Results 101 to 127 of 127
Thread: Lumin D2
September 30, 2019, 12:37 PM #101
Re: Lumin D2
Welcome to the forum.
September 30, 2019, 01:06 PM #102
Re: Lumin D2
Lumin app does not have EQ, but it has a plethora of upsampling options and with a Lumin, you can also use Roon which does have EQ options. Lumin has QoBuz and Tidal.
September 30, 2019, 01:16 PM #103
October 2, 2019, 07:45 PM #104
Re: Lumin D2
Hi Peter
Few days ago I saw a notice for new firmware (vers. 11.6) for my D2. After the update my Lumin always stops playing music after several songs then continues the song again after few minutes. This has never happened before with the older firmware. Could you see the possibility if the new firmware somehow create this issue. Btw, there is no change to the network where Lumin is connected to. Appreciate your suggestion.
thanks
Harry
October 3, 2019, 12:39 PM #105
- Sep 2019
- U.S.
- 42
Re: Lumin D2
In a pretty high end system what sound quality difference would I hear going from a Bluesound Node2 to the Lumin D2?
October 3, 2019, 12:42 PM #106
Re: Lumin D2
Please power cycle the D2. Save your current playlist, clear the current playlist, then add a few albums from MinimServer and try playing them again.
I'll also test it in my setup at work. However, it's been almost 2 weeks since the release of the firmware, and we have not received any other firmware 11.6 issue report.Peter Lie
LUMIN Firmware Lead
October 3, 2019, 12:53 PM #107
Re: Lumin D2
Hello Audio4me, I heard the Blusound 2i (from my son-in-law) and I had the Lumin D2, for my ears there is a lot of difference between these 2 streamers. Lumin D2 is a wonderful team, it has a very natural and great sound, the musicality of Lumin D2 is exceptional. If you can give yourself the pleasure to buy the D2 do not hesitate. Regards.
October 3, 2019, 08:57 PM #108
October 3, 2019, 09:32 PM #109
- May 2013
- 3,242
Re: Lumin D2
Peter
I had it happen also multiple times using the NT-505 with the Lumin app. Switched to the HR Streamer app and the problem went away. Seems to have started after the IOS 13.1.1 bug fix earlier in the week. Just noticed there is now another bug fix 13.1.2 so no telling what it will do.Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
October 3, 2019, 09:42 PM #110
Re: Lumin D2
When it "stops playing", is the track completely played or is it in the middle?
When it "continues playing again", does it repeat the last played track, from the point where it stopped (if wasn't completely played), or does it play from the next track in the playlist?
From the Lumin to your network switch/router, is it all wired without going through any WiFi conversion?
Is your iOS device running iOS 13.x?
Due to what Jack said, could you try: start playback in repeat mode, then power down your iOS device. See if the Lumin still stops playback unexpectedly.Peter Lie
LUMIN Firmware Lead
October 3, 2019, 09:44 PM #111
Re: Lumin D2
Both Lumin and NT-505 (current firmware: Dec 2018), because of OpenHome standard, are supposed to keep playing the playlist even if the iPad is powered down. While we are taking care of cosmetic issues in Lumin app bring by iOS 13, music playback problem is currently unexpected at this point.
Peter Lie
LUMIN Firmware Lead
October 3, 2019, 09:53 PM #112
- May 2013
- 3,242
Re: Lumin D2
Peter
When the music stops the timer and the circle keep moving. Sometimes it will come back in the same song and sometimes at the start of the next one.Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
October 4, 2019, 06:07 AM #113
Re: Lumin D2
Peter
My Lumin stops playing in the middle of the song (incomplete) then after a while it continues playing from where it stops. Exactly the same effect if you would press pause button.
There is no wifi conversion between my Lumin to router and NAS. And I use android device not iOS.
Harry
October 4, 2019, 06:23 AM #114
Re: Lumin D2
I tested Firmware 11.6 with iOS 13.1.2 and did not experience this issue.
Harry,
Please power down the Lumin, Android device and NAS. Power cycle the wifi router and all network switches. Wait for 5 minutes then power them up.
Then use Lumin app to factory reset the D2, in settings, options under D2, About.
If it still has problem please try playing an album from usb drive plugged into D2 instead of NAS, and use a different network cable connected to a different network port.Peter Lie
LUMIN Firmware Lead
October 4, 2019, 05:51 PM #115
Re: Lumin D2
Peter
Ok, I will cycle power etc, once i get a chance, but I wonder why. It has been fine for a year until the last update. And I use wireworld cat8 cable between my Lumin and router. Is there any possibility for you to test with Android device instead of iOS?
Thanks again
Harry
October 5, 2019, 12:10 AM #116
Re: Lumin D2
Yes, I can test that next week after our holiday. By design the control point cannot cause the player to stop playback though. You can shutdown your Android device and the Lumin D2 will still play.
Peter Lie
LUMIN Firmware Lead
October 5, 2019, 08:14 AM #117
October 6, 2019, 06:57 PM #118
- Sep 2019
- U.S.
- 42
Re: Lumin D2
Peter, what do you think sounds better, the T1 or the D2? Primarily for streaming Tidal and Qubuz.
October 6, 2019, 09:13 PM #119
- Sep 2019
- U.S.
- 42
Re: Lumin D2
Does D2 streaming of Tidal and Quobuz sound better than a cd?
October 6, 2019, 09:32 PM #120My Systems: http://www.audioshark.org/showthread...481#post158481
October 8, 2019, 02:42 AM #121
October 8, 2019, 06:06 AM #122
October 8, 2019, 09:18 AM #123
- Sep 2019
- U.S.
- 42
Re: Lumin D2
Can anybody comment on the sound quality of the D2 compared to the Bluesound Node2?
October 8, 2019, 09:38 AM #124
September 30, 2021, 03:55 AM #125
- May 2019
- TX
- 7
Re: Lumin D2
Hello, I’ve currently been using the D2 the past couple years plugged into my mc5200 integrated amps balanced xlr inputs with great results.
I’m curious if I can have the D2 xlr balanced outs plugged into the McIntosh, and also use the unbalanced rca outputs on the Lumin to a separate headphone amp?
Not playing at the same time, but plugged in at the same time so I can switch back and forth between my Regular McIntosh living room set up, or when I want to listen to headphones through a separate amp without having to unplug cables every time?
September 30, 2021, 06:55 AM #126
Re: Lumin D2
Yes, as long as it does not cause a ground loop.
Peter Lie
LUMIN Firmware Lead
September 30, 2021, 02:33 PM #127
- May 2019
- TX
- 7
Re: Lumin D2
Excellent! Thank you.
Upgrade on the way...
