Results 1 to 21 of 21
Thread: Best speakers for Shindo Apetite
February 14, 2017, 04:30 PM #1
- Feb 2017
- Belgrade, Serbia
- 7
Hi,
my name is Djole and I'm from Belgrade, Serbia.
I'm Audioshark forum member few days and this is my first post on this site.
My new amp - Shindo Apetite will come to me at the end of february.
I still have my old speakers Marten Duke II. I like them very much, but I'm afraid that this will be bad match (4ohm, 88db).
If somebody have expirience with Shindo Apetite, or have opinion regarding speakers it would be great!!!
I have possibilty to take Ocellia Calliope 21, or Living Voice IBX-RW for this moment, but I will consider all options.
Also Devore Fidelity O/93 is in some combination...
Thanks
My system
Shindo Apetite, Oracle Delphi Mk V, SME V, EAR 834P Deluxe, Shindo silver interconect, Auditorium 23 interconect, Shindo Mr. T Power Conditioner
My room is 6 x 4 meters with speakers on wider side
February 14, 2017, 05:40 PM #2
Re: Best speakers for Shindo Apetite
Welcome to the forum Djole, thank you for joining.
February 14, 2017, 10:31 PM #3
Welcome Djole - I have had Shindo components including pre amp and amp, though no experience with the Shindo Apetite. The output of my amps was similar to the Apetite. I had mine paired with the Devore O/96 speakers, it was a great pairing, other Devore Speakers such as the 3XLs might also make a good pairing.
As always if possible I recommend you audition before any purchase.
Roon Rock | Ortofon Cadenza Black | Miyajima Zero | VPI Avenger | Devialet 440 Pro | Vivid Audio G3
February 14, 2017, 10:46 PM #4
- May 2013
- 3,242
Take a look at the Heco Direkt or Dreiklang. Both tested in the mid 90's and shown many times with low powered SET amps.
http://www.heco-audio.de/en/loudspea...rekt-dreiklangMain - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
February 14, 2017, 11:01 PM #5
TANNOY Westminster GR.
February 15, 2017, 12:28 PM #6
- Feb 2017
- Belgrade, Serbia
- 7
Thanks Baddog!
What are you thinking about O/93?
February 15, 2017, 12:29 PM #7
- Feb 2017
- Belgrade, Serbia
- 7
Thanks guys!
Mike, I thin that Westminster is to big for my room, maybe Kensingtons?
February 15, 2017, 12:46 PM #8
- Jan 2014
- Los Angeles
- 1,775
Devore O is a great match with that amp and clearly JD uses Shindo in development.
Other high efficiency matches might include Voxativ, Zu, and Spatial AudioBrinkmann Bardo w/ EMT HSD-006 cart, MSB Reference DAC --> Linear Tube Audio MicroZOTL --> Ampzilla 2000, 2nd Edition --> Fyne Audio F1-12
February 15, 2017, 04:33 PM #9
To answer the O/93 question. I know of a user using O/93s with similar gear as yours. He was happy with it, however after time he upgraded to the O/96. A number of factors come into play here, room size, size of your budget, etc... The O/93 is a very nice speaker, the O/96 simply gives you more of those wonderful qualities, plus IMHO more bass.
February 15, 2017, 04:52 PM #10
February 15, 2017, 05:55 PM #11
- Mar 2016
- 37
For small/medium rooms, I would think the Shindo Lafite speaker would be good. I'm considering moving from my O96 to the Lafite potentially, haven't demo'd them but if you want to have an all Shindo system, I think that would potentially be a great match.
February 15, 2017, 10:47 PM #12
Hello,
I owned the Apetite for about two years. Stunning little amp but really needs very high efficient speakers and easy load.
The O93 looks like a good choice.Shindo, Nagra, Electrocompaniet, Harbeth, AMR, Mc Intosh, Auditorium 23, Rega, DeVore, JC Verdier, WireWorld, Kimber
February 16, 2017, 04:49 PM #13
- Feb 2017
- Belgrade, Serbia
- 7
Thanks guys!
It was very helpful!
I was assume that Devore is probably best match for money, only problem is that I can't demo Devore speakers in my country...
But thank to you guys, I'm know more relax and open to make order.
First I will try Ocellia Calliope .21, becouse my dealer have it, and based on specs it maybe can be good combination...
One more question. Is it safe to try my Marten Duke II (4ohm, 88db) with Apetite?
