Thread: Vitus SS-103 or SM-011?
May 18, 2017, 03:31 PM #1
Similar in power delivery (50w vs 40w class A) both share the newer architecture with intelligent class A & music modes, and are similarly priced. If sound quality is the primary objective which would you choose?
TimTim
Playback Designs mps-5, Nagra Classic Pre, Nagra Classic Amp, YG Carmel 2s, Signal: TaraLabs Muse, Power: Ansuz D & C, Mainz-8D, SRA Craz3 Rack.
May 18, 2017, 03:32 PM #2
Re: Vitus SS-103 or SM-011?
SS-103
May 18, 2017, 03:35 PM #3
May 18, 2017, 03:35 PM #4
May 20, 2017, 01:57 PM #5
- May 2017
- Guildford, UK
- 123
I've heard both back to back and the SS-103 walks it. The SM-011's sound veiled and slow by comparison (and I loved the SM-011's on a home demo). Personally I don't know why anyone would pick the monos over the stereo, although I know some v knowledgable people have it the other way around.
May 20, 2017, 02:44 PM #6
Welcome to the forum heihei, thank you for joining.
May 20, 2017, 09:32 PM #7
- Mar 2015
- 99
just to prove how we all hear things differently. I owned the SM 011 for a couple of years and eventually moved them on as i found them too analytical and somewhat forward in my system. Certainly the opposite of veiled and slow in my system. I did everything i could to slow them down!!.
however their bass control and authority was simply awesome. I remember when i put them into my system (coming from a Vitus SIA 025) it was like i had added a subwoofer to the system.
May 20, 2017, 09:55 PM #8
- Sep 2016
- 901
Personally i'm waiting on the SIA-030 integrated due around the end of the year which will be based on the SS-103 & SL-103 .
May 20, 2017, 10:09 PM #9
- Mar 2015
- 99
i think in retrospect the SIA 025 was a real sweety in my system - and there was probably no need to change. Highlights that moving up the line even within the same brand doesn't mean your going to get more of the same.
May 21, 2017, 08:15 AM #10
- Sep 2015
- 60
May 21, 2017, 05:02 PM #11
- Apr 2013
- New York, New York
- 657
Melbguy1, I'm with you.I wonder if the DAC option will be available when it's released. It would be nice to get some pricing info...
T+A MP3100HV, T+A PA3100HV. Custom made Furutech cables with ETP-609 distributor with NCF outlets, Harbeth 40.2 Anniversaries.
May 21, 2017, 05:55 PM #12
- Sep 2016
- 901
May 21, 2017, 06:00 PM #13
- Sep 2016
- 901
May 21, 2017, 10:29 PM #14
- Mar 2015
- 99
elrog 845's - awesomeness
May 22, 2017, 12:04 AM #15
- Sep 2016
- 901
...or maybe not! The SIA-025 is reminiscent of a good 300b amp in class A mode because of its warmth & the way the midrange is rich and nicely rounded, but of course it will never replace one. Then again, a 300b integrated or stereo amp will never replace what the Vitus does so well .
May 22, 2017, 01:58 AM #16
May 22, 2017, 06:03 AM #17
- Sep 2016
- 901
Hi Ken,
I may not be able to swing a home demo as I have a suspicion there will be a waiting list for the new model, and I would need to sell my current amp to part-fund the new one. With that said, the feedback on the SS-103 and SM-103 mono's + SL-103 has been very positive, so that's a good sign. Also the S5 Mk2's are fairly power hungry, so I think the extra power/control and improved circuit design should more than compensate for any slight loss of warmth.
March 27, 2018, 08:45 AM #18
- Dec 2017
- 73
Hi david,
I own sabrina from w.a feeded by devialet200.
I m seriously thinking of an end game amp, and vitus is on top of my amps.
Would the sia 25 be the pretender for the task?
The ri100 or ri101( the newest one) with built in dac is more in my budget, and i m wondering if he can excel in handling the sabs?
Any thoughts?
