Results 1 to 33 of 33
July 26, 2017, 11:13 AM #1
AudioQuest Niagra 1000 - What the hell are you waiting for?
July 2, 2018, 01:28 PM #2
Re: AudioQuest Niagra 1000 - What the hell are you waiting for?
This looks fairly interesting to me. Anyone have any experience with one of these?
― Neil deGrasse Tyson
July 2, 2018, 01:48 PM #3
Buddy
Boulder 1160 Amp, 1110 Pre-Amp
Audio Research Ref. 3 Phono-Pre
Vivid Audio Giya G2S2 Speakers
MSB Reference DAC
Innuos Statement w/Next. Gen. PS
B & W DB1D Subwoofer X2
Audioquest Niagara 5000 Power Conditioner
Kronos Pro Turntable w/Kronoscope RS tonearm + SCPS-1 PS + MSL Platinum Cart.
VPI HW-40 Turntable w/ Lyra Etna cartridge
Jay's Audio CDT3-MK3 CD Transport
Schiit Mjolnir 2 HPA + Audeze LCD X headphones
Adona Equipment Rack and Amp Stands
Furutech Outlets and Plates + NCF Booster
Shunyata Cables
Synergistic Research Galileo SX Ground Block, FEQ 4, Ethernet Switch UEF, Black Box + Room Acoustic treatments
July 2, 2018, 01:57 PM #4
Nice... would love one of those, but a bit out of my reach at this point ...
July 2, 2018, 02:02 PM #5
Buddy
MSB Reference DAC
Shunyata Cables
July 2, 2018, 02:15 PM #6
Yea... go to Mr. Mike first for anything I may want at this point!
July 11, 2018, 05:04 PM #7
So the AQ Niagara 1000 has arrived. Hopefully I can get it in place this evening. Been looking forward to it!
July 11, 2018, 07:41 PM #8
Paul
Tape Deck Otari 5050B II2
Music Server: Aurender N100H
July 12, 2018, 10:23 AM #9
Very short first listening session.... busy day at work, so I was beat and fell a sleep. (of course Cheryal had some fun with that )....
From a short listen though, very open, very very quite background. I noticed some more subtle details.... seems like the bass is a bit more subdued at this point, but I know there is definitely some breaking in to happen. AQ actually mentions that it will sound good out of the box but will continue to improve as it breaks in.McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
July 12, 2018, 10:31 AM #10
Paul
July 12, 2018, 10:57 AM #11
I replaced a Furman power conditioner. I think the AQ is definitely a step up and I have been told that it out performs units that cost a lot more.
I may move the Furman to a friend; if not will probably move it to the bedroom where I have a Sony TV, cable box, Yamaha Blu-ray, and my NAS (convenient Ethernet port was there with direct access to the network that I had pre-wired in our house when it was built).McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
July 12, 2018, 10:59 AM #12
Glad to hear it complements your system, Randy. Looking forward to hearing more from you as the unit breaks in.
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
AudioQuest Hurricane HC
HRS E1
July 12, 2018, 11:11 AM #13
Paul
July 12, 2018, 11:25 AM #14
Talk to Mike; he told me that he has compared it to other high level power units. Of course, always go to Mike first... I have not regretted anything that I purchased from him!
July 12, 2018, 11:34 AM #15
Paul
July 12, 2018, 11:44 AM #16
Ok call me skeptical but $1k for a glorified power strip? How can this be better than a well engineered transformer coupled power conditioner?
Marty
MSB Premier
PS Audio Powerplant 15
July 12, 2018, 12:34 PM #17
Niagra 1000 Specs:
6 AC outlets: 1 High-Current Ground-Noise Dissipated; 5 Ultra-Linear Filtered/Ground Noise Dissipated
Direction-Controlled Ultra-Low-Resistance Solid-Core Wiring
Ultra-Linear AudioQuest AC RF Filtering Capacitors
* Patented Ground Noise-Dissipation System: 3 banks of direction-controlled ground noise dissipation
Ultra-Linear Noise-Dissipation Technology: More than 18 octaves of AC differential filtering with linear response, optimized for varying line and load impedance
Non-Sacrificial Surge Protection: Withstands multiple AC surges and spikes up to 6000V/3000A
Zero Ground-Contamination Technology: Prevents the noise or surge energy present on AC Line or Neutral from connecting to the AC Ground
Over-Voltage Shutdown with Automatic Reset
Low-Z (low impedance) NRG Series AC Power Inlets and Outlets.
Sounds better than the power strip you buy at Home Depot. I had the Niagra 1000 and thought it was great at eliminating noise which is very detectable on the Avantgarde’s.
