Page 2 of 2 FirstFirst 12
Results 51 to 67 of 67
  1. #51
    Re: Soulution 511 monos unboxing
    Don't know as I installed the 511's as a mono pair from the beginning....
  2. #52
    I've ALWAYS wanted Soulution monos since I first heard the 501's. Now with the 511's, it's another peg up. I've had the preamp for a while, but I've been saving for the amps. In a word: endgame. Wait, didn't someone already say that? Seriously. Incredible.
    so, how are the 511 behaving after the long break-in? Do you still have them paired with the M3?
    How hot do they get when pushed?
    thanks!
    System: Magico S1 MkII, DCS Puccini Player & Clock, Aurender N100C, SME Mod 15, SME IV, Lyra Etna, Nagra VPS
    Headfi: Violectric HPA V281, Sony Z1R, Kimber Axios Cu
    Cables: Transparent Premium USB, Gen5 Reference 75 Ohm, Ultra interconnects, phono and speaker cables
    Power: Shunyata EU7, Alpha NR, Furutech Powerflux-18E
    Accessories: Finite Elemente 600 APS, several Cerabases, Ceraballs and Cerapucs
  3. #53
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,044
    Quote Originally Posted by pessoa00 View Post
    thanks!
    Yes. The 511's seem to be the overwhelming solid state amp favorite in my store with all the Magico's - including the M3's (but I don't have my new Vitus SM-103 monos yet). They get warm when pushed, but never "hot" like a class A or tube amp. You can put your hand on them for several seconds.
  4. #54
    Thanks. For how much time did you have them running before your felt they reached their full potential?
  5. #55
    Senior Member
    Join Date
    Feb 2014
    Austin, TX & Suburban Chicago
    Posts
    687
    See post #47
    Le Roy
    Foundation:
  6. #56
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    An additional note about sound quality and heat. The Soulution 500 Series are Class AB amps but are heavily biased into Class A. This means they will be operating in Class A mode most of the time for maximum sound quality except for very dynamic passages. This also means they run near maximum warmth while at idle. While my 501 monoblocks were very warm at idle, they were never too hot to touch and they didn't get appreciably warmer at higher volumes. Compared to my Pass XA-100.8 monoblocks, the 501's put out significantly less overall heat. The Soulution amps do need adequate ventilation, so I wouldn't recommend anything above them or too close to the sides.
    Best,
    Ken
  7. #57
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,044
    500 hours, but they continued to improve past 1000. I will tell you they are very sensitive to preamp pairing. I have to say, the Vitus Preamp is killer with them.
  8. #58
    The coment about preamp is interesting. You prefer the Vitus to Soulution own 520? I believe they'll launch a new 525 in Munich
  9. #59
    Senior Member
    Join Date
    Apr 2015
    Front Row Center
    Posts
    3,456
    Soulution , Pass , Vitus ... Ohhhh Mike's wary head ..
  10. #60
    Senior Member
    Join Date
    Feb 2014
    Posts
    687
    Quote Originally Posted by a.wayne View Post
    Wary or weary?
    Le Roy
    Foundation:
  11. #61
    Quote Originally Posted by Odyssey View Post
    Wary or weary?
    Or both?
    Rockport Lyra speakers; TotalDac Amp-1 mono blocks; four box CH Precision L1/X1 pre/power supply monos; CH precision P1/X1 phono/power supply; TotalDac d1-driver monos; Pacific Microsonics Model 2 DAC; TotalDac d1-12 MkII DAC with two reclockers; Kodo The Beat Turnatable with LT Schroder magnesium tonearm and Lyra Atlas cart; Taiko Extreme server; Kalista Dreamplayer CD Transport; Taiko Audio Daiza Platforms; Nordost Odin2 Power Cords and Analog ICs; 512 Engineering/Tim Marutani Balanced Transformers (30 amp for sources; 50 amp for amps); Rives designed dedicated room.
  12. #62
    Senior Member
    Join Date
    May 2017
    Guildford, UK
    Posts
    123
    Any update on how these are sounding? Any idea how these would compare to the 7-series stereo amp which probably comes in around the same price?
  13. #63
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,044
    Quote Originally Posted by heihei View Post
    They’re long gone. Sorry. I switched over to Gryphon.
  14. #64
    Senior Member
    Join Date
    Apr 2015
    Front Row Center
    Posts
    3,456
    So not the solution you were looking ....
  15. #65
    Senior Member
    Join Date
    Feb 2014
    Posts
    687
    The 511 stereo amp was retailing for $35,000 USD and the 711 stereo is around $60,000 USD.
    I have never had the 511 in my system but I currently have the 711 in one residence and the 501 mono blocks in another.
    The 511 is said to have a similar power supply to the 7 series. This may be a benefit of "trickle down" technology.
    Le Roy
    Foundation:
  16. #66
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    Hi Le Roy,
    Would you say the 511 has the same sonic signature as the 501 monoblocks with more oomph?
    Ken
  17. #67
    Senior Member
    Join Date
    May 2017
    Guildford, UK
    Posts
    123
    The point on pricing is that when you double the 511 up to run them as monos, they are about the same as the 711 stereo.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