Thks
March 28, 2018, 07:33 AM #19
- Sep 2015
- 60
I found this from the Stereophile review of the Sabrina:-
My estimate of the Sabrina's voltage sensitivity on the tweeter axis was 88.2dB/2.83V/m, slightly higher than the specified 87dB. Wilson specifies the Sabrina's electrical impedance as 4 ohms, with a minimum magnitude of 2.53 ohms at 139Hz. My measurement of the impedance is shown in fig.1: the value (solid trace) varies between 4 and 6 ohms between 250Hz and 4kHz, and the minimum magnitude is 2.44 ohms at 135Hz. However, there is also a combination of 4.44 ohms and a capacitive phase angle of –58° at 72Hz, a frequency where music can have considerable energy; this will place a significant demand for current on the partnering amplifier.
Read more at https://www.stereophile.com/content/...Hjkq18SiLm0.99
This impediance drop out at 139Hz can present problems for the partnering amplifier.
Regards
Cyclopse
March 28, 2018, 09:58 AM #20
- Dec 2017
- 73
Thks, i ve read it many times.
I know that sabs require only 50watts amplification, but experience showed that higher wattage is much better!
Ri100 will definitely do the job, but i was wondering what the sia25 with 30 watt class A will be able to do.
Cheerd
March 28, 2018, 12:22 PM #21
- Sep 2015
- 60
The magic with Vitus is class A mode. A total of 25 watts with the SIA-025 or much more with Ri100, more watts but no class A mode. My Harbeths are only 83.5db efficiency and the SIA-025 has no problem at all because Harbeth have made it an easy load. My Raidho was around 87db efficiency but the Vitus prefers the Harbeth load. So it’s not all about efficiency figures.
October 19, 2019, 12:13 PM #22Triangle Magellan Concerto 2 < AQ Everest < Vitus Audio SS-010 Mk2 < AQ Dragon HC < AQ WEL Signature XLR < Chord Qutest w UpTone JS-2 & AQ Dragon Source < SOtM tX-USBultra w 75Ohm Master Clock Input, Paul Hynes SR5-12 Turbo XL & AQ Dragon Source < AQ Diamond USB < Aurender N-100H w AQ Dragon Source < Gryphon PowerZone w AQ NRG-Wild < Solid Tech Hybrid < Ansuz Darkz D-TC, Darkz D2, Stillpoints Ultra SS, Omicron Harmonic Stabilizer & Gold SE < Furutech FT-SWS < Synergistic Research Blue Quantum Fuse
October 20, 2019, 02:41 PM #23
- Sep 2015
- 60
July 6, 2022, 08:39 AM #24
Did anyone keep SIA-025 and added the SM-011 as an upgrade ?
Speaker System : Thiel CS 3.7 - Vitus SIA-025 Mk2 - Aqua Acoustics LinQ - Aqua Acoustics Formula xHD Rev 2 - Fanless Intel NUC + Sbooster Mkll - Farad Super 3 - Paul Pang Quad Switch - Pink Faun LAN cables - Cardas Clear Beyond IC and SC - Furutech DSP 4.1 Power cables - Audioquest Niagara 3000 Power Conditioner - Woodlink Rack - Roon Rock - Qobuz & Tidal.
Headphone Rig : Hifiman HE-1000SE - Kennerton Ondin Mk2 - Chord Hugo 2 - Smartphone - Qobuz & Tidal.
July 6, 2022, 04:59 PM #25
- Mar 2015
- 99
i did exactly this and regretted it
the SM 011 are a much leaner more forward presentation - although they do dig down quite low, the overall presentation is vastly different to the SIA 025. I tried all sorts of things to remedy including adding one of Vitus's own preamps to flesh out the sound but nothing really helped. At the time i was using the Vitus MP Dac and transport as source. The MP Dac was also the preamp.
July 7, 2022, 03:49 AM #26
July 7, 2022, 03:57 AM #27
- Mar 2015
- 99
who knows ..... never had the ss103 in my system ....
if you dont want the SIA 025 as an integrated why keep it as a pre? I was told the MP dac was good as a pre ..... but its not.
July 7, 2022, 04:21 AM #28
July 7, 2022, 05:06 PM #29
Are your speakers coming alive at low volume with the vitus sia 025 or do you need to crank it up a bit ?
