Results 1 to 26 of 26
August 4, 2017, 07:45 AM #1
- Apr 2013
- 1,874
Bryston Launches BP-17³ Cubed Preamplifier
FOR IMMEDIATE RELEASE
New preamp is the first to employ patented Salomie input circuit and new feature set with highly flexible input/output array
Peterborough, Ontario August, 2017
Bryston has announced the introduction of the new BP-17³ (Cubed Series) preamplifier, utilizing patented technology that debuted on the much heralded Cubed Series amplifiers. The BP-17³ also features a new expanded input/output configuration for enhanced system flexibility. Like all analog components from Bryston, the BP-17³ is covered by an industry best 20 year warranty.
Bryston’s patented super-linear, low noise input buffer jointly developed by Bryston and the late Ph.D. engineer Dr. Ioan Alexandru Salomie significantly reduces noise and distortion. The BP-17³ also has improved RF and audio frequency noise filtering to prevent unwanted anomalies on the power line from interfering even minutely with the audio signal.
The BP-17³ offers expanded input/output options, including two pairs of XLR outputs and two pairs of RCA outputs, making it possible to connect a wide variety of equipment and accommodate numerous system configurations. An RCA tape loop lets users connect a line-level processor or recording device and one of the XLR output pairs can be internally selected to have either variable (default) or fixed output enabling users to easily connect a Bryston BHA-1 or other balanced input headphone amplifier.
The BP-17³ also includes two pairs of balanced inputs and five pair RCA inputs, and can be ordered with a high-resolution internal DAC, a premium moving magnet phono stage, both DAC and phono modules or without either module installed. Users can select sources, adjust volume and more all from the optional BR-2 remote control or via RS232 connection to virtually any control ecosystem. The BP-173 is available in either black or silver, 17-inch or 19-inch (wide) faceplates.
The BP-17³ will begin shipping to authorized dealers in September, 2017 with a US MSRP of $3995.
IMAGES:
https://www.dropbox.com/sh/xcmwzp8fu...YBUtTCAsa?dl=0
August 4, 2017, 11:16 AM #2
Re: Bryston Launches BP-17³ Cubed Preamplifier
Good looking product!
August 4, 2017, 12:09 PM #3
James.......The new Bryston BP-17³ looks to be an excellent preamplifier with a lot of user versatility. Good to see this fresh preamp offering.
Dan
August 10, 2017, 04:18 PM #4
- Jun 2017
- Maryland
- 13
James,
Any chance of a future module for driving active Model T/Middle T speakers?
Steve
August 11, 2017, 09:08 AM #5
- Apr 2013
- 1,874
Hi
Yes we are working on a preamp which will be a combination of a BP-17 and a BDA-3 DAC which will be able to have a crossover card installed to use with the Model T, Middle T and Mini T active speakers.
It is many months away and will be expensive.
james
August 13, 2017, 07:32 PM #6
- Jun 2017
- Maryland
- 13
August 14, 2017, 06:38 AM #7
- Apr 2013
- 1,874
HI
The BAX uses different software based on the speaker it is used with.
Most generic active crossovers will have settings for crossover slope and frequency but we go one step further and measure the speaker in the anechoic chamber (over 600 measurements both horizontally and vertically) to ensure that the 'Sound Power' is optimized for the Middle, Mini and Model T speakers. The software is then written and installed in the BAX.
james
October 26, 2017, 02:30 PM #8
- Apr 2013
- 1,874
Hi Folks,
Lots of demand for the new BP-17 Cubed Preamplifier
November 3, 2017, 10:14 AM #9
- Apr 2013
- 1,874
HI James,
Our 17B3 is now well run in. I even took it home to play with. It is superb!
I can now hear that the BP26 has some colourations in the upper mids and high frequencies compared to the BP173. I can now use high efficiency speakers with our Bryston setup and there no longer the sense of a rising frequency response that speakers like this normally exhibit. I tried a horn loaded tweeter from Triangle and is was beautifully smooth! I have some Opera Loudspeakers with a SEAS soft dome and they too are smoothed out and better balanced than I've ever heard them. And I use Nordost speaker cables! So much for the notion that they are bright cables! They only reveal the quality of the equipment.
Next will be an 8 ohm, 94dB, horn loaded compression driver mated to a cellulose bass driver! This could rip your face off if improperly set up
Thank,
Davies
November 9, 2017, 06:39 AM #10
- Apr 2013
- 1,874
Hi James,
I've tested the 17cubed with a variety of amps from high gain to low gain, balanced and single ended. The result is always the same: composure.
I used it with a single ended, point to point solid state amp which has 30dB of gain. Not only was the system silent (used with very efficient speakers) but the 17cubed's volume control offered a great deal of usable range and dynamics.
