Results 1 to 16 of 16
  1. #1
    Senior Member
    Join Date
    Apr 2013
    Valrico, FL
    Posts
    408
    MIT at my house!
    Earlier this month Mike came by the house with a *big* box of goodies for me to try out in the system - his own set of MIT cables, or more properly interfaces. This included the MI-2C3D Level 1 Speaker interfaces, MI-2C3D Level 1 XLR Interconnects, SL Matrix USB, and Oracle MA-X Digital Balanced Interconnect (AES/EBU). This replaced my Acoustic Zen Hologram 2 speaker cables, Matrix Reference II Interconnects, and WireWorld Platinum AES/EBU and Starlight USB cables.
    At first listen, it was clear that there was a big difference with the MIT loom. We listened for a couple of hours and Mike was uncharacteristically quiet, not talking at all during any of the songs we played and hardly saying a word between tracks. As is often the case with major system changes, first impressions are hard to describe - you get a sense of what you hear but you haven't processed it yet.
    Fast forward a couple of days - the sound continued to improve as the cables settled in but there was a very slight edge in the highs. I told Mike about it, we did some investigating and found that the interconnects running to the amps were set to medium impedance but the XS 300 amps have high impedance. I made the switch on both interfaces.
    Bam! The slight edge was gone. Once settled in at the proper settings the sound was perfect!
    So how do they sound?
    First, there's a ton more detail - it's been a while since I've noticed "something I never heard before" on my system but now I get it all the time. And everyone who's heard them says the same thing. Breathing, tapping, fingering, audience noise - much more highly resolved.
    Second, the background is quieter - but not in the sense that you see it as "blacker" - blacker would call attention to itself. It's more like there just isn't any background noise anymore, which makes quiet passages stand out more and sudden notes all the more striking.
    Finally, it's like the pre-amp suddenly has several new control knobs on it: Texture, Tonal Richness, and Holography... and they're all dialed up to 8 or 9. Those knobs weren't there before, but if they were they would have only been set to 1 or 2 in comparison).
    Texture and richness speak for the themselves - they're not squishy terms like "organic" or "musical". Holography... well, if my system was like a High Definition OLED TV before now it's like the Holodeck on the Enterprise (Next Generation). It seems almost that real. And everything is affected equally - male and female vocals, percussion, strings, horns, guitars, and OMG piano!
    It's startling at times - the sounds are so real and they come out of nowhere in a sound field that fills the whole space in front of you and doesn't seem to have any relationship with the speakers or equipment in the room. Decay goes on forever. It doesn't sound like reproduced music - just music. And opening your eyes doesn't break the illusion at all.
    I could go on but I think you get the idea - these MIT interfaces are not leaving my system (sorry Mike).
    Howard
    Pass Labs XS 300's, XS Pre | Berkeley Audio Design Alpha DAC Reference Series 3, Alpha USB Series 2 | Aurender W20SE, ACS10 | Magico S7's with MPOD's, QSub 15 x 2 | Shunyata Denali 2000T x 2 with Sigma HC | Shunyata Everest 8000 w/ Omega XC | MIT Heritage and Oracle Interconnects and speaker cables | Critical Mass Maxxum rack
  2. #2
    Senior Member
    Join Date
    Feb 2014
    Austin, TX & Suburban Chicago
    Posts
    687
    Re: MIT at my house!
    Howard, I am having the same experience with another brand of cable. It is hard to believe that cables that are purported to be responsible for maybe 3-5% of the sound (if that) can make such a dramatic difference.
    Cables from my understanding don't really add anything but "do no harm to the signal". When you get ahold of a brand such as yours it can be bliss. Congratulations.
    Le Roy
    Foundation:
  3. #3
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    What you are both describing is the difference between audio cables and an audio interface. This is what you get with MIT, Ansuz DTC and Transparent. And yes, the interface makes a major difference in sound quality IMHO. These brands have come a long way since they were first introduced. Definitely not your father's MIT!
    Ken
  4. #4
    Thanks for sharing, Sandman. I'm awaiting EVO level 1 speaker cables. Already thinking EVO level 1 XLR.
  5. #5
    Quote Originally Posted by Alpinist View Post
    Ken
    Ken, may I ask which cables you are using?
  6. #6
    MIT at my house!
    Quote Originally Posted by kzhtoo View Post
    Also thinking about the EVOs, heard Magicos with MIT cables in Munich and my thoughts keep coming back to that presentation.
  7. #7
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    Quote Originally Posted by Kuoppis View Post
    My Vandersteen M7-HPA mono amps came with proprietary single-ended fixed length speaker cables produced for Vandersteen by AudioQuest. They use solid 100% perfect surface silver (PSS) conductors and AQ's dielectric bias system (DBS), which was designed by Richard Vandersteen. My interconnects are AQ Wild Blue Yonder, which are also 100% PSS and DBS. Richard uses AQ cable in all his speakers.
    Best,
    Ken
  8. #8
    MIT at my house!
    My Vandersteen M7-HPA mono amps came with proprietary single-ended fixed length speaker cables produced for Vandersteen by AudioQuest. They use solid 100% perfect surface silver conductors and AQ's dielectric bias system (which was designed by Richard Vandersteen). My interconnects are AQ Wild Blue Yonder. Richard uses AQ in his speakers.
    Best,
    Ken
    Appreciate the details. AC must be good if Richard has chosen them for his speakers. Mike also keeps talking about AC quality
  9. #9
    So, what you hear at Munich with MIT different than what S3 mk2 is doing at your home in terms of presentation? Care to elaborate? You are using Cardas at home, right (sorry if I'm wrong)?
  10. #10
    I think what I am hearing at home right now is very good - I am using WyWires Platinum full loom, which I quite like.
    If anything, I guess the MIT setup might have been more open, but it is very hard to say whether that was due to the mk2 version of speakers or because of the cables.
    But I will be very interested to hear about your experiences, as you have only one factor changing in the setup.
  11. #11
    Will report back after I have it in the system for enough hours.
  12. #12
    How are you liking your EVO Ones?
  13. #13
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Quote Originally Posted by mdp632 View Post
    I put them on the S5 mk2 system yesterday and sat back and enjoyed a couple of hours of listening. A good dose of the qualities I heard immediately with the 2C3D's on the M3's was present. I'm sold. Amazing.
  14. #14
    I'm only at about 120 hours with EVO One SC. So far like it enough to order EVO One XLR and Three XLR. MIT at my house!
  15. #15
    Which LS cables were you using before? Can you describe the difference?
  16. #16
    PM sent
MIT at my house!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
