Hi all,
I have Job 225 coming next week. I am very late to the party I know.
With Job Systems being shut it's a bit of a gamble but having read about this amp, when I saw a classified for £700 I just pulled the trigger.
I am actually putting together a system for the first time and I have a few questions.
Attenuation and preamp matching
I will be driving the Job 225 from the RCA pre out of an RME ADI2 DAC. To deal with the high gain I am able to set the reference level output to -5dBu (the default is +7dBu or 1.73 VRMS). Do I still need attenuators from Rothwell audio? If yes, is 10db enough or will I need more? I plan to order the Rothwell River interconnects with Switchcraft plugs.
RME specs:
Analog Outputs
XLR
- Output level switchable +19 dBu, +13 dBu, +7 dBu, +1 dBu @ 0 dBFS
- Signal to Noise ratio (SNR) @ +7/+13/+19 dBu: 117 dB RMS unweighted, 120 dBA
- Signal to Noise ratio (SNR) @ +1 dBu: 115,4 dB RMS unweighted, 118,9 dBA
- Frequency response @ 44.1 kHz, -0.1 dB: 0 Hz – 20.2 kHz
- Frequency response @ 96 kHz, -0.5 dB: 0 Hz – 44.9 kHz
- Frequency response @ 192 kHz, -1 dB: 0 Hz – 88 kHz
- Frequency response @ 384 kHz, -1 dB: 0 Hz – 115 kHz
- Frequency response @ 768 kHz, -3 dB: 0 Hz – 109 kHz
- THD @ -1 dBFS: -112 dB, 0.00025 %
- THD+N @ -1 dBFS: -110 dB, 0.00032 %
- THD @ -3 dBFS: -116 dB, 0.00016 %
- Channel separation: > 120 dB
- Output impedance: 200 Ohm balanced, 100 Ohm unbalanced
Chinch
As output XLR, but:
- Output: 6.3 mm TS jack, unbalanced
- Output level 6 dB lower than XLR (-5 dBu to +13 dBu @ 0 dBFS)
- Signal to Noise ratio (SNR) @ +13 dBu: 117 dB RMS unweighted, 120 dBA
- Signal to Noise ratio (SNR) @ +1/+7 dBu: 114/116 dB RMS unweighted, 117/119 dBA
- Signal to Noise ratio (SNR) @ -5 dBu: 109 dB RMS unweighted, 113 dBA
Power cord matching
The general consensus among reviewers seems to be that an aftermarket power cord makes a substantial difference. Can anyone confirm this is the case? If so, what cords are a good match?
I am keen on a Oyaide GPXe v2, but given the price I want to be sure of the benefits.
Fuse swap
I came across a review which suggests to swap the stock fuse with a
Telos QBT-18.Has anyone tried this? What is the stock fuse and which specifications should I order if I want to replace it?
Manual
I do not have a copy of the manual. Does anyone have one in PDF and can PM it to me?
Thanks in advance!
