Results 1 to 12 of 12
  1. #1
    Senior Member
    Join Date
    Sep 2017
    Seattle
    Posts
    1,964
    Nordost - Q Kore
    QRT’s - QKore 6
    I am writing to bring awareness on how awesome an external ground helps a system and to hopefully draw attention to help others realize this.
    I know only the fundamentals about electrical grounding relative to safety and not sure how it relates to sound, other then external grounding components work to bring out a much richer and focused sound. Maybe someone on here can help enlighten the engineering behind this in layman terms, in any event, here we go...
    This past October I attended my first audio show, RMAF and like any convention there is lots to see and do, but to realize maximum value you have to engage to learn, and that’s what I hoped to do but could not fully get into the technical side of things as the sounds and the audio eye candy distracted my focus.
    Prior to RMAF and being on these forums, I have already started my Nordost cable journey but was not familiar with what the QRT products offered as I embodied skepticism, and wanted to use the RMAF platform to learn more about these various tweaks to decide how much further I would venture into nirvana in terms of time and expense.
    Quickly, I found my way to the Nordost room directed by their conveniently placed kiosk in the lobby. Smartly, Nordost took you through the different series of cables, and the improvements that offers something for everyone, and they were able to prove this with no gimmicks, tricks and related. Each testing used the same settings, gear and tracks played. As the demonstration evolved, one of the focal points was within the QRT product line; the QKore external grounding system.
    There are 3 models of the Q-Kore, each at different price points; the 1, 3 and 6. The base level, QKore 1 addresses grounding in the power distribution and also serves as a great starting point in price and quality. However, be warned that you will quickly want the second or third models in the series offered by Nordost where it allows you to address either 2 or 5 components, aside from the power distribution. Either of these choices and your still ahead, both sides gives you a sense of completeness of QKores ability. Also, Nordost recommends begin with power distribution as a starting point even before grounding and offers their QB8 and QB4 distribution outlets addressed my this, but using their distribution is not a requirement.
    I operate a PS Audio P10 and QKore6 for my own reasons. PS Audio said they do not address the grounding aspect like offered by Nordost. QKore did it’s job realizing very noticeable ground gains using the optional RJ45 jack from the P10 into the power side of QKore. So this makes QKore universal from grounding the power side between QRT devices and the P10, then with the QKore6 I get to ground 5 components as well adding layers of improvement.
    Back to where it started, so upon the presenters demonstration, the overall dimension and clarity in sound hit me between the ears and played out like the original Batman TV series using the Bam’s, POW’s and Smack’s in animated fashion…I was beyond impressed and all from a component requiring no power cable. The QKore grounding systems magical ability borders as mesmerizing, no different then when one undergoes cable, isolation and treatment upgrades aside from components and speakers.
    I instantly contacted my Nordost dealer from the show ordering the QKore 6, plus 4 grounding cables for various components.
    * Note: The Nordost Q Kore 6 has a total of 6 terminals, with 1 dedicated to ground the distribution power and the others for audio components or mono block amps (each additional cable is around $350, a fraction of the price compared to power cables and come in RCA, BNC, XLR, RJ45 and Banana)
    * Hookup was simple, the results spectacular. Upon turning on the system, the music was now more revealing in every way, much like at the show, no matter the track played. Sounds appeared clearer through their dynamic broadcast revealing music as it was intended and with an increased level in volume showing what an ungrounded system was hiding. Yes the level of volume increased, but not by adjusting the volume control, the sound became louder as the ground in QKore was removing unwanted electrical noise and interference providing clearer dynamics on a darkened detailed soundstage.
    One of the hardest parts of this hobby was getting past the notion of choosing complimenting items that greatly benefits a system. Visually it’s hard for me to spend money unless immediate visual gratification can be had with knobs, dials, lights and all the fancy billeted aluminum, but somehow I mostly restrained myself.
    I am a believer to maximize performance on many pieces of gear by various brands the foundation of the system addressing power along with controlling the sound emitted by room treatments and isolation devices are of great importance and the difference between good sound and great sound.