Moon 700i V2, YG Acoustics Hailey, Aurender N10, dCS Rossini, Oppo BDP103D (audiopraise board), Ansuz Mainz 8 D2
July 8, 2022, 02:55 PM #30
- Sep 2016
- Germany
- 54
I can say, from my point of view, what happened when I added the SS025 to the SIA025/Gauder RC7 combo. Everything remained the same, timbres, dynamics, spatiality. The only thing that changed was the lack of distortion, which now occurred. In direct comparison, the SIA025/Gauder combo now sounds like excellent hifi. The combination with the extra SS025, on the other hand, sounds like real music.
Vitus Audio SIA-025Mk2 + SS-025 (biamping), Gauder RC7 Diamond black edition, Vitus Audio SCD-025Mk2, Simon Yorke S9+Jan Allaerts MC1 Boron+Dr. Fuss power supply+AS Phonolab, Amazon 1+SME V+Ortofon Rohmann+Nagra BPS, Oppo BDP-105D modified by Gert Volk Audio, Melco N1Z/2 EX H60+D100B+Sbooster, Copulare Grand Porto, Magnan Signature speaker cable, Magnan Vi XLR + RCA, Göbel Lacorde Statement XLR, Göbel Lacorde Statement USB, AQ Diamond + Vodka RJE, Buffalo BS-GS2024 Switch, modified 10Gtek+Startech 1000Base Fiber, Wireworld Starlight 8 CAT8, Vitus Andromeda power cable, Aural Symphonics Magic Gem power cable, Aural Symphonics Cubed v3 power bar, Stillpoints Ultra SS + Ultra mini, Ansuz Darkz, Shun Mook Mpingo Discs, Hifi tuning supreme 3 fuses, ahp Klangmodul 4g fuse module, HMS wall socket, Block Audio C-Lock lite, Furutech NCF Booster. Room 40 m2.
February 15, 2023, 03:23 PM #31
May 4, 2023, 02:04 PM #32
Ok guys guess what, huge change in my system since I replaced my 2 Audioquest Firebird PCs for 2 Furutech DSP 4.1 with FI50 plugs.
My SIA-025 is now in another league, it even outperformed the Audionet Humboldt in a recent shootout.
You Vitus owners should take a look at Furutech DSP 4.1 PCs it’s jaw dropping!!Speaker System : Thiel CS 3.7 - Vitus SIA-025 Mk2 - Aqua Acoustics LinQ - Aqua Acoustics Formula xHD Rev 2 - Fanless Intel NUC + Sbooster Mkll - Farad Super 3 - Paul Pang Quad Switch - Pink Faun LAN cables - Cardas Clear Beyond IC and SC - Furutech DSP 4.1 Power cables - Audioquest Niagara 3000 Power Conditioner - Woodlink Rack - Roon Rock - Qobuz & Tidal.
May 4, 2023, 04:08 PM #33
- Jan 2015
- 122
With a Vitus RI-101-2 needing a power cord, I'll bite.
What did it do for the sound and did you DIY it or..... from whom?
May 5, 2023, 02:14 PM #34
DSP 4.1 delivers way more current to your amp than most cables out there.
Sound is very engaging, full body, organic and yet more transparent than my ex Firebird.
Bass is insanely good, it puts to shame my ex Firebird!
I purchased from this guy :
Furutech DPS-4.1 Alpha-OCC-eDUCC Limited Edition/ FI-50 NCF | Audio NirvanaSpeaker System : Thiel CS 3.7 - Vitus SIA-025 Mk2 - Aqua Acoustics LinQ - Aqua Acoustics Formula xHD Rev 2 - Fanless Intel NUC + Sbooster Mkll - Farad Super 3 - Paul Pang Quad Switch - Pink Faun LAN cables - Cardas Clear Beyond IC and SC - Furutech DSP 4.1 Power cables - Audioquest Niagara 3000 Power Conditioner - Woodlink Rack - Roon Rock - Qobuz & Tidal.
Altaira or Gemini CGS on...
