Results 51 to 73 of 73
Thread: Luxman incoming....
February 11, 2018, 03:44 PM #51
Re: Luxman incoming....
I think the 509x would be better....newer design, headroom, and much cooler temp wise and nicer looks......just a guess and an opinion though.
On the plus side the 590 is all class A although only 30 watts.Larry
Lumin U1
Chord Dave Dac
Vac Master Preamp
Vac 200IQ Amp
Magico S3 Mk2 in Mcast Pewter
Denali 6000S
Ansuz and MIT cabling
Timbernation walnut racks
February 11, 2018, 03:50 PM #52
February 11, 2018, 09:23 PM #53
Is Luxmans website wrong? The 509x is at 120watts at 8 ohms same as Diablo 120
The L-590AX MK II draws upon Luxman's decades of experience in amplifier design to deliver an exquisite combination of rich sonic expression, fine detail, wide bandwidth and dynamic gusto. Stereo output is rated at 30W per channel into 8Ω and 60W per channel into 4Ω.
Larry
Lumin U1
Chord Dave Dac
Vac Master Preamp
Vac 200IQ Amp
Denali 6000S
February 11, 2018, 09:31 PM #54
Omg! Did I just correct Mike!
i have graduated!Larry
Lumin U1
Chord Dave Dac
Vac Master Preamp
Vac 200IQ Amp
Denali 6000S
February 11, 2018, 09:44 PM #55
February 11, 2018, 10:16 PM #56
What! That was in Celsius watts? Hifi news is UK based....
Larry
Lumin U1
Chord Dave Dac
Vac Master Preamp
Vac 200IQ Amp
Denali 6000S
February 11, 2018, 11:48 PM #57
- Apr 2013
- 1,622
Quite a bit underrated! Who would expect this from a 30w Class A amp! http://www.luxman.com/files/HFN_Luxm...XII_lowres.pdf
"I got a real surprise when firing-up Luxman’s L-590AXII on the test bench because, unlike the on-line ‘reviews’ that proclaim this amplifier ‘outputs 30W/8ohm and 60W/4ohm’ (a fact dotingly reprinted from Luxman’s press release and user manual), HFN can reveal the figures are actually 2x95W and 2x165W into 8/4ohm. Quite a difference, as I’m sure you’ll agree! Perhaps Luxman means that the first 30W are delivered in Class A (power consumption at 2x30W/8ohm output is 265W)? Either way, the dynamic output of the balanced power amp section suggests very little additional headroom at 97W and 180W into 8/4ohm with electronic protection activating at 303W and 170W into 2/1ohm loads, respectively [see Graph 1, below]. Still, the maximum 13A current capability (at <1% THD) is muscular enough for a 30-watter."
February 14, 2018, 05:04 PM #58
- Apr 2013
- 1,622
Here is a quick video of the Luxman L-590AX Mark II 24hrs into the break in. Loving the faster Vu meters. https://youtu.be/uo6ODDP1fJk
February 14, 2018, 05:38 PM #59
Wow! Love it.
February 14, 2018, 06:22 PM #60
That sounds awesome!!
February 14, 2018, 06:49 PM #61
- Apr 2013
- 1,622
It's a work in progress obviously since the room has zero treatment and is 26x31 so the front wall needs to be tamed a bit.
February 15, 2018, 11:04 PM #62
- Apr 2013
- 1,622
Luxman L-590 with the new Chord Qutest DAC https://youtu.be/LBpPAd-graw
February 16, 2018, 03:00 AM #63
Serge....
Great project. The Luxman amp is a beauty.
BTW...my cats in Paris are Stereophiles ( they are 2 ) and they told me that they are waiting for you !
Envoyé de mon iPhone en utilisant TapatalkShindo, Nagra, Electrocompaniet, Harbeth, AMR, Mc Intosh, Auditorium 23, Rega, DeVore, JC Verdier, WireWorld, Kimber
February 16, 2018, 10:42 AM #64
- Apr 2013
- 1,622
February 16, 2018, 05:13 PM #65
February 23, 2018, 03:59 AM #66
How old are the power amps in the Luxman line-up? Are the integrates newer?
Triangle Magellan Concerto 2 < AQ Everest < Vitus Audio SS-010 Mk2 < AQ Dragon HC < AQ WEL Signature XLR < Chord Qutest w UpTone JS-2 & AQ Dragon Source < SOtM tX-USBultra w 75Ohm Master Clock Input, Paul Hynes SR5-12 Turbo XL & AQ Dragon Source < AQ Diamond USB < Aurender N-100H w AQ Dragon Source < Gryphon PowerZone w AQ NRG-Wild < Solid Tech Hybrid < Ansuz Darkz D-TC, Darkz D2, Stillpoints Ultra SS, Omicron Harmonic Stabilizer & Gold SE < Furutech FT-SWS < Synergistic Research Blue Quantum Fuse
April 4, 2018, 10:13 PM #67
Waiting for the 509X to come to my local Bangkok dealer; I really want this amp. Expecting price to come in around 250,000baht.
Sent from my SM-G950F using Tapatalk
September 2, 2018, 11:43 AM #68
October 16, 2019, 10:34 AM #69
- Feb 2019
- Southeast Iowa
- 992
Would really like to see a comparison between the Luxman 590axii and Pass int 60.
October 19, 2019, 08:58 AM #70
- Apr 2016
- 590
^ Then buy both and compare?
October 19, 2019, 09:17 AM #71Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
October 19, 2019, 06:42 PM #72
- Apr 2016
- 590
Its something Im always doing... theres no replacement for living with a new piece of gear in your home. A side by side comparison reveals all.
October 20, 2019, 02:22 PM #73
- Feb 2019
- Southeast Iowa
- 992
Smooth this morning, as well. Thanks Mike & Co.
Forum Software Update
