM #8
January 5, 2018, 10:54 PM #9
First, I tried a Berning ZOTL-40 amplifier. Not really a good match. They sound wooly in the bass and soft on transients.
Then, since I have them, I put the Constellation Centaur II in. A bit of a mismatch price wise and far more power than is required. However, this is a great match for the speaker. Beautifully balanced, punchy and articulate. Soundstaging is brilliant with great depth. Two of the most difficult to accurately portray are the human voice and piano. Both are very realistic with this combination.
I have a Devialet which will very likely be a good match but haven’t put it in because the Constellation-Beth combination is so captivating.
Source equipment is a Constellation Virgo preamp and the Lampizator GG or TotalDAC.
January 5, 2018, 11:23 PM #10
Caelin, I had to Google Wenge since I know squat about wood. Did you use that wood for it’s appearance, or it’s sonic qualities. Or both. The stands do look great and match the speakers.
Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
January 5, 2018, 11:28 PM #11
Thank you. Much appreciated. Would love to hear your system
Paul
January 6, 2018, 12:43 AM #12
Weill mostly it matches the speaker finish. You know, many exotic woods have good acoustic properties. Wenge makes a good wood for stands because it has a high porosity that tends to dampen vibration. I find wood to sound more natural than filled metal stands. But, I have nothing against things like Sound anchors, I use them with the Maggie’s. Really the Beth is a traditional, almost retro, look that I like. It just appeals to my aesthetic sense to put them on wooden stands. If you read some of Shaw’s interviews on the Harbeth design - they intentionally don’t overdampen or use thick cabinet walls. People that have tried to improve these speakers by reinforcing the walls or using thicker cabinets usually end up screwing up the finely balanced sound qualities. So, it is in that design spirit that I intentionally designed an open frame for the stands so as to avoid reflections from the speaker bottom and the stand under it. And I selected a material that would couple well with the speakers wooden cabinet without overdampenimg it. Nor did I want a stand that had its own sound quality that would be incongruent with the speakers natural sound qualities.
January 6, 2018, 01:01 AM #13
Thanks. As I said, I know squat about wood. I bought my rack based on Mapleshade’s opinion maple is excellent for absorbing vibrations, especially compared to rigid materials such as marble, steel, glass, etc. Throw in the tidbit that the string instrument makers preferred maple sold me. LOL
Good job. I love the ‘old school’ appearance of Harbeth speakers.Bud
Sony XA-5400ES SACD
January 6, 2018, 01:20 AM #14
- Oct 2013
- Seattle, WA
- 317
Hi Caelin,
Did the Harbeth 40.2 replace the Devore 096s? If so, how would you compare the sound?
Also, which model of TotalDac do you have?
Thanks,
Anshul
January 6, 2018, 02:05 AM #15
January 8, 2018, 01:45 PM #16
have to confess , i was going to buy some oak furniture to use as stands but money a bit tight so i made mine from chopping boards and staircase spindles at under 100 pounds . i briwaxed them . i shall be using iso pucks on them as per professional studio monitors
P1050199 by , on Flickr
P1050197 by , on Flickr
P1050204 by , on Flickr1]bel canto EIX/ F5 monoblocks . BC cd2, tannoy eaton legacy 2]bel canto pre 5 ,arcam a85 , black ice modded dac
January 8, 2018, 01:46 PM #17
and in case you are wondering my harbs are still being made in the factory and this is the iso puck used in studios . i have found them extremely effective under my standmounts and light floorstanders [18kg]
http://www.isoacoustics.com/isoacous...ovember-issue/1]bel canto EIX/ F5 monoblocks . BC cd2, tannoy eaton legacy 2]bel canto pre 5 ,arcam a85 , black ice modded dac
January 8, 2018, 02:10 PM #18
Wow very creative. May I use these pics on FB?
Paul
January 9, 2018, 01:40 PM #19
you may indeed paul
January 9, 2018, 01:42 PM #20
altho these are for the sh5plus i think if i turn them sideways they may accommodate a m40.2 if one could afford and fit it in the space which is dubious
January 14, 2018, 04:40 PM #21
January 14, 2018, 04:57 PM #22
Do you have a photo. would be nice to see
January 14, 2018, 06:04 PM #23
Here you go...got the old version and the new...
McIntosh - PMC - Aurender - Kimber Kable - WW - Core Audio Designs
January 15, 2018, 01:58 PM #24
nice, I like the look of the one on the left best.
Cheers ! …. Dave
January 15, 2018, 03:08 PM #25
- Aug 2015
- texas
- 45
January 15, 2018, 03:22 PM #26
March 28, 2018, 07:00 AM #27
- Sep 2015
- 60
I do not think I have seen Harbeth on these before. It's Russ Andrews Torlyte generic speaker stands:-
Last edited by cyclopse; March 28, 2018 at 07:08 AM. Reason: Correcting image on its side
March 28, 2018, 09:59 AM #28
Ton Trager stands with slate under the stands is best I've tried.
March 29, 2018, 07:30 PM #29
Should someone that needs a bit of leveling on one side choose a different stand over the Ton Trager? They do not have spikes or a way to level, correct?
April 12, 2018, 10:51 PM #30
30.1s on Sound AnchorsClearaudio Ovation turntable/Clearaudio Universal tonearm/Ortofon Cadenza Bronze/Esoteric E-03; Apple Air/Ayre QB-9 DSD; McIntosh MCD500; Pioneer RT-909 reel to reel; PrimaLuna DiaLogue Premium HP Integrated Amplifier; Harbeth 30.1 Monitors; REL S/5 SHO; Shunyata Venom PS8 Power Distributor, Venom Defender, Venom HC and Venom 3 PCs; Cardas Clear USB Cable; WireWorld Silver Eclipse 7 ICs and speaker cables; Steve Blinn Designs Rack; Mapleshade Platform; KLAUDiO RCM.
Clarisys Arrives at Puur...