I was read on some forum that this (4ohm speaker) can make damage to this kind of amp?
February 16, 2017, 05:10 PM #14
- Mar 2016
- 37
Hi Djole,
I wouldn't hook a 4ohm 88db speaker to the Apetite for fear of damaging it. This is the opposite end of the spectrum in terms of sensitivity for speakers design for Shindo (ideally they like 16ohm 100db).
I would also point out that while it's widely accepted that Devore/Shindo is a good match, ToneImports hasn't formally acknowledged that Devore is a recommended for Shindo amps. They recommend A23, LM Audio, and Shindo speakers. I will say that Tone does represent these brands in the US so that's likely why he's recommending them, but I think the recommendation is because they truly are fantastic matches for Shindo gear and great speakers in their own right. Some Shindo/Devore dealers have recommended certain pairings for Devore as well, but in my experience they have recommended more towards the ToneImports brands mentioned. FWIW, I think the Haut Brion is a good match for the O93/O96, more so than EL34 based amps in my experience and from what I've read. I've had the Devore Nines and thought that the EL34 based amps sounded better on those. I think the Apetite would do ok on the higher sensitivity speakers of these brands mentioned.
February 16, 2017, 05:21 PM #15
What are your room dimensions?
No one can reliably suggest what might possibly work without some idea of the room itself.DPT4ME - Dynamics, Presence & Tone for Musical Engagement; MBP (3) - stripped down for music only; Shunyata Omega & Sigma USBs; ISO REGEN w/short Curious USB links; Berkeley Alpha USB; Aqua La Scala II Optologic DAC; Schiit Yggdrasil - fully updated; Ayre Codex dac - updated; Pass Labs INT-60 integrated amp; Wyred 4 Sound STP-SE-2 preamp, Quicksilver Mono 120 amps w/Tung-Sol KT150s; Quicksilver Mid Mono amps w/Gold Lion KT77s; Fyne Audio 703s; Symposium Svelte Plus & Ultra Platforms; REL S-812 subwoofers; Duelund DCA12GA speaker cables; AV Room Service EVPs, Stein Music Harmonizers, Duelund DCA16GA & 20GA ICs; Shunyata Denali 6000S/V2; Tripp Lite PCs; Wyred 4 Sound power cords; AudioDharma cable cooker; dedicated custom room; various GIK & ASC room treatments; etc.
www.getbettersound.com
February 16, 2017, 06:50 PM #16
- Feb 2017
- Belgrade, Serbia
- 7
February 16, 2017, 06:51 PM #17
- Feb 2017
- Belgrade, Serbia
- 7
February 17, 2017, 11:04 AM #18
- Aug 2016
- North Carolina
- 203
Goldprint Audio -- Dealer For: PS Audio -- Leben -- KEF -- Line Magnetic -- DeVore Fidelity -- Joseph Audio -- Sugden -- Rogue Audio -- Manley Labs -- VPI Industries -- Bel Canto -- Alta Audio -- Tannoy -- Rega -- Kimber Kable -- Ortofon -- Chord -- Sonos -- Quadraspire -- Salamander -- SVS Sound -- Torus Power -- Audio Desk -- Gingko -- Auditorium 23 -- Box Furniture -- Krell -- Cary Audio -- Soundsmith -- EMT
www.goldprintaudio.com
February 17, 2017, 11:16 AM #19
- Nov 2014
- Phoenix, AZ
- 49
Shindo speakers would be best. If not Auditorium 23. If Devore I would use the O96 with your amp due to the higher efficiency. As others suggested do not use your amp with the Marten speakers.
Jim Perry
Garrard 301 TT in Woodsong Plinth
Ortofon 309D Tonearm
Shindo Cartridge
EMT Cartridge
SME Model 10A Turntable
Benz Micro LP-S mr Cartridge
Aesthetix Rhea Signature Tube phono preamp
Aesthetix Calypso Tube preamp
Aesthetix Atlas Amplifier
Proac Response D-40r Speaker
Linn Genki CD Player
Nordost Cable
February 23, 2017, 04:55 AM #20
- Feb 2017
- Belgrade, Serbia
- 7
Thanks guys!
March 14, 2018, 10:19 AM #21
- Mar 2016
- 161
The Rogers Monitor work very well.
Peter is...awesome. 👌 Absolutely superb and responsive customer support.
Can't Get Spoft to Play Through...