I usually only give you incessant feedback when I like something
Cheers,
James
February 2, 2018, 11:56 AM #11
- Apr 2013
- 1,874
Hi Folks,
French review on the BP17 preamp and 4B Cubed combo.
http://www.bryston.com/PDF/reviews/2...ch_Bryston.pdf
March 21, 2018, 04:46 AM #12
- Apr 2013
- 1,874
Hi Folks,
Just got the copy of the review on the Bryston BP-17 Cubed preamplifier coming in June 2018 issue.
As the Brits would say "Its a corker"
james
May 1, 2018, 06:42 AM #13
- Apr 2013
- 1,874
Hi Folks,
Got this today from our South Africa Distributor.
james
Hi James
Please find the link to local review of the Bryston BP 17 Cuber preamplifier - http://www.avsa.co.za/bryston-b17b3-...-sonic-policy/
May 5, 2018, 02:03 PM #14
- Apr 2013
- 1,874
Hi Folks,
The June Issue of Stereophile has a review of the Bryston BP-17 Cubed.
May 15, 2018, 06:54 AM #15
- Apr 2013
- 1,874
May 22, 2018, 03:49 PM #16
- Apr 2013
- 1,874
Hi Folks,
I have the PDF of the full review - email me if you want a copy.
jamestanner@bryston.com
james
May 22, 2018, 03:51 PM #17
- Apr 2013
- 1,874
James,
Excellent review. This product should win product of the year. The price performance ratio is outstanding.
Congratulations to your team this is product competes with the finest and most expensive pre Amos in the world at a fraction of the price.
Outstanding!!!
Best regards,
Steohen
May 24, 2018, 12:08 PM #18
- Apr 2013
- 1,874
Hi James,
NEW REVIEW on BP-17 and 4B Cubed !
“One of the actually best amplifiers on the market”
On German Online Magazine Fairaufio.de:
https://www.fairaudio.de/test/brysto...r-kombination/
Best regards
Edvard Potisk
AViTech, Dkfm.
Email: edvard.potisk@avitech.at
Web: www.avitech.at
May 24, 2018, 05:32 PM #19
- Apr 2013
- 1,874
Full Stereophile review:
http://bryston.com/PDF/reviews/2018_...hile_BP_17.pdf
May 25, 2018, 07:34 AM #20
- Apr 2013
- 1,874
Hi James
I read the German review and gotta tell you , it’s really great for both components.
Ernie
May 31, 2018, 05:58 PM #21
- Apr 2013
- 1,874
June 4, 2018, 03:52 PM #22
- Apr 2013
- 1,874
Hi Folks,
I have a PDF of a very, very, very in depth review of the Bryston BP17 Cubed Preamplifier and 4B Cubed Power Amplifier combo from FAIRAUDIO Magazine in Germany. Some great pics as well!
My sincere thanks to Peter Ullman a dedicated audiophile and true gentleman for his translation of the German to English.
Please email me if you want a copy - it's 11 pages and 1M - jamestanner@bryston.com
james
July 15, 2018, 03:20 PM #23
- Apr 2013
- 1,874
SUBJECT: Bryston BP17 Cubed and 4B Cubed Combo – Customer Feedback
July 2018
Wow!
Now that they are in working order, and any kinks (traced to other components) have been troubleshot, my system is transformed.
Bryston is spoiling me as we speak. Hard to tell if it is the 4B Cubed stereo amplifier or the BP17 Cubed pre-amplifier, which I added at the same time.
Such a fantastic pair!
The sound is much more full and detailed. Soundstage is markedly improved, so much that I must say it’s almost like I never heard soundstage in my system before. Bass is extended and midrange is particularly improved. I can now ‘feel’ the music, unlike before.
Vocals are more in the room. Whatever you have done with this pair, you have done right. The wife, who could almost care less about music, commented right away “It sounds amazing”. I can only concur. Looking forward to years of enjoyment....
My thanks to the entire Bryston team!
Shrinky
August 16, 2018, 10:08 AM #24
- Apr 2013
- 1,874
SUBJECT: Bryston BP-17 Cubed Preamplifier Demo Video
August 2018
Hi Folks,
Another great demo video from our dealer Moon Audio regarding the Bryston BP-17 Cubed Preamplifier.
Please see link below.
https://www.youtube.com/watch?v=SRDo1BDDZ2A
September 21, 2018, 01:41 PM #25
- Apr 2013
- 1,874
June 19, 2019, 04:52 PM #26
- Apr 2016
- 590
I owned this preamp for a few months and can only say that if you care about the noise floor of your entire system then ensure you audition first.
It's like music you're only as good as your latest hit, LOL Last year it was the minuet, this year, well, it wasn't. I notice that each online magazine seem to have their picks or favorites they...