An interesting white paper: https://www.audioquest.com/content/a...per-6-1-18.zipMy Systems: http://www.audioshark.org/showthread...481#post158481
July 12, 2018, 12:48 PM #18
I definitely cannot hold any judgement as I have not heard its merits in my system but I am skeptical. So many ways to skin a cat in this industry.
Marty
MSB Premier
July 12, 2018, 12:54 PM #19
July 12, 2018, 12:58 PM #20
Mike have you ever tried a transformer coupled conditioner like the Torus products or similar designs?
Marty
MSB Premier
July 12, 2018, 01:08 PM #21
I've had the Torus and BIT20 (made by Torus). Both were excellent. My APC S20 follows a similar approach (with added UPS). As I've come to understand it (and correct me if I'm wrong), but there are basically four approaches to power conditioning:
1. Transformer Coupled or similar (AudioQuest)
2. Power Regeneration (like PS Audio)
3. The use of non-active materials (Shunyata)
4. A technology which essentially sends "noise" into an unaudible band/cancellation of noise (think Bose headphones). I believe the Ansuz DTC follows this approach.
My experience has been that Power Regeneration is ideal for digital. The non-active materials approach follows the "first do no harm" and works very well. The traditional transformer coupled approach is very effective as well. I don't have enough experience with the Ansuz DTC to comment.My Systems: http://www.audioshark.org/showthread...481#post158481
July 12, 2018, 01:12 PM #22
I am working on a balanced power unit for my digital equipment. I have read good things about this on the low level signal pieces.
Marty
MSB Premier
July 12, 2018, 07:16 PM #23
- Apr 2016
- Bay Area
- 760
Sightly off topic but does anybody know how the Audioquest fares or compares to other passive conditioners like the Audience a6R-TSSD and the Synergistic Research 10UEF ?
The new PS Audio Directstream power plant looks very promising as well!
July 12, 2018, 07:18 PM #24
- Apr 2016
- Bay Area
- 760
July 12, 2018, 09:07 PM #25
- May 2013
- 3,242
The CPT balanced power units are very good but until they get their ownership issues worked out they are not available for sale. If you are interested in one I would keep my eye on the Underwood HiFi website as Wally will probably be the first one to get them. If you just want to run your digital gear through one the 1200 should be more than enough. I don't know if it is still available but Tyson on AC had one of his BPT units for sale for a good price.
July 12, 2018, 11:52 PM #26
- Apr 2016
- Bay Area
- 760
Is BPT and CPT the same thing tech wise ? I know both are based on balanced isolation transformers, BPT is out of business and CPT is having long standing product delivery issues. Apart from that, are their other differences ?
July 13, 2018, 12:11 AM #27
I have both Niagra 1000 and Denali 6000T and end up using the Niagra for TV, AppleTV, cable box and a linear power supply for my reclocker. I compared it with Denali when I first installed it. I feel it’s good for the money, but 2-3 levels below Denali, which is very clearly and easily outperforms.
July 13, 2018, 12:48 AM #28
- May 2013
- 3,242
Dev
I am not sure what the differences are exactly other than the BPT products were always a good bit more expensive. If you are familiar with Mark's history he was not big on reinventing the wheel if he could copy something proven and change it just enough to avoid copyright rules. All I know is that it works and for the price Walter was charging a bargain. Jeff at Tone uses them in his own system as do several other reviewers.Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
July 13, 2018, 09:38 AM #29
Paul
July 13, 2018, 10:13 AM #30
July 13, 2018, 10:48 PM #31
Actually I wasn’t really comparing or hoping to replace Denali with Niagra. I had Denali for a few months when I bought the Niagra because I needed a few extra outlets. Just for fun, I plugged in my integrated and DAC for a few hours after I logged some break-in hours on the Niagra.
I’m also not really looking to see if Denali is 5x better because it’s 5x more expensive. In this hobby, it just doesn’t work that way.
But for the money, the Niagra is well worth it. But it won’t compete with next level well designed conditioners.
July 14, 2018, 10:55 AM #32
Fair enough. I doubt in my system I could appreciate the next level of conditioner. I do believe that the Niagara is giving me a very nice boost in a range that I can afford.
I am continually amazed at just how resolving the system is though. I do not feel that my loft library (the only place that my system truly fits in our house) is large enough to house a larger system anyway ....McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
August 12, 2018, 07:35 PM #33
- Mar 2017
- Berlin, CT
- 259
I'm using the 1000 also. I'm going to upgrade to the 5000 once I get a new amp I think. I've heard the difference and it's a fair amount. I have had it up against my old SR Galeleo power cell 10 with their top cord as well as a few others. I do like the Niagara best for tonality and realistic soundstage. I really love Garth's gear so far. His next products will blow us away in the same way his cords are.
There are lot's of nice conditioners on the market right now. I've found that often times it depends on your own listening room and the quality of your electrical.
Upgrade on the way...
