Page 5 of 5 FirstFirst 12345
Results 201 to 213 of 213
Thread: Esoteric N-01
  1. #201
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,081
    Re: Esoteric N-01
    Quote Originally Posted by mallen123 View Post
    Hi Peter,
    i powered off everything and still have the issue with Sound Stream on IPad not seeing my N01. I then downloaded Sound Stream onto my Android phone and was able to connect and control the N01. So I assumed SS app on my IPad might need reloading. I deleted it from my IPad and downloaded a new version and I am still having the same issue. I have an IPad7, 14.8.1 . Have u heard of any SS issues with this version? Or is my next step resetting the network card on the N01?
    This is a WiFi problem.
    Please try Lumin app, although it is not likely to behave much differently.
    Set different SSID (name) for WiFi 2.4GHz and 5GHz. Try them individually from the iPad. See if one works better than the other.
    Try an iPhone if you have one.
    If these are still not working, try temporarily removing the network extender from the network, and test only with your WiFi router.
    Peter Lie
    LUMIN Firmware Lead
  2. #202
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,081
    Re: Esoteric N-01
    @mallen123 any update?
    Peter Lie
    LUMIN Firmware Lead
  3. #203
    Re: Esoteric N-01
    Quote Originally Posted by wklie View Post
    I've made sure the iPad is on the same network with no success.
    I don't have an iPhone.
    I can see and control the N01 with the soundstream app on my Android phone so not sure it's a network extender issue.
    My next step will be the Lumim app on the IPad
    I havnt tried connecting directly to my router as the N01 would be a beast to relocate to my office for a direct connect to my router.
    Avantgarde Duo Mezzo,
    Nagra VPA 845 mono blocks, Audio Note UK Shinri 300B mono blocks, AudioPax KT88 monoblocks
    Conrad Johnson GAT, Zesto Tessera
    Esoteric K-01X, Esoteric N-01,
    Clearaudio Innovation TT,
    Graham Phantom 2 Supreme Arm/Ortofon Anna, Bobs Sky 2 SUT
    Clearaudio Universal Arm/Benz LPS
    Minus K isolation platform
    Galibier TT,
    Graham Phantom Elite Arm/Clearaudio Goldfinger Statement,
    Kubala Elation Cabling, Shunyata Trident 3, Typhon QR
    Zoethecus stands,
  4. #204
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,081
    Re: Esoteric N-01
    Have you set the different SSID for 2.4GHz and 5GHz? This is important.
    Peter Lie
    LUMIN Firmware Lead
  5. #205
    Re: Esoteric N-01
    Quote Originally Posted by brodricj View Post
    In Fing>Devices does the N-01 appear in the device list?
    Yes
    Galibier TT,
    Zoethecus stands,
  6. #206
    Re: Esoteric N-01
    Yes.
    I just downloaded the Lumin app to my IPad and it works fine. It saw the N01 right away and connected with no issues.
    Galibier TT,
    Zoethecus stands,
  7. #207
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,081
    Re: Esoteric N-01
    Please tell me the Esoteric Sound Stream app version. You're still using iOS 14.8.1 right?
    Peter Lie
    LUMIN Firmware Lead
  8. #208
    Re: Esoteric N-01
    Soundstream 1.1.3
    IOS 14.8.1
    Galibier TT,
    Zoethecus stands,
  9. #209
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,081
    Re: Esoteric N-01
    This is being investigated.
    Peter Lie
    LUMIN Firmware Lead
  10. #210
    Senior Member
    Join Date
    Apr 2017
    Australia
    Posts
    1,758
    Re: Esoteric N-01
    Esoteric is recommending Sound Stream App users do not upgrade Apple devices to iOS16.
    Speakers: Magico M3, ACC, S-SUB | Electronics: Esoteric Grandioso stack | Amplification: Halcro |
    Analog cables: Crystal Cable | Digital cables: Shunyata Sigma | Rack: YG Acoustics Rack 1.8
    | Source: Kaleidescape Premiere (4 x 6TB) | Power: Shunyata Typhon-QR, Everest and Denali
  11. #211
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,081
    Re: Esoteric N-01
    @mallen123 please update to Esoteric Sound Stream app 2.0.0 and verify that it fixes the problem for you on iOS 14.8.1
    Peter Lie
    LUMIN Firmware Lead
  12. #212
    Re: Esoteric N-01
    i downloaded 2.0.0. it sees my N-01 and works fine. Thanks!
    Galibier TT,
    Zoethecus stands,
  13. #213
    Re: Esoteric N-01
    I downloaded 2.0.0. it sees my N-01 and works fine. Thanks!
    Galibier TT,
    Zoethecus stands,
Esoteric N-01
Posting Permissions
  • You may not post replies
  • You may not edit your posts
