Results 101 to 106 of 106
Thread: what Phono stage do you using?
November 16, 2020, 11:44 AM #101
Re: what Phono stage do you using?
I ended up buying a Zesto Andros. I haven’t had a chance to spend serious time with it, but I’m pretty sure I’ll be happy with it.
Focal Sopra 2, MC452, C2300, MCD1100, MT2 w/Hana SL, HRS, Bel Canto Stream, Schiit Yggy, AQ Niagara 5000 w/Hurricanes, WW Silver 7’s.
November 17, 2020, 06:17 PM #102
- Feb 2014
- SF Bay Area
- 73
Luxman EQ 500 and loving it! This will be my end game phono stage, since I am tired of the component upgrade game!
January 10, 2021, 01:09 PM #103
- Aug 2014
- Fleming Island, FL
- 77
DSA Phono II (Dynamic Sounds Associates). Three inputs, four levels of amplification, and any loading you can imagine from 25 to 1575 in 25 ohm steps.
Gryphon Diablo 300 w/DAC, Rockport Mira II, Wolf Audio Alpha 3SX, DSA Phono 2, Origin Live Sovereign MK3, Enterprise MK4, Conqueror MK4, SoundSmith Hyperion, Miyajima Zero
January 10, 2021, 07:00 PM #104
- Sep 2016
- Singapore
- 109
July 11, 2021, 11:26 PM #105
- Apr 2021
- Los Angeles
- 9
I had a Sonneteer Sedley for a really long time. It was an excellent solid state phono pre. Large power supply, simple design, premium components and a lot of loading options. I then tried a 12 tube Balanced Audio Technology VK-P6 with Super Pak and was smitten. I then moved to an Allnic H-1201 and later settled on the H-1202. Both have tube gain stages plus iron nickel step up transformers for the MC section. Between the ver. 1 and the 2, the latter is slightly improved with a tube regulated power supply. Its slightly warmer than solid state, weighty sound and delicate highs. I really like it. My only gripe is that the supernatural imaging described in a few reviews seem hyped. I like it.
July 12, 2021, 11:00 AM #106
So I updated my phono stage to a McIntosh MP100 because I wanted a single phono stage for both turntables. I also like that it has an AKM ADC so that I can record my albums to digital if I want to. It sounds very good to my ears in my system!
― Neil deGrasse Tyson
Upgrade on the way...
