Results 1 to 12 of 12
Thread: HRS Damping Plates
October 13, 2017, 10:05 PM #1
HRS Damping Plates
Has anyone had experience with these? I was told they make an improvement with Esoteric spinners. I don’t get why putting a chunk of metal on the single heaviest CD player I’ve ever seen would make a difference.
Thoughts?
Sent from my iPad using TapatalkPreamp/Digital: Meitner MA3
HT Processor: Bryston SP3
Amps: Bryston 14b3, Bryston 4b3
Speakers: Kef Reference 5, Kef Reference 4c
Sub: REL Carbon Special
Power: Shunyata Denali, Bryston BIT15
Wires: Wireworld Silver Eclipse XLR & SC, Ethernet - WW Platinum USB
Other: Stillpoint Ultra SS, ISO-Acoustics ISO Pucks
-Kyle
October 22, 2017, 09:17 AM #2
- Jun 2014
- 24
Re: HRS Damping Plates
Way back in 2009 I think I bought an ex dem Accuphase E450, and was persuaded by the eulogies of the dealer to add a couple of these....the amp remains wonderful & the damping plates remain at the back of some cupboard, so useless I haven't got the heart to sell them to someone else. There may have been subsequent versions, but to my ears they did absolutely nothing!
NA Spacedeck - Jelco 750D & Ortofon SPU #1E or At33Sa / Jelco SA250 & Zu Denon 103
Technics SL1210 & 2M Mono SE
Weiss DAC202 , Mac Mini
Accuphase E450
Allnic H-1201 & Parks Audio Budgie + Albarry Head amp
Martin Logan Electromotion ESL's
October 22, 2017, 09:53 AM #3
I would suggest some form of proper energy dissipation under the Esoteric. The ones that make the most sense to me, from an engineering standpoint, are the Magico Q-POD’s. It is my opinion, that with a device creating energy at 60 cycles per second, dissipation is what we want, rather than isolation. With isolation, the energy returns to the device and over time, results in a “dead” sound. With dissipation, the energy is allowed to escape. In the case of the Magico Q Pod’s for example, the energy is turned into heat and escapes through the solid copper ring. In addition, I have found proper dissipation to be most effective under digital devices. YMMV.
I will be getting some of the Artesania damping plate gizmos to try in a month or so.My Systems: http://www.audioshark.org/showthread...481#post158481
October 22, 2017, 10:05 AM #4
I use a Symposium Svelte shelf on top of my Esoteric K-01x. I think it is similar principle to the damping plates. I hear an improvement in sound quality. It is very easy to A & B the difference. I also use Stillpoints and a svelte shelf under the K-01x. Every little bit helps for me.
Paul
Main Stereo System:
Harbeth 40.3 HD, Jay's CDT3 MK3, Mola Mola Tambaqui DAC, Aurender N20, Luxman M900 & C900 , (2) JL f113, Shunyata Denali 6000v2 Power Conditioner, Altaira, AZ Cables, Stillpoints & Symposium shelves under everything.
Theater System:
JVC RS400 projector, 130" Stewart screen, Oppo 105D, Audio Physic Classic speakers, REL 3D subs, MC8207 MX136, Synergistic Research Powercell, AZ interconnects, speaker cables and PC's.
October 22, 2017, 01:16 PM #5
- Sep 2014
- 766
Try Artesania dampers above and Shun Mook diamond resonators below.
October 22, 2017, 05:16 PM #6
- Oct 2015
- New York City Metro Area
- 443
I have both the HRS and the Artesania damping plates. While difficult to say to what degree they “work” I can say I use them and do not find them to adversely impact the performance of my system. For what it is worth, the Artesania dampers aesthetically appeal to me more. Hope this helps...
October 22, 2017, 05:56 PM #7
- Jun 2014
- 24
Accuphase E450
October 23, 2017, 04:06 PM #8
I Placed an HRS plate on my K-03X to quench a vibration of the top cover I could easily feel when Music was playing. Seemed a simple enough and good looking fix. I also put Stillpoint Minis under it but the vibration is still there without the HRS plate.
Of the two, the HRS plate seems more important to my ears.Main Equipment: Kharma Elegance dB11-S, JL Audio F113v2, Block Audio Line & Mono SE Amplification, Bricasti M21 DAC, Antipodes Kala K-50 Server, ClearAudio Performance SE, Satisfy Arm & Maestro Wood MM Cartridge
Power: 3 x 20 Amp Lines, Shunyata Everest 8000, Sigma XC v2, Shunyata Sigma v2 NR, Block Audio Power Cords, Defender, ADDPowr Wizard
Grounding: Shunyata Altaira CGS - Alpha CGS cables
Network : Supra Cat 8+, Twin (Nenon Modified) Buffalo GS2016 Switches powered with Keces P3 LPSU,
Cables: Wireworld Platinum Starlight 8 USB, Wireworld Platinum Eclipse 8 SCs, 1M & 6M Tubulus Concentus ICs,
Other: Isoacoustics GAIA I footers on the Kharmas, GIK/Vicoustics/Stillpoint Apertures, Stillpoint Ultra SS, Furutech GTX - Gold outlets, Adona Rack
October 25, 2017, 08:48 AM #9
- Oct 2015
- 443
LOL!!! Well, perhaps it’s a low bar but I’m sure I am not the only one here who in the past has spent some good coin for a product anticipating results/improvement that did not come. I am happy with my dampers. Surely they help I’m just not always able to measure the degree of improvement especially when considering other variables as well.
October 27, 2017, 04:02 PM #10
- Jun 2014
- 24
Over the years I have most definitely been guilty as charged, back in the late nineties the UK HiFi press wash awash with glowing reviews of Nordost, and when a Thor came up ex dem I grabbed it, and to be honest at the time really thought it had improved the sound. As the years passed & I swapped out my expensive but utterly unbendable power cords for the flexible things that came in the box without my system "collapsing" into awfulness, when I finally needed 7 inpus rather than the 6 the Thor offers, I went to Maplins & bought a 20 quid 8 way gang....and remarkably (and tbh annoyingly!!), nothing changed in the sound, or at least to my 48 yr old ears that heard Motorhead at the Hammersmith Apollo! In the end, I have come to think that while things certainly make a difference, (copper & silver I swear differ for eg in cables), we adjust to the new sound within about a week, and stop hearing the difference, we go back to hearing music, in which case why worry. That's what we were doing before.
I dug out the HRS plates thou, and nope, still doing nada in my set up, which is in my sig & does reveal pretty decently imhoNA Spacedeck - Jelco 750D & Ortofon SPU #1E or At33Sa / Jelco SA250 & Zu Denon 103
Accuphase E450
November 1, 2017, 08:54 PM #11
- Jan 2016
- Australia
- 24
Re HRS dampling plates - I could not hear any difference in my system.
November 3, 2017, 04:49 PM #12
- Sep 2015
- 60
Put some of the HRS Nimbus footers under a component and you will soon hear a difference. I find they drain treble from the system and introduce a muddy bass. I find Wave Kinetics a much better solution underneath and have left the dating plates in place on top.