    While my writing tilts towards Nordost, there are other companies that include similar offerings creating options for you. I have no vested interest in Nordost whatsoever, and don’t believe there is one solution for all other then the principles of ensuring room treatment, isolation and power play a factor in reproducing the best sound possible.
    Hear where you can, read and study when you can, but overall enjoy your system! After all, who wants to spend a bunch of time and money to never fully be happy.
    I hope this helps the prospective, current and future enthusiasts in their listening journey.
    In closing, I respectfully request the forum moderators to add Nordost into the manufacturers forum.
    Speakers: Wilson Alexias
  2. #2
    Senior Member
    Join Date
    Aug 2016
    Denmark
    Posts
    639
    Re: Nordost - Q Kore
    Thank you for that very interesting story
  3. #3
    Senior Member
    Join Date
    Aug 2013
    Chicago suburbs
    Posts
    1,583
    Thanks for sharing your honest impressions of the relatively new Nordost QKORE grounding system.
  4. #4
    Senior Member
    Join Date
    Aug 2013
    Singapore
    Posts
    1,021
    I attended a dealer organised presentation of the Nordost QKore range in Singapore in October. Nordost’s product specialist Bjorn Bengtsson demonstrated all three products. Effectively a grounding unit the QKore – most notably the QKore 1 really improved the resolution [fine detail retrieval] and the bass definition and timing coming from the demo system. For me and for the system used the biggest sonic gains were achieved from the QKore 1.
  5. #5
    Senior Member
    Join Date
    May 2017
    Cleveland, Ohio, USA
    Posts
    530
    The basic definition for 'ground' is common reference point.
    So if the QKORE6 has continuity between the 6 terminals, the it fulfills this function.
    And the QKORE3 for small tree component systems. But the QKORE1 not at all.
    Remember that 'ground' is a reference point and not a destination.
  6. #6
    Senior Member
    Join Date
    Aug 2013
    Singapore
    Posts
    1,021
    Quote Originally Posted by Speedskater View Post
    I'm not sure I understand your comment, perhaps you could clarify / expand?
    The Qkore 1 addresses the primary or AC side of the power system, connecting directly, and exclusively, to an audio system’s power distributor, ideally the Nordost QBase or similar distributor which has an external grounding socket. If the three pin power cord of each of audio component is connected to the distributor they all "see" the same artificial “clean” earth.
  7. #7
    Senior Member
    Join Date
    May 2017
    Posts
    530
    Quote Originally Posted by kiwi_1282001 View Post
    ..........If the three pin power cord of each of audio component is connected to the distributor they all "see" the same artificial “clean” earth.
    Rather they "see" the same "common reference point", which is a good thing. Because it will reduce Common Impedance Coupling noise.
    I hope that the most important Safety Ground path back to the Neutral in the main breaker box remains intact.
  8. #8
    Senior Member
    Join Date
    Aug 2013
    Chicago suburbs
    Posts
    1,583
    Thought this review of the QKore Grounding System from TAS would be of interest here.
  9. #9
    Senior Member
    Join Date
    May 2017
    Posts
    530
    It's too bad that TAS reviews contain no technical information.
  10. #10
    Senior Member
    Join Date
    Aug 2016
    Denmark
    Posts
    639
    Why not simply contact Nordost for the information you want ?
    Flemming
    Lumin X1
    Rotel Michi S5
    Focus Audio FS788
    LS cable : Yter
    Nordost QB8
    Rack : Finite Elemente Pagode
  11. #11
    Senior Member
    Join Date
    May 2017
    Posts
    530
    Quote Originally Posted by FDPDK View Post
    What's wrong with independent measurements?
  12. #12
    Senior Member
    Join Date
    Aug 2016
    Denmark
    Posts
    639
    Nothing of course
    Flemming
    Lumin X1
    Rotel Michi S5
    Focus Audio FS788
    LS cable : Yter
    Nordost QB8
Nordost - Q Kore
Posting Permissions
  • You may not post replies
  • You may not edit your posts
